Old 10-29-2014, 11:56 PM   #141
Luckrider
My Other Ride's a Jeep
Luckrider's Avatar
Drives: 2013 BRZ Limited
Originally Posted by mid_life_crisis View Post
RR?
RomRaider. I am currently running my 1.5X tune if I remember correctly. It doesn't take advantage of all of Shiv's new work, but I would be more than happy to share it for the cranking tables.
Luckrider is offline   Reply With Quote
Old 10-31-2014, 11:27 AM   #142
mid_life_crisis
Drives: FR-S 10 #103 AT
Now that I'm back on 93, I just realized this morning that the crickets had gone away while on E85. Of course I realized that because they came back!
“Sex is like Bridge. If you don't have a good partner, you'd better have a good hand.” - Mae West
Papa said, "son there's a lot of evil temptations out there. Best to try 'em all so you know which ones to avoid."
mid_life_crisis is offline   Reply With Quote
Old 11-09-2014, 07:49 AM   #143
Wayno
Wayno's Avatar
Drives: Toyota 86 GTS
Gains quite noticeable going from petrol to E85, more torque over entire rpm range better top end even on completely stock car. Our P100 RON only about as good as the USA 91. Even on 100ron you cannot run the usa 93 maps without heaps of knock.
gain on stock car in USA was dyno around 15-20 hp with our crap fuel our gain likely to be closer to 20 as we would be down a few hp due our crap petrol. @Wayno had some dyno numbers from aussie cars
The difference for us would be greater than the difference for the americans. The 91 tune will run almost knock free on the street with P100 and requires about 2 deg taken out to stop knock on the track on the exact same tank.
Old 11-10-2014, 08:18 PM   #144
ZZT86
ZZT86's Avatar
Drives: BR86
Wayno - You in sunshine state ? I do exactly as you just stated although I don't use united petrol, I use shell 98 for the top up which sh1ts me really :/ It's still too bloody cold here.
ZZT86 is offline   Reply With Quote
Old 11-10-2014, 09:17 PM   #145
steve99
Drives: FT86
try malts cranking table enrichment values link in first post
Old 11-10-2014, 09:42 PM   #146
Wayno
Wayno's Avatar
As far as i know cranking enrichment is for 2nd crank and later. Always starts 2nd crank on pure e85 anyway so no point.
Old 11-11-2014, 02:13 AM   #147
steve99
Drives: FT86
where did you find that info ?
Old 11-11-2014, 03:16 AM   #148
Wayno
Wayno's Avatar
I assumed cranking state number was the number of cranks and which starts at 2 which is why everyone reports great results of being able to always start on 2nd crank when editing those tables but it's probably a calculation the ECU does based on some voodoo and not the number of cranks.
Old 11-11-2014, 04:05 AM   #149
Td-d
Garden variety obsessive
Drives: 2009 Sti Hatch; 2015 Audi RSQ3
Chuckle... not even close. It's not clear, but in all likelihood it's the various stages of start up that are referenced by arghx7 earlier on in this thread:
http://www.ft86club.com/forums/showp...2&postcount=29
Td-d is offline   Reply With Quote
Old 11-11-2014, 10:57 PM   #150
Wayno
Wayno's Avatar
Can you post your rom up please mate?
I tried E70 (40L E85, 10L P100), knocks heaps. I could try 77% next (45L E85, 5L P100), but easier at that stage to run straight E85 i think.
Old 11-11-2014, 11:03 PM   #151
Luckrider
Luckrider's Avatar
I tried E70 (40L E85, 10L P100), knocks heaps. I could try 77% next (45L E85, 5L P100), but rather run straight E85 i think.
https://drive.google.com/file/d/0Bz4...ew?usp=sharing
That is based on the 1.42 ROM but the cranking tables are the important part and have my revisions.
Just remember:
Old 11-12-2014, 06:15 AM   #152
tmichel
tmichel's Avatar
Drives: Sonic Blue 2014 GT86
http://datazap.me/u/tmichel/e85-1st?...ta=1-6-9-10-14
Hi Steve first run on Caltex E85 hopefully had enough learning time can you please have a look see what you think
tmichel is offline   Reply With Quote
Old 11-12-2014, 07:14 AM   #153
steve99
Drives: FT86
Looks good
Fuel trims good
AFR looks bit rich probably due residual petrol in tank lowering E%.
slight bit of knock -0.6 again probably due residual petrol.
Old 11-12-2014, 06:07 PM   #154
tmichel
tmichel's Avatar
Will try a tank of united once this one is empty and see how that goes.
Stock FR-S Tune Just Done Zach3794 Engine, Exhaust, Transmission 67 11-05-2017 02:01 PM
stock BR-Z, much detonation during shifts: tune? elefunkd Engine, Exhaust, Transmission 69 07-26-2013 04:20 PM
Anyone have a stock tune from Visconti? Bleevin CANADA 3 07-03-2013 01:01 AM
My Initial (all stock) BRZedit tune mad_sb Engine, Exhaust, Transmission 6 02-16-2013 12:20 PM
Save stock tune with ecutek? gdrider77 Engine, Exhaust, Transmission 7 01-06-2013 12:50 AM
