Old 03-25-2013, 07:50 AM   #1
Perihelion
Unemployed DIY Ninja
Perihelion's Avatar
Drives: 2013 SWP BRZ, 1983 MB SD300
OEM Back up Camera
I stumbled across this thing.
http://www.japanparts.com/db/parts_d...ME=484-022-001
Has anybody installed this yet?
Perihelion is offline   Reply With Quote
Old 03-25-2013, 08:31 AM   #2
SloS13
Drives: 2013 FR-S whiteout
Do want. I have a cheap ebay camera and the angle/viewing angle is bad.
SloS13 is offline   Reply With Quote
Old 03-25-2013, 08:32 AM   #3
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
That is too expensive guys. Get the Rydeen Duo. Great quality and fits the OEM camera spot.
Old 03-25-2013, 02:43 PM   #4
Perihelion
Perihelion's Avatar
Link to buy?
Old 03-25-2013, 02:46 PM   #5
Sportsguy83
Drives: Limited BRZ
Originally Posted by Perihelion View Post
Link to buy?
http://www.ft86club.com/forums/showp...&postcount=103
Originally Posted by kludger View Post
If you are looking for something besides e-bay I bought mine for $99 from:
http://www.al-eds.com/Rydeen-Mobile-...0B-p22239.html
They shipped fast and I received it fine, although I can't speak to how well it works yet since I haven't had time to install yet (maybe this weekend).
I got mine for $137 so that $99 looks like a very good deal!
Old 03-25-2013, 03:17 PM   #6
xxscaxx
It is more expensive but i'm curious of its picture quality. That link isn't working btw.
edit, if you click the ft86 link, then on the link for the rdyeen, it works
xxscaxx is offline   Reply With Quote
Old 03-25-2013, 03:21 PM   #7
husker741
I haven't installed my beat sonic yet, but everyone that has loves it. It just goes right into the license plate drill hole. No extra drilling required.
husker741 is offline   Reply With Quote
Old 03-25-2013, 04:20 PM   #8
Beyer Subaru
Drives: 2013 BRZ SWP 6AT Ltd
Yep, I just got done with the install last week. The kit is what you would expect of an OEM set-up as far as picture quality. But the end connections still need a few aftermarket wires installed to the existing harness.
I tried to use @SVXdc 's plug and play harness but I got the one out of a hundred that didn't plug-in. Just my luck. I used his wires to pin the existing OEM harness and everything plugged up just fine.
So if you are to get this kit, I would reccomend to get his pinned wires or something of the like and install them into the original harness.
This kit will require you to drill into the plastic trim piece as well as a hole in the trunk.
Beyer Subaru is offline   Reply With Quote
Old 03-25-2013, 04:37 PM   #9
Perihelion
Perihelion's Avatar
Do I need anything else? Wiring harnesses, etc.? Or does this come with everything included?
Old 03-25-2013, 04:39 PM   #10
Sportsguy83
Drives: Limited BRZ
I used SVXdc plug and play harness, tie wraps and a T-tap to get the camera power off the amp in the trunk. That's it. The camera has glue tape to tape it to trunk, a bolt to bolt it down and enough cable to make it to the HU.
The Following User Says Thank You to Sportsguy83 For This Useful Post:
Perihelion (03-25-2013)
Old 03-25-2013, 04:47 PM   #11
Perihelion
Perihelion's Avatar
Thanks for the info. One last thing... got some pictures of this installed? :happy0180:
Old 03-25-2013, 04:49 PM   #12
Sportsguy83
Drives: Limited BRZ
Not mine, but you can see a lot here:
http://www.ft86club.com/forums/showthread.php?t=17020
Perihelion (03-26-2013)
BRZ Back-up Camera and NAV Bypass SOLVED Flat Black VW Electronics | Audio | NAV | Infotainment 167 02-13-2018 12:45 AM
Back up camera integrated with license plate light brianlo622 Electronics | Audio | NAV | Infotainment 10 05-26-2014 09:04 PM
DIY back-up camera? SloS13 Electronics | Audio | NAV | Infotainment 5 02-24-2013 01:14 AM
Backup Camera Help husker741 Electronics | Audio | NAV | Infotainment 2 02-13-2013 01:04 AM
Drove the 86GT and NC miata back to back on GT5 Hanzo FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 39 01-07-2012 12:56 PM
