| Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) Everything related to the mechanical maintenance of the FR-S and BRZ |
Drives: Stock brz
Do Fumoto Drain Plugs remove all oil?
basically what the title says.
I've been doing research on the valve, but I keep getting mixed reviews. Some people claim it's the best thing ever. Some people say it leaves a bit of the old oil in the pan due to it sticking into the pan a little. My question is for anyone that owns one. Have you ever released the valve to drain the oil, and then remove the plug? Did any additional oil drop out? I'm all for easier oil changes (mainly to avoid dropping the drain plug in the oil) but if it's not 100% the same functionality as the regular plug. I'll just stick with the oem plug. |
#2 |
The laws of physics/geometry say that there will be a little bit of oil left, but not enough to matter.
Think of it this way, even with the regular drain plug there is still going to be some oil coating the walls of the pan and other engine parts. By the time you've added a fresh 5.5L of oil, it's not going to matter. |
#3 |
Drives: Stock brz
I understand that, but I'm just curious if anyone has ever removed the plug after draining the oil using the plug.
#4 | |
Drives: 2005 Toyota Camry
![]() Honestly, just don't think about it. You're better off monitoring your oil levels regularly than worrying about every last drop. -alex |
#5 |
Drives: 2013 Subaru BRZ
I've been doing research on the drain plug, but I keep getting mixed reviews. Some people claim it's the best thing ever. Some people say it leaves a bit of the old oil in the pan due to it sticking into the pan a little. My question is for anyone that owns one. Have you ever removed the drain plug to drain the oil, and then removed the pan? Did any additional oil drop out? I'm all for easier oil changes (mainly to avoid dropping the drain pan and replacing the gasket every time) but if it's not 100% the same functionality as removing the pan. I'll just stick with removing the pan and cleaning every last bit of oil out with brakleen and shop rags.
1jz salvaged brz build thread brought to you by visconti tuning --> Pipe dreams and poor life choices
#6 | |
Off Topic
#7 | |
This is just an anecdote, but you know how automakers changed up the recommended oil change intervals in the late 90's / early 00's? It took a TON of durability testing to do that. Supposedly during that testing, GM engineers figured out that at highway speeds, the typical LS1/LS6 ate enough oil through blowby that they could top it up with mobil1 and swap out filters every now and again, and basically run it indefinitely without actually changing the oil because they were putting in a fresh quart every few thousand miles. With that in mind, a tablespoon or so of used oil trapped against the body of the fumoto valve probably isn't going to blow your car up.
#8 |
Drives: Stock brz
#9 |
#10 |
Drives: 2015 Scion FRS
I talked to the folks at Fumoto and they said that they would be happy to send owners of the FR-S and extra washer which would lower the plug but would still provide suffient threads to hold the plug. Maybe this is an option
#11 |
Drives: 2014 WRB BRZ Limited
Just did my first oil change with the Fumoto valve installed. Filling it up with 5.4L as recommended in the manual put me at the perfect level on the dipstick.
If there is any residual oil left in the pan that can't clear the edge of the valve, it is so little that it's insane to be worrying about it. |
#12 | |
Drives: 2004 Subaru Forester 2.5XT
![]() Dennis |
#13 |
Drives: 2014 SWP BRZ, MT
I have this valve and can attest to it being the best thing ever :p. I'll be changing oil pans in a few days (oil return line) so I'll take a picture of the inside and how much it sticks in. Regardless that extra ounce of oil isn't going to blow something up. You can't really get all of the oil out anyway, there's always drops here and there.
#14 |
Drives: frs
Mine does because i cut the threads down by all most half.
Measured threads in pan and cut valve to match. |
| Greddy Magnetic Oil Drain Plug or Fumoto Drain Valve? | tracerit | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 20 | 01-04-2016 07:36 PM |
| Transmission fill and drain plugs | goshem | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 5 | 07-27-2014 12:37 AM |
| GROUP BUY: Fumoto Drain Valve | Simon99 | Mechanical Maintenance and Tools | 8 | 03-28-2014 06:27 PM |
| Installed Perrin shifter bushing & Fumoto oil drain valve | zooki | Engine, Exhaust, Transmission | 23 | 03-31-2013 05:18 PM |
