Old 10-23-2014, 11:14 PM   #15
kodyo
Drives: Scion FR-S
Yes, but did the clutch in your friend's GTO slip on throttle in top gear? OP's clutch disengages just fine. It slips.
And the pedal feels soft because the clutch disc is worn down to the rivets - loose pressure plate.
Hence term "shot in the dark". I just think it's odd that his clutch went out at 27k miles with no explanation.
kodyo is offline   Reply With Quote
Old 10-23-2014, 11:24 PM   #16
OkieSnuffBox
Drives: '23 BRZ Limited
Ensure the slave cylinder isn't leaking.
Old 10-23-2014, 11:50 PM   #17
Oh, I hear ya. On a related note, I am amazed at the pedal travel between the touch point and full engagement in this clutch. I have 6000 miles on mine and am ready to look for a slave cylinder with a smaller bore.
Does anyone else notice this? I'm afraid I'll fry my clutch as much as it fakes me out.
Old 10-24-2014, 03:18 PM   #18
username404
Drives: 2013 BRZ Limited GB 6MT
My friend had a master cylinder go out on his '05 GTO. The symptoms were a soft clutch similar to what OP described. We bled the lines and he was able to shift a little better, but it still didn't disengage the clutch fully, but enough to get it to the shop. He replaced the master cylinder and it fixed his problem.
A clutch going out at 27k miles is a clear indication of some other problem. Driver or mechanical. He may need to replace the clutch. But if he doesn't find the underlying problem, he may encounter this again in the future.
Any suggestion how i should describe the issue? Or else i am sure that dealership will ask me to replace the clutch as wear and tear (driver fault).
username404 is offline   Reply With Quote
Old 10-24-2014, 03:23 PM   #19
username404
But then how do you explain about my issue #2 where gear indicator is showing incorrect gear? From my understanding, unlike 370z, this one is software based and displays which gear in based on the RPM and Speed.
Old 10-24-2014, 03:58 PM   #20
Akari
Drives: 2013 DGM BRZ
If your clutch is slipping(Regardless of if your clutch is bad, your pedal being out of adjustment, or air in the line) then the computer won't be able to calculate what gear you're in as RPM will not match up to speed in it's internal table.
Akari is offline   Reply With Quote
The Following 2 Users Say Thank You to Akari For This Useful Post:
kodyo (10-24-2014), Ultramaroon (10-24-2014)
Old 10-24-2014, 04:53 PM   #21
wparsons
wparsons's Avatar
Not to be an ass, but I bet the explanation is between the seat and the pedals.
I've seen people a clutch in a weekend, I've also seen people get 400k km's out of an OEM clutch. It's all in how you drive and how much you're riding the clutch.
flickr
Calum (10-24-2014)
Old 10-25-2014, 10:14 AM   #22
username404
Thanks for all the input but i have one more question. If the clutch is worn already, would it still burns at 5th and 6th gear?
Old 10-25-2014, 11:19 AM   #23
White64Goat
Does it slip in 1st through 4th?
Old 10-25-2014, 01:37 PM   #24
Unless you know what to look for, the effect of a worn clutch will first be felt in the tallest gear. As it gets worse you will no longer be able to hook up in progressively lower gears. This will happen pretty quickly. Get it fixed now while you can still drive it to the shop.
Old 10-26-2014, 12:15 AM   #25
username404
NOPE
Stock brakes worn out? Brahsbrah Suspension | Chassis | Brakes -- Sponsored by 949 Racing 8 04-05-2014 01:08 AM
Worn floor mats - Covered under bumper to bumper warranty? Philly758 Issues | Warranty | Recalls / TSB 45 08-19-2013 01:32 PM
Worn out clutch stopper AsianStyle Issues | Warranty | Recalls / TSB 1 07-05-2013 07:07 PM
Worn Clutch? Jakeedaman21 Issues | Warranty | Recalls / TSB 18 04-30-2013 02:06 PM
