Old 03-12-2015, 12:45 PM   #1
bigdawg86
Can I keep the factory SiriusXM tuner?
Hey guys... question as stated. I have a 2014 BRZ and just am about done upgrading my stereo. My headunit will be arriving in a few days (Pioneer 4100NEX) and I was wondering if it's possible to use or adapt the factory satellite radio tuner with an aftermarket HU? I commute in an area with crappy radio reception so I have to have my satellite radio! Thanks in advance.
bigdawg86 is offline   Reply With Quote
Old 03-12-2015, 01:33 PM   #2
sure74
sure74's Avatar
Drives: 2016 Toyota 4Runner Trail Premium
Pretty sure you will need this: SiriusXM SXV300V1 Tuner
sure74 is offline   Reply With Quote
Old 03-12-2015, 02:49 PM   #3
Chimera
Drives: FRS
/May/ be able to with idatalink maestro, but the svx300v1 is cheaper
Old 03-15-2015, 08:22 AM   #4
SVXdc
Radio wiring harness guru
SVXdc's Avatar
Drives: 1996 SVX L AWD
Maestro won't do that. Their OEM integration is only for a few particular car models from the 'large volume' automakers (Ford, GM, Toyota).
I think you'll find that your OEM XM tuner is built into the OEM Fujitsu Ten nav HU. Even in other Subaru models where the sat radio tuner is a separate module, those only work with Subaru's OEM HUs. The only thing to do is sell the tuner module to another Subaru owner who can use it.
You can continue using your car's XM antenna. You'll need to find or fabricate an adapter (to convert from the square plug that was plugged into the back of the HU to the round SMB type used on aftermarket SiriusXM tuners).
First, follow the car's XM cable from the HU down to the floor, and see if there's a junction onto a longer cable (the latter will be the one that goes most, if not all, of the way to the antenna on the roof). Don't confuse it with the GPS antenna's cord, which has a very similar plug at the back of the HU.
If BRZ has that junction on the XM antenna cable, there are OEM "feeder cords" from other Subaru models that will provide what you need.
SVXdc is offline   Reply With Quote
The Following User Says Thank You to SVXdc For This Useful Post:
Chimera (03-15-2015)
Old 03-16-2015, 10:11 PM   #5
bigdawg86
Is anyone aware of someone that was used the factory antenna via adapter or as you described? If so link?
Old 03-18-2015, 11:20 AM   #6
bigdawg86
So I found this adapter... Pretty pricey, but I'm thinking about buying it because I want to keep things so I can easily revert to OEM in the case I sell my car....
http://www.tss-radio.com/installatio...ble-fra3m.html
SiriusXM radio in the FR-S Svend Electronics | Audio | NAV | Infotainment 130 07-16-2016 02:55 PM
Oi Takashi in USA, driving for Import Tuner Magazine FRS tuner impressions. Moto-P Scion FR-S / Toyota 86 GT86 General Forum 15 11-19-2015 05:39 PM
SiriusXm Antenna placement mbh1101 Electronics | Audio | NAV | Infotainment 11 04-07-2014 04:06 AM
DIY siriusxm antenna mount near hood mbh1101 DIY (Do-It-Yourself) Guides 0 03-02-2013 12:10 AM
SiriusXm - 4 more months of free Sat radio chandz05 BRZ First-Gen (2012+) — General Topics 21 02-25-2013 08:08 PM
