Old 09-03-2014, 08:32 PM   #43
medina619
medina619's Avatar
Drives: 10 series, MX-5,Mazdaspeed protege
Originally Posted by teamturbo View Post
@medina619
Thanks. Here are a few more...
Just got mine installed
medina619 is offline   Reply With Quote
The Following User Says Thank You to medina619 For This Useful Post:
teamturbo (09-07-2014)
Old 09-07-2014, 02:06 AM   #44
teamturbo
teamturbo's Avatar
@medina619 How do you like them compared to the Sportlines you had? Looks clean BTW
teamturbo is offline   Reply With Quote
Old 09-07-2014, 02:54 AM   #45
medina619
medina619's Avatar
i absolutely love the Prokit it gives you a balance of looks and better handling, The ride is much smoother over the sportlines. I would cringe when going over a bumpy road with the sport lines the ride was really harsh. The Prokit takes bumps well and IMO provide better performance.
Old 09-11-2014, 02:36 PM   #46
jflogerzi
jflogerzi's Avatar
Here is my car on the Pro Sport springs, 17x7.5 et48 and 225 sized tires.
Old 09-11-2014, 03:18 PM   #47
GotBRZ1691
GotBRZ1691's Avatar
Drives: 2014 Subaru BRZ Limited 6smt
I have a few questions for all those with the pro sport springs. I am not as well versed in suspension and wheels as i am engine so hopefully not total noob sounding here but anyways:
1.) how is the ride quality. Honest feed back! I really want to lower my car a tad but will be doing 6 hour drives every other Friday, so that is why I am concerned
2.) I will be on stock wheels / tires until it comes time for new rubber. Camber bolts are not necessary with these springs, correct? but if I plan on a wheels / tire upgrade down the line should I get and install camber bolts while doing the springs? or wait?
3.) lastly, How would you rate a spring swap in terms of difficulty? I have a fair amount of mechanical skills and have replaced head gaskets ( volvo 240, 850r, impreza 2.5i), replaced exhaust systems and intakes, and such
For power mods, I will be getting a header and an OFT (if this needs to be considered)
Thanks guys!
GotBRZ1691 is offline   Reply With Quote
Old 09-12-2014, 04:13 AM   #48
ET86
Perfectionist
ET86's Avatar
Drives: 2014 Scion FRS
Thanks guys!
They feel like stock but more refined. They are smoother and less bouncier, the drop is subtle but noticeable.
ET86 is offline   Reply With Quote
The Following User Says Thank You to ET86 For This Useful Post:
GotBRZ1691 (09-12-2014)
Old 09-12-2014, 04:32 AM   #49
s2d4
s2d4's Avatar
No idea what prosport is.
The Following User Says Thank You to s2d4 For This Useful Post:
JARE_ee (11-06-2014)
Old 09-12-2014, 04:56 AM   #50
asdf
Loading...████████] 99%
asdf's Avatar
Drives: #0517
Thanks guys!
If you read this very thread, questions 1 and 2 will be answered.
3. it is a fairly simple task that may take longer than anticipated if you do not have the right tools. For a spring install, a spring compressor will be a great help. You can definitely do it w/o one but it makes it easier to remove the spring/shock from the car and to take it apart. Plus you can rent the tool from your local autoparts store for a deposit and get a full refund when you bring it back.
asdf is offline   Reply With Quote
Old 09-12-2014, 09:57 AM   #51
GotBRZ1691
GotBRZ1691's Avatar
3. it is a fairly simple task that may take longer than anticipated if you do not have the right tools. For a spring install, a spring compressor will be a great help. You can definitely do it w/o one but it makes it easier to remove the spring/shock from the car and to take it apart. Plus you can't rent the tool from your local autoparts store for a deposit and get a full refund when you bring it back.
1. was answered by only a few and I wanted to hear more because there is always someone to the contrary and I want to hear why his opinion is.
2. All that is said is that they are not needed. But if i'm taking the car apart anyways should I do the bolts? or not because I'd just take them out again when I swap rims. Which may be soon than I thought. so again wanted more input
3. can or can't? i have an orielly's autozone and napa 5 mins from where i work so if i can, I will rent one, if I can't ghetto fab C-clamp
Old 09-12-2014, 05:20 PM   #52
asdf
asdf's Avatar
Drives: #0517
a new wheel/tire setup won't require camber adjustment-- if you plan on picking up rear LCAs and something for camber adjustment up front anyways then yeah you'd save some time installing those items at the same time. but again, you don't need it for this setup.
sorry, typo-- you can rent the tool. would definitely make it easier.
if you have never done a spring install before, i'd set aside a few extra hours that day so you don't feel rushed. some other tools that would make the job easier: 1. a breaker bar, 2. a friend to lend a helping hand, 3. a couple of beers to celebrate with
The Following User Says Thank You to asdf For This Useful Post:
Old 09-12-2014, 05:26 PM   #53
GotBRZ1691
GotBRZ1691's Avatar
Got plenty of beers and friends. Now just need some springs
Old 09-12-2014, 05:33 PM   #54
jflogerzi
jflogerzi's Avatar
Honestly the ride is bit worse then stock, but not much. To me its worth it. Get some camber bolts for up front.
Old 09-13-2014, 03:15 PM   #55
MEGA_Tawn
Drives: 2014 Scion Frs
Did you guys use your stock struts?
MEGA_Tawn is offline   Reply With Quote
Old 09-13-2014, 04:16 PM   #56
brz408
Manny
brz408's Avatar
Drives: 13 WRB Brz
I did. I've been on the pro kit for over 6 months and no issues for me.
brz408 is offline   Reply With Quote
FS: Eibach Sportline Springs in AZ AZ BRZ Brakes, Suspension, Chassis 14 02-05-2013 08:27 PM
Scion FR-S Eibach Pro Kit Springs Vonsamhain Brakes, Suspension, Chassis 3 12-14-2012 10:13 PM
GTA FS: Eibach Sportline springs, BNIB l8apexr Canada Classifieds 14 12-05-2012 03:50 PM
alignment with Eibach springs? zooki Suspension | Chassis | Brakes -- Sponsored by 949 Racing 20 09-17-2012 12:34 PM
New Eibach Springs for the BRZ/FT86/FR-S RallySport Direct Suspension | Chassis | Brakes -- Sponsored by 949 Racing 8 07-19-2012 12:05 PM
