Old 10-09-2014, 07:46 PM   #1
ExxelDistributions
ExxelDistributions's Avatar
Drives: 2014 FR-S 6MT Monogram Series
Tire Size Suggestion
I am considering buying a set of Enkei NT-3+M 18x9.5 +40 wheel for my frs. I already placed my order and just had a tire fitment question.
What is the best tire size that fits with that setup and width that wont rub crazy and I won't have to roll fenders. Some info about my car is I have KW V3 coilovers and it is lowered about an inch front and rear. If anyone has some info on these wheels and setup that could help with what tire size would be best please help. Thanks in advance!
ExxelDistributions is offline   Reply With Quote
Old 10-09-2014, 10:48 PM   #2
Phelzes
Drives: 2013 Whiteout 6MT FRS
Well +40 is a pretty high offset so it will be tucked in, I would say go for a staggered setup as 245/35/18 in the rear and 235/35/18 in the front. Watch the sidewall maybe do a 40. What are your spring rates?
Phelzes is offline   Reply With Quote
Old 10-10-2014, 07:15 AM   #3
midnight23
dying bird under the hood
Drives: 2013 SWP Limited BRZ
i have a set of advans 18x9.5 +40 I run 255/35/18 on them. I only rub on track during elevation changing turns and even then it's not terrible.. It's a fine setup for daily driving.
Build Thread
Instagram
Old 10-10-2014, 11:43 AM   #4
ExxelDistributions
have you rolled your fenders or as is with a drop you fit that size?
Old 10-10-2014, 11:44 AM   #5
ExxelDistributions
not really looking for a staggered setup. I want to do a square setup.
Old 10-10-2014, 02:07 PM   #6
midnight23
As is. 2.2 camber all around
Build Thread
Instagram
Old 10-11-2014, 06:13 PM   #7
ExxelDistributions
does it rub if you try to correct the camber?
Old 10-11-2014, 08:39 PM   #8
midnight23
Usually you will run some camber in general. I'm not sure if it will rub 0 all around.
Build Thread
Instagram
Old 10-12-2014, 07:39 PM   #9
ExxelDistributions
thanks for giving me the help and info i need
Tire size help sharris721 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 9 06-19-2014 12:03 AM
Tire size TofuAE86 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 04-10-2014 12:03 AM
Tire suggestion...245/35/18 with good grip and 20k continuecrushing Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 04-01-2014 07:24 AM
Appropriate tire size for 250-350 whp Tiz Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 13 07-12-2013 02:40 PM
Tire Size help! J-Money Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 02-04-2013 12:04 PM
