Old 03-08-2015, 03:48 PM   #29
akahenry
akahenry's Avatar
Drives: '18 STi
Currently running ENEOS Sustina 0W20. I'll be picking up the same motor oil when the next oil change is due.
akahenry is offline   Reply With Quote
Old 03-08-2015, 09:19 PM   #30
n8dog11914
n8dog11914's Avatar
Drives: 2013 WRB Subaru BRZ 6MT
Originally Posted by M12Power View Post
Walmart has also added the Penzoil Platinum Pure Plus 0W-20 in stores. You can pickup the 5qt jug there; however, you have to go somewhere like Advance Auto to find an extra 1 qt jug. For the first two years of ownership, Walmart only had the Mobil 1 OW-20. I'm glad we now have other 'reasonably priced' options.
http://www.walmart.com/ip/Pennzoil-P...5-Qts/36030479
n8dog11914 is offline   Reply With Quote
Old 03-09-2015, 05:17 PM   #31
MTCRX
MTCRX's Avatar
Drives: Whiteout FRS- autocross ready
Originally Posted by Alltezza View Post
Really appreciate the feedback, I might actually start running Mobil1 now. I just bought Royal Purple. Lol so I might try it out next time if it goes on sale.
FWIW: I went to my Toyota/Scion dealer to get Toyota motor oil for my FR-s, the parts man said they only have bulk oil for the service department and don't sell oil by the quart. He said Toyota recommends Mobil 1 for all of their cars, including the FR-s. If the dealer is recommending Mobil 1 I would have to believe them, I guess.
MTCRX is offline   Reply With Quote
Old 03-09-2015, 05:38 PM   #32
swarb
There are two types, the gold bottle with the titanium and the black bottle. I am using the black bottle and it seems to be fine. I can't find much info on it as it was called "syntec" with no "edge" before. Not sure if they changed the formula.
Old 03-09-2015, 08:10 PM   #33
xwd
I still stay away from Mobil 1. Have seen few EJ20s/EJ25Ts with spun bearings after using it, maybe coincidence, maybe not.
Anyways, I have been using the Eneos Sustina 0w20, but I am switching back to the 0w30 Miller Nanodrive since I have a few liters of it left and it's too expensive to just throw out.
Old 03-10-2015, 12:37 AM   #34
M12Power
M12Power's Avatar
Drives: 2015 Firestorm Scion FR-S 6MT
I think it's just new packaging. They decided to go black instead of gold. Other than that, there's probably no difference. The bottle bought and tested by PQIA last year was gold as shown on their site.
I picked up the black jug/bottle in store at Walmart, and it does have the Titanium label without the word Syntec on the front (on the back, it does say "Formerly Syntec").
M12Power is offline   Reply With Quote
The Following User Says Thank You to M12Power For This Useful Post:
swarb (03-10-2015)
Old 03-10-2015, 12:46 AM   #35
M12Power
M12Power's Avatar
I may give Pennzoil Platinum PurePlus a try the next time (made from natural gas certainly sounds interesting). They did certify it for API SN and ILSAC GF-5, but it seems that they didn't certify it for ACEA...
Old 03-10-2015, 01:11 AM   #36
wheelhaus
wheelhaus's Avatar
Ive been doing more research into it, and apparently a lot of people blame the HTHS rating, which is another method to rate viscosity at the most critical high temp areas, like bearings under load. I believe German Castrol has a 0w30 but it actually operates more like a 10w40 or something because it's HTHS is so much higher. The consensus seems to be higher is better, but it also means the oil is thicker, which means less efficiency and less power. The bigger consensus is for a daily driven car, use what's specified by the mfg, including HTHS ratings. Most synthetic 0w20s fall around 2.6-2.9 it would seem. If you're boosted or run at the track a lot, the constant high heat and high load would warrant a thicker oil with a higher HTHS rating, also an oil cooler. That may be a 5w20, 0w30, or even a 0w20 from another brand.
This would make sense why a lot of people on nasioc were blaming Mobil 1 (again I feel largely because it's so popular/common) and people are modding like crazy making the engine produce huge power with just an exhaust and flash to hit 300whp (nearly 400chp). Maybe 5w30 was a little thin to begin with, but you boost the power by 30% and of course you might have issues without addressing the oil.
Old 03-16-2015, 02:13 PM   #37
bluesubie
Drives: 2004 Subaru Forester 2.5XT
Winner, winner chicken dinner!
Yes, Mobil1 is the most popular synthetic oil in the world by sales. So many knucklehead WRX and STI owner's modify their cars, don't check their oil levels, get a bad tune, and BAM! "MoBILe 1 sUx cuZ mY EnJUn bLOWEd up usINg iT"! And some continue to use 5W-30 "because it's on the cap", even after modding their engines. Low HTHS GF5 5W30 oils are designed to shear for the best fuel economy.
But as uoa's here have shown, the factory recommended GF5 0W20 from any brand does well in a LOT of conditions (excluding modded cars or track conditions).
bluesubie is offline   Reply With Quote
Old 03-16-2015, 02:44 PM   #38
D_Thissen
D_Thissen's Avatar
Amsoil 0W20 (OE in the winter and SS in the summer)
Old 03-16-2015, 03:43 PM   #39
RickyBobby
Drives: 2013 Firestorm FR-S AT
Mobil 1 0W-20
The fall 2014 rebate is back.
Currently Walmart is the lowest retailer for a 5 qt jug of Mobil 1 Full Synthetic Motor Oil (various weights) at $26.68 - $12 rebate = $14.68 + tax.
Walmart, like the last rebate, is not listed under participating locations but I had no problem before getting the $24. rebate purchasing from Walmart.
Promo: https://mobiloil.com/en/promotion/mo...nd-mobil-super
Rebate form: https://apfco.net/secure/R8235W/Content/OfferForm.pdf
Online rebate form: https://apfco.net/secure/R8235W/Home/Entry After you submit one rebate it will ask you if you want to submit another.
Link through Discover to Walmart, buy online, and get 5% cash back, free pickup at store.
RickyBobby is offline   Reply With Quote
The Following 3 Users Say Thank You to RickyBobby For This Useful Post:
Koa (03-16-2015), Pat (04-14-2015), wheelhaus (03-16-2015)
Old 03-16-2015, 03:56 PM   #40
acro
Drives: GT-86
Royal purple 0 -20w
acro is offline   Reply With Quote
Old 03-16-2015, 04:17 PM   #41
D_Thissen
D_Thissen's Avatar
Pretty interesting comparison of 4 different oils(all 5W30), that were cooled down to -40C over night.
[ame="https://www.youtube.com/watch?v=uQ_vxdO_9nc"]-40 Mobil 1 Amsoil Royal Purple comparison - YouTube[/ame]
Old 03-16-2015, 06:29 PM   #42
RickyBobby
Does it ever get down to -40C in Thunder Bay, Ontario?
Running but going nowhere. VictorKassil Issues | Warranty | Recalls / TSB 60 02-04-2015 08:18 PM
Seized motor!! What STX mods should I do while I have the motor out?? BlaineWasHere Tracking / Autocross / HPDE / Drifting 27 12-11-2014 03:39 PM
RPM dip with A/C running BunnyRZed Issues | Warranty | Recalls / TSB 31 10-22-2014 10:56 PM
Something running while car is off. grostoine Issues | Warranty | Recalls / TSB 5 04-11-2014 09:56 PM
Running low on gas Arctek83 Scion FR-S / Toyota 86 GT86 General Forum 63 04-15-2013 08:35 PM
