#183 |
Drives: 13' BRZ
@troek helped me with updated definitions which worked perfect.
Ill be switching back to 1x definitions since i just picked up a vortech and will be using oft300 map. Sent from HTC M8 while in burnout mode |
#184 | |
SLO NO MO
| The Following User Says Thank You to Foobar For This Useful Post: | acj47 (12-10-2014) |
#185 | |
#186 | |
SLO NO MO
#187 | |
So if I am using OFT v2.06 map and my calid is A01C, which file do I need to reference? Thank you. |
#188 | |
SLO NO MO
Specifically, you'll need Code:
<table name="MAF Correction After Start (Neutral)" storageaddress="11C868"> <table type="X Axis" storageaddress="11C81C" /> <table type="Y Axis" storageaddress="11C848" /> </table> <table name="MAF Correction After Start (In Gear)" storageaddress="11C964"> <table type="X Axis" storageaddress="11C918" /> <table type="Y Axis" storageaddress="11C944" /> </table> Code:
<table type="3D" name="MAF Correction After Start (In Gear)" category="Mass Airflow / Engine Load" storagetype="uint16" endian="big" sizex="11" sizey="8" userlevel="4">
<scaling units="g/s" expression="x*0.004577637" to_byte="x/0.004577637" format="0.0" fineincrement="0.1" coarseincrement="1" />
<table type="X Axis" name="Coolant Temperature" storagetype="float" >
<scaling units="DegreesF" expression="(x*1.8)+32" to_byte="(x-32)/1.8" format="0.0" fineincrement="1" coarseincrement="10" />
</table>
<table type="Y Axis" name="Idle Mode" storagetype="float" >
<scaling units="Mode Counter" expression="x" to_byte="x" format="0" fineincrement="1" coarseincrement="5" />
</table>
</table>
<table type="3D" name="MAF Correction After Start (Neutral)" category="Mass Airflow / Engine Load" storagetype="uint16" endian="big" sizex="11" sizey="8" userlevel="4">
</table>
</table>
</table>
#189 | |
Thanks - just figured that out. My problem was this tidbit of information: Why is my Tune Calibration ID different from my stock ROM or in OFT/OFM...OFT tunes are generally based on the latest ROM revision for your ROM type...For USA/Canada type = C eg ZA1JB01C...2.0X tunes based on B01 revision So once I added the two parts of code from the B01 file https://raw.githubusercontent.com/TD...R_ZA1JB01C.xml I then opened up in RomRaider and: success! Thanks to all who helped! |
| The Following User Says Thank You to acj47 For This Useful Post: | RavioliG (01-26-2015) |
#190 |
SLO NO MO
Right on! I've been using the quiet cold start through cold weather (right at freezing) and haven't had any issues. I know the primary purpose of the original start parameters are to make the cats more efficient, so I'm feeling a bit guilty about that, but then again, I've already eliminated one of the cats, so I'm already in the hole I guess.
#191 | |
Exactly - I don't want to be the pesky neighbor with the loud exhaust, especially early in the morning. I changed the Ignition Timing Post Start values to 0 (0.04) yesterday, but the car still started up at ~2100 RPM and threw the CEL P050B (Cold Start Ignition Timing Performance). I'm hopeful that editing the MAF Correction AFter Start (In Gear) & (Neutral) tables will eliminate throwing the CEL and bring down the idle RPM to my Idle Speed Target values. This forum rocks
#192 | |
SLO NO MO
#193 |
Generally Well Liked
Drives: '08 STi Hatch, '11 Outback 3.6R
Last weekend I started my car in -15C a couple times, zero issues.
- AdrianG |
#194 |
#195 | |
Drives: FT86
just disable the code. we never throw that code on G roms, must be something dierent in usa roms. you need to alter the maf correction at statup or the car will still idle high and not follow the idle maping settings at startup |
#196 |
I've been using a cold start tune for a while and haven't had any codes, but I modified mine to be slightly less aggressive down low since I live in a place with freezing temps.
| Cold start question | retrosmiths | Scion FR-S / Toyota 86 GT86 General Forum | 106 | 11-15-2016 03:14 PM |
| Cold weather knocking during start ups. | JDMenrique | Issues | Warranty | Recalls / TSB | 38 | 01-13-2015 12:53 AM |
| backfire at cold start | FreaQshoQ | Scion FR-S / Toyota 86 GT86 General Forum | 15 | 10-16-2013 07:21 AM |
| White Smoke cold start up in Cold Weather (turbo cars) | whitefrs | Forced Induction | 17 | 09-25-2013 06:05 PM |
| Loud cold start and mpg drop since new | be6sti | Issues | Warranty | Recalls / TSB | 7 | 11-28-2012 02:35 PM |
