Old 01-22-2015, 02:05 PM   #15
CSG Mike
CSG Mike's Avatar
We use an AIM Solo DL.
Yes, the data is through the CANBUS, but it is also a full datalogger that will not only display what you want, but also log it so you can review later if something is off.
BRZUK (01-22-2015), Koa (01-22-2015)
Old 01-22-2015, 05:20 PM   #16
BRZUK
Drives: GT86
I will take a look at this option
Mike for example what would be your list of top four things to monitor? would love to here your input.
Thanks again
BRZUK is offline   Reply With Quote
Old 01-22-2015, 05:25 PM   #17
Koa
Thanks again
I know you asked Mike, and he has x1000 more experience and insights than I do, but the essentials are: A/F, Oil Pressure, Oil Temp
Fourth, if wanted, would best go to air (IC) temp, boost, fuel pressure (fuel is a known weak link on our FA)
The Following User Says Thank You to Koa For This Useful Post:
BRZUK (01-22-2015)
Old 01-22-2015, 05:58 PM   #18
BRZUK
Drives: GT86
Thanks man i was always going with your top 3 as well and most likely boost but do you think fuel pressure would be better to monitor than boost?
Old 01-22-2015, 06:12 PM   #19
CSG Mike
CSG Mike's Avatar
Thanks again
Typically we watch ECT, EOT, IAT, and Cat temp (EGT).
Boost is moot with a SC; you'll know if you're down and boost, and you can't overboost. Oil pressure requires an external sensor and gauge.
We don't watch Lambda; you should know if your car is running rich or lean by a change in power delivery (like boost), and also be able to gauge via external methods (soot on exhaust, etc.). IMO, AFR is only something you watch if you don't have confidence in your tune.
The Following 3 Users Say Thank You to CSG Mike For This Useful Post:
ATL BRZ (01-25-2015), JEFFSTYLE (01-08-2017), Koa (01-23-2015)
Gauges for frs? wootwoot Cosmetic Modification (Interior/Exterior/Lighting) 9 02-26-2015 01:19 PM
Necessary gauges misooscar Engine, Exhaust, Transmission 5 09-18-2014 02:42 AM
Gauges for supercharger? LtS720 Forced Induction 15 12-23-2013 09:14 PM
WTB: Gauges AtlasMick Engine, Exhaust, Bolt-Ons 2 03-29-2013 12:04 AM
Gauges CyberFormula Scion FR-S / Toyota 86 GT86 General Forum 45 07-24-2010 06:26 PM
