Old 03-03-2015, 03:03 AM   #1
rixter145
Sleep Chomper
rixter145's Avatar
Fujitsu Ten/ Back up Camera Bug?
Anyone have rear back up camera not showing? unplugged the cables and replugged it seem to have worked but after awhile the camera is not picked up again. I'm using the Fujitsu Ten head unit stock from BRZ (I hate how there is barely any manuals/info on this bloody unit). Will be trying the beat sonic camera & harness tomorrow to see if it changes anything. I hope it's not a faulty head unit though
rixter145 is offline   Reply With Quote
Old 03-09-2015, 07:05 PM   #2
xwd
I've had my Rydeen Duo installed for over two years now and have never had an issue with it.
Old 03-12-2015, 12:38 PM   #3
sure74
sure74's Avatar
Drives: 2016 Toyota 4Runner Trail Premium
Same here.
sure74 is offline   Reply With Quote
Old 03-15-2015, 07:28 AM   #4
SVXdc
Radio wiring harness guru
SVXdc's Avatar
Drives: 1996 SVX L AWD
Narrow down the problem:
Try the camera on a TV or monitor.
Try some other NTSC video source into the HU (via the 16-pin rear camera harness).
Also check whether the camera's own voltage converter is getting too hot. Many cameras have this problem -- they were only intended to be powered for short times while you're in reverse.
I'm guessing your first camera may have died. Once it stops outputting a video signal, the next time the HU boots it will indicate you don't have a camera connected.
SVXdc is offline   Reply With Quote
Stock Rear View Camera for Fujitsu Ten? Foobar Electronics | Audio | NAV | Infotainment 151 08-19-2021 11:24 AM
Back Up Camera mrhemi BRZ First-Gen (2012+) — General Topics 7 04-22-2014 09:09 PM
Back up Camera Wilson15 CANADA 13 01-14-2014 07:49 PM
FS: JDM BRZ Back-Up Camera Beyer Subaru Audio/Visual, Electronics, Infotainment, NAV 3 06-21-2013 10:55 AM
OEM Back up Camera Perihelion Electronics | Audio | NAV | Infotainment 11 03-25-2013 04:49 PM
