#43 |
Drives: 13 FRS Satin
I'm wondering if anyone knows a good alternative to the HPs price wise. Something with the same tire life, grip and rolling resistance. Reason being, the HPs are more expensive than Pilot Sports which is odd. Are there any 'summer' tires that are even a bit cheaper than the HPs with a similar character? (Got a set of winters so would like the other side of the spectrum) I've researched and found FalkensZIEX ZE914 Ecoruns but I can't seem to get any in my city. They all have stock of the Falken performance summers though.
And a personal thing for me too, mine still have at least 1 or two seasons but I'm thinking heading back to school sooner or later and WILL be broke. But I still want to be able to drive my little twin because I can't give that up. |
#44 | |
Drives: RV-7
http://www.tirerack.com/tires/types/grandtour.jsp |
| The Following User Says Thank You to torqdork For This Useful Post: | Chanpion (01-17-2015) |
#45 |
Drives: 2013 Asphalt 6spd
anyone tried replacing just the front two? agreeing with above the primacy do not give me confidence in < 50 degrees & wet conditions. It could be inexperience, but I have been driving this car for over a year now and I still find that I never know when they are going to let go. This is not so much a problem when it's the back end coming out because you have options to save or enjoy it, But when the front lets go unexpectedly there are much fewer options available. I would much rather spin around in a circle than understeer into a curb.
Phantom ESC, OFH, OFT, K&N Drop in
#46 | |
Drives: RV-7
| The Following User Says Thank You to torqdork For This Useful Post: | Target70 (01-17-2015) |
#47 |
true didn't think about the speed sensors, but then again, before I rotated my tires, my fronts had much more tread on them than my backs, so maybe it wouldn't cause an issue.
#48 |
Drives: 84 CJ7, 08 Duramax, 2014 FRS
My plan will be to put something stickier on when I wear the OEMs out. I do like how controllable the stock tires are, but right now in the Portland, OR area, it's pretty wet, and as stated earlier, these tires wet traction leaves a lot of room for improvement.
I laid into the throttle exiting the Tualatin cloverleaf on-ramp the other night and it got loose on me. I knew I was close, but that one skeered me because that K rail isn't that far away. Also, I don't understand their price point when better tires are much cheaper. There must be some 'prius owners will pay whatever we tell them' mentality in there somewhere. |
#49 |
Drives: '13 FRS - STX
I love them too, but there are two problems with the Primacy HP's: price and weather capability, I don't have to worry about the latter just the former.
If I come across a set of Primacy HP's that are low mileage and cheap (everybody the first year were dumping them before they filled up the tank for the first time) I'll pick them up and mount them when I use up the tires I have now, otherwise there are many better performance options for less money. It isn't worth the extra $80-$200 imo. Primacy: http://www.tirerack.com/tires/tires....7PHP&tab=Sizes Bridgestone RE-11A http://www.tirerack.com/tires/tires....E11A&tab=Sizes Dunlop Direzza ZII http://www.tirerack.com/tires/tires....R7Z2&tab=Sizes Michelin Pilot Super Sports http://www.tirerack.com/tires/tires....SSXL&tab=Sizes Yokohoma Advan AD08 http://www.tirerack.com/tires/tires....D08R&tab=Sizes BFGoodrich Rivals http://www.tirerack.com/tires/tires....FRXL&tab=Sizes Last edited by strat61caster; 01-17-2015 at 10:28 PM. |
#50 |
Drives: RV-7
I've driven cars in the wet on the Primacy's, RE-11A's, AD08's and PSS's. The only one I'd consider suitable for year 'round use in Portland are the PSS's, not sure about the ZII's or Rivals but their tread pattern and survey results can't match PSS wet reviews although they're rated relative to others only within category. PSS are in the Max category vs. Extreme of the others so it's apples and oranges in the wet while the others are better in dry, warmer conditions.
@jeepmor, if you like the control of the OEM tire, you'll really appreciate the added control, balance and recovery ability of the PSS. The downside is a slightly rougher ride in 225/45-17 size and louder tire noise but I run a Perrin unresonated so hardly notice above the din. America's Tire Co. has PSS $100 discount promos quarterly so watch their site for best price (and they match tirerack pre-discount). |
#51 |
The Primacy tires aren't bad, but they are way too expensive to rebuy considering all the other options out there.
As far as Auto X, I'm at the point where I can't improve my times further on the OEM tires either so when these are worn out I'll look forward to something different. |
#52 |
Mentat
Drives: 2013 Scion FRS 6MT
I went with PSS and never looked back.
| The Following User Says Thank You to Muaddib For This Useful Post: | torqdork (01-19-2015) |
#53 | |
#54 |
Drives: GT86 '13 AT, Supra 3.0i Turbo' 91
In terms of price I just compared the Primacy HP to others in stock dimension at my local tire dealer here in Germany.
The Primacy costs 140€ - Same as a Bridgestone RE050 A. For 145€ you get Goodyear Eagle F1 asymmetric 2, Dunlop Sport Maxx RT and TT and Continental Sportcontact 5. Michelin Pilot Sport 3 is 155€, Pirelli P Zero Nero is only 120€! |
#55 |
Drives: FRS
I have a set of PSS for track and mt. Run. But I actually prefer stock tires for daily driving but seeing how much it cost i wont be getting them again.
#56 |
Drives: '13 Ultramarine
If I was doing auto x or track time, I would want better tires. As is, my car is a street car/daily driver and I don't mind the stock tires. The low grip adds to the fun nature of the car. It is part of what makes the car such a riot to drive. There is no arguing that the price is way out of line, and the lack of grip in the wet is kind of scary, but if you ditch (or curb) it, it's because you were going too fast for the road conditions.
| Stock FRS Wheels with New Stock Tires | gbgracer | Wheels and Tires | 2 | 10-05-2014 03:38 AM |
| FS: 2x stock rims with stock tires $120 | retrosmiths | Wheels and Tires | 21 | 04-13-2014 03:20 AM |
| Stay safe in snow 86ers. Don't go out with crap stock tires, only snow tires | stockysnail | Northwest | 36 | 12-19-2013 01:12 PM |
| stock tires on 17 x 9 | andrew5826 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 16 | 11-11-2013 11:26 PM |
| FS: Stock Wheels+Stock Tires+TPMS sensor | Pin Flare | Wheels and Tires | 1 | 03-26-2013 11:07 AM |
