#29 |
in orbe terrum non visi
Drives: violent
Or he forgot to put the ground on top of the bellhousing back on and the di computer isn't on.
I have E85 where there isn't E85, that's my secret.
http://www.ft86club.com/forums/showt...t=reaper+build |
#30 |
Drives: series.blurrr
Yeah those were all the first things I figured (like I said I do have a decent car background).
No I'm not cranking it for 30 seconds that would drain the battery or even possibly burn up the starter. Yeah I cranked it multiple times for up to 10 seconds. No I wasn't quite that careless haha all grounds and all plugs are back in their places double triple n quadruple checked. Almost off, just got the clutch to go, can't remember but I'm pretty sure the rpms didn't show but not positive (can't check now that the starters off but ill check again after its back) |
#31 |
#32 |
Well????
The suspense is killing me!
#33 |
Ok well I'm not sure what it was but something along the lines when I redid it worked. I have a feeling it was the timing disk. Thorpedo ill shoot ya a pm.
Unfortunately now I have the problem of a grinding noise when decelerating between 2800 and 2200. Not sure if its the fact that I used redline MTL or what. And the struggle continues >.< |
#34 |
Drives: 2014 SWP BRZ, MT
Did you get a lightweight flywheel? It could just be gear chatter, I have a similar sound on deceleration. It's common with lightweight flywheels.
The answer is racecar. Always.
#35 |
Yuuuuuup Just found that out. Glad to know its normal. Wish there was a way to fix it
#36 |
Going to start a separate thread to see if anyone knows of any way to fix that.
| The Following User Says Thank You to bren5279 For This Useful Post: | shiro (11-28-2014) |
#37 |
Drives: violent
To fix what? Gear chatter from a lightweight flywheel? The stock flywheel is engineered to be as light ad absolutely possible without causing gear chatter. Some manufacturers use a dual mass flywheel in an attempt to go even lighter without causing chatter. A lighter than stock flywheel WILL chatter no matter what you do. It's physics.
#38 | |
The SquadWhisperer
OP just do some searching, there is lots of evidence out there that Reaper is incorrect. I know of two cars locally that run lightweight flywheels without gear chatter. "It's physics"..... come on man.
2013+14+15 Atlantic Region Motor Sports Autocross STX Champion
2013+14+15 Atlantic Region Motor Sports Overall Autocross Champion 2017 Bluenose Autosport Club Overall Rallycross Champion Powered by Great North Performance, Jani-King Canada, and OK Tire. |
#39 |
Drives: violent
? Good luck. Gear chatter is caused by a flywheel not holding enough inertia and on deceleration. This is well known and the purpose of dual mass flywheels.
I'm not arguing this. Let the world know if you find a fix. Because BMW couldnt.
#40 | |
Drives: 2013 Scion FR-S, 2014 Lexus IS350
You beat me to it!!! That was the issue I had when I replaced my first clutch. That damn disk behind the flywheel LOL! I'm glad you figured it out ![]() As for the other questions on chatter. I'm getting some pretty good chatter between 2-3K RPMs on acceleration and deceleration. I'm not 100% sure it is the clutch but it is quite possible. I'd love to troubleshoot it but I haven't found much on alternate possibilities than the clutch creating that noise. I'm currently using an Exedy Stage 4 clutch. - Exedy Forged Chromoly Flywheel - Exedy 6 Pad Cerametallic Friction Disc - Exedy Hyper-single Forged Aluminum Cover I'll have to check out the new thread when created.
#41 |
Drives: ft86
how did you have the disc installed incorrectly? it was flipped over?
#42 |
Drives: BRZ DGM Limited
glad to hear you figured it out. Do you need my address to send be the $50? From my post:
flywheel not lined up or backwards. LOL |
| Car wont start? Anyone else? | ScionFrsFan | Issues | Warranty | Recalls / TSB | 150 | 06-09-2017 10:35 PM |
| filled up w e85 now car wont start..id1000s dw65s jdl kit | kingkai23 | Forced Induction | 8 | 07-24-2014 11:56 AM |
| car wont start, winjet to blame?? | 7M-King | Cosmetic Modification (Interior/Exterior/Lighting) | 21 | 12-29-2013 04:34 PM |
| Car Wont Start Up HELP !!*** | ScionFR-S | Issues | Warranty | Recalls / TSB | 20 | 11-28-2013 02:01 AM |
| URGENT : CAR WONT START | DarkCard | Engine, Exhaust, Transmission | 9 | 08-01-2013 09:57 PM |
