Old 01-22-2015, 11:53 AM   #71
Sleepless
Sleepless's Avatar
Drives: 2016 FR-S
No issues for me either; many track days and 15K miles. Guessing manufacturing flaw. Talk to TF.
Sleepless is offline   Reply With Quote
Old 01-22-2015, 02:02 PM   #72
CSG David
CSG David's Avatar
If it's aluminum, then chances are, if not properly heat treated, the strength properties drop by 80% at the weld.
Old 01-23-2015, 04:25 PM   #73
Touge Factory
Touge Factory's Avatar
Drives: ZN6
Send a message via AIM to Touge Factory
Originally Posted by THEWAKLER View Post
Has anyone had this happen yet? I thought they felt flimsy when I installed them, didn't think the weld was that weak..
No worries!
We'll sound you a replacement backing plate right away. PM me your name and address and/or order #. We'll get you back on track asap!
This should not happen. We put much effort into properly preparing each individual piece, and using quality materials to ensure durability.
Trying to maximize the opening size while having limited space.
On our Wilwood BBK the rotor is large enough that we don't have to put the opening near the edge.
Touge Factory is offline   Reply With Quote
Old 01-24-2015, 06:40 PM   #74
kosoku
Drives: 2013 fr-s
look at Touge Factory coming through! Good job guys!
kosoku is offline   Reply With Quote
The Following User Says Thank You to kosoku For This Useful Post:
Touge Factory (01-26-2015)
Old 01-30-2015, 09:26 AM   #75
AZP Installs
AZP Installs's Avatar
Drives: '11 STi->'14 BRZ | '14 Touareg TDi
Send a message via AIM to AZP Installs
We've had this on our Project BRZ for about 4,000 track miles and 4,000 street miles. It made a huge difference at Watkins Glen. This kit will also be the preferred kit for the Spec 86 Cup Road Race Series that's starting in 2015.
http://Spec86.com
-mike
AZP Installs is offline   Reply With Quote
The Following User Says Thank You to AZP Installs For This Useful Post:
Touge Factory (04-28-2015)
Old 04-28-2015, 08:50 PM   #76
Touge Factory
Drives: ZN6
Fresh batch!
The Following User Says Thank You to Touge Factory For This Useful Post:
smbstyle (04-28-2015)
Old 06-10-2015, 07:06 PM   #77
Touge Factory
Drives: ZN6
Making a duct kit for the APracing BBK.
We fabricate all parts in house, and use an actual OE spindle from a FR-S to make sure fitment is perfect.
The Following 2 Users Say Thank You to Touge Factory For This Useful Post:
AZP Installs (06-11-2015), Pat (06-10-2015)
Old 06-11-2015, 07:01 AM   #78
AZP Installs
Great ducts! We use them on our Project BRZ and their ducts helped us stay on stock calipers for a while. Nice thing is that the one for the OEM Calipers also work with our ST40 Calipers now!
-mike
Arrows Japan Brake Duct Cooling Kit & Suspension BPAuto Brakes, Suspension, Chassis 65 06-22-2013 09:35 AM
TF Brake Duct Cooling Kit Touge Factory Suspension | Chassis | Brakes -- Sponsored by 949 Racing 33 02-19-2013 06:04 PM
Carbon Fiber Brake Cooling Duct JDMenrique Cosmetic Modification (Interior/Exterior/Lighting) 7 10-25-2012 12:03 AM
Brake cooling duct kit tranzformer Suspension | Chassis | Brakes -- Sponsored by 949 Racing 14 12-14-2011 01:37 PM
