Old 10-07-2014, 09:50 PM   #169
AdrianG
Generally Well Liked
Drives: '08 STi Hatch, '11 Outback 3.6R
Originally Posted by troek View Post
for the the biggest difference was the maf correcction after start tables. if you dont have those in romraider, shoot me a pm with your email address, and what cal rom you use.
Thanks but no need right now, Vishnu has told me that an updated definition is coming soon so I will wait for that.
- AdrianG
AdrianG is offline   Reply With Quote
Old 11-08-2014, 11:43 PM   #170
edeekeos
edeekeos's Avatar
Drives: 2014 Pearl BRZ Limited
Any updates of these updated xml's with the MAF tables added? I'm on B01C and absolutely have to get this idle down. I have no cats in my exhaust, and it's STUPID loud. Sounds like the car is going to blow up LMAO!
I've set the timing from -15 to 0, and its 'better' but still idles high as hell..
| OFT & Stg2 e85 Tune | Perrin Intake Tube & High Flow Filter | Perrin Lightweight Crank Pully |
| Tomei UEL Header/Overpipe | HFC/Perrin Catback | Tom's Tails | Enkei RPF1's | RS*R SuperDowns |
edeekeos is offline   Reply With Quote
The Following User Says Thank You to edeekeos For This Useful Post:
akahenry (04-30-2015)
Old 11-09-2014, 01:11 AM   #171
troek
troek's Avatar
Drives: 2012 Toyota 86
check ur pm
troek is offline   Reply With Quote
Old 11-09-2014, 04:38 AM   #172
JamesBond000
First Class Speeder
Drives: Silent and Quick
lol tell me about it cold start at 330 am in a basement parking garage with a check engine light = 2200 rpm for 30 seconds with Buddy Club No resonator Header back catless...
JamesBond000 is offline   Reply With Quote
Old 11-10-2014, 10:12 PM   #173
Foobar
SLO NO MO
Foobar's Avatar
Anyone make these cold start idle changes on an OFT300 tune? Looking to try this out on mine.
Old 11-10-2014, 10:34 PM   #174
phrosty
Living in what is about to become a very cold climate, seeing these huge mods at the low end kind of freaks me out. I imagine that while these table are likely very effective at heating up cats, they might also have something to do with keeping an extremely cold engine going.
I changed it to be much less aggressive than the above recommendations until it gets to 50 degrees:
MAF Correction After Start (Neutral): 40 20 11 10 10 9 9 9 9 8 8
Ignition Timing Post Start: -15.07 -15.07 -15.07 -15.07 -15.07 -8.04 -8.04 -8.04 -8.04 -8.04 -8.04 -8.04 -8.04 -8.04 -8.04 -8.04
I left MAF Correction After Start (In-Gear) as stock because I have a remote starter installed and by the time I get into gear, it's warm.
phrosty is offline   Reply With Quote
Old 11-10-2014, 10:35 PM   #175
bee_are_zee
bee_are_zee's Avatar
Drives: GBS BRZ
I will here shortly. I currently don't have an exhaust on so it wouldn't do much good hah. Have you checked if the tables are in the definitions? I know at least my tune is pretty old and before some of the stuff was mapped out.
bee_are_zee is offline   Reply With Quote
Old 11-10-2014, 11:17 PM   #176
Foobar
SLO NO MO
Foobar's Avatar
I'm using the RR_ZA1JA00C.xml definition from the OFT site and it doesn't appear to have these tables. Is it safe to use anyone's definition file for this CALID or do I have to get one specifically for the OFT?
Old 11-10-2014, 11:32 PM   #177
phrosty
Be very careful, because OFT's CALIDs are different. Most of the 2.0x ROMs are actually version B01 masquerading as something else. Using the wrong def could result in you bricking an ECU.
The Following User Says Thank You to phrosty For This Useful Post:
Foobar (11-10-2014)
Old 11-10-2014, 11:34 PM   #178
Foobar
SLO NO MO
Foobar's Avatar
Roger that - I'll reach out to Shiv to see if he can send me the def file that he's been using.
Old 11-12-2014, 12:32 AM   #179
Foobar
SLO NO MO
Foobar's Avatar
OK, thanks to all the contributors in this thread. I successfully made this change on my OFT300 tune. Shiv confirmed it was a 1.x definition so I worked with the OFT 1.x XML file and added the tables documented in this thread using TD-D's version in github. I didn't take his entire file in case my OFT one had some specific values it needed.
Old 11-12-2014, 09:39 AM   #180
bee_are_zee
Drives: GBS BRZ
@Foobar care to share?
Old 11-12-2014, 02:18 PM   #181
Foobar
SLO NO MO
Foobar's Avatar
You mean the definition file? What CAL do you have? If it's A00C I can share the file I modified (I changed a few of the DTC names as well because the forward slash prevented them from showing up in RomRaider). If it's something else, you'll need to start with your appropriate OFT 1.x definition file then add the table definitions from TD-D's definition file for your CAL. Could you simply use TD-D's file to begin with? It might work, but I wasn't sure if Shiv had something in his version that was unique to OFT.
Old 12-10-2014, 11:18 AM   #182
acj47
acj47's Avatar
According to this thread, I should have the tables "MAF Correction After Start (In Gear)" and "MAF Correction After Start (Neutral)" in the "Mass Airflow / Engine Load" folder of the .bin file.
I am using OFT v2.06 A01C bin file (Stg 2 E85) and these tables are not present. There's a lot of talk about what to do/not to do to add these using definition files from romraider, github, etc...
Can Shiv or someone else confirm what is needed to get these two tables in the v2.06 A01C bin file? Thanks!
Update: i tried adding the text listed earlier in this thread, without any success.
It seems that there is another section in the definition file that is required, as the text (in the blue image) is added to the file, but the new tables do not show up in RomRaider. The text (in the red image) is present for all other tables, so it seems this is also required for the tables to appear.
Does anyone know this text and can post it here? Thanks.
acj47 is offline   Reply With Quote
Cold start question retrosmiths Scion FR-S / Toyota 86 GT86 General Forum 106 11-15-2016 03:14 PM
Cold weather knocking during start ups. JDMenrique Issues | Warranty | Recalls / TSB 38 01-13-2015 12:53 AM
backfire at cold start FreaQshoQ Scion FR-S / Toyota 86 GT86 General Forum 15 10-16-2013 07:21 AM
White Smoke cold start up in Cold Weather (turbo cars) whitefrs Forced Induction 17 09-25-2013 06:05 PM
Loud cold start and mpg drop since new be6sti Issues | Warranty | Recalls / TSB 7 11-28-2012 02:35 PM
