Old 08-14-2014, 06:28 AM   #1
dhoeze
Drives: Toyota 86
Trd Alloy Wheels: will it fit???
Good day gurus,
I just want to inquire if the TrD alloy wheels with spec 18x7.5 +35 clear my 4pot front 2 pot rear brembo brakes???
much appreciate all your assistance
dhoeze is offline   Reply With Quote
Old 08-14-2014, 06:30 AM   #2
dhoeze
Drives: Toyota 86
Here is the link of the wheels
http://www.toyota-parts.com/product/...For-FR-S/-650/
Old 08-14-2014, 06:53 AM   #3
nzer
nzer's Avatar
Drives: 2012 Grey TRD GT86, 2015 VW Golf R
Originally Posted by dhoeze View Post
Only way to tell for sure is to get a fitting template for you to try.
I have the TRD SF2 wheels in 18x7.5 +46 so a higher offset meaning theoretically less calliper clearance and they clear my TRD brembos that are six pot front and four pot rear. But, spoke design may mean the wheels you're looking at have less (or more) clearance.
But, as mentioned, see if they have a fitting template they can email you to print out and put on some card. Just make sure any template has a scale both vertical and horizontal so you can check the printout is the correct size.
nzer is offline   Reply With Quote
Old 08-14-2014, 11:25 AM   #4
JonAvalon
SCBYD0
JonAvalon's Avatar
Drives: 18 BRZ (WRB)
They should fit at the very least. TRD put their brakes on with the same wheels. But like said above get a template to confirm.
JonAvalon is offline   Reply With Quote
Old 08-14-2014, 02:30 PM   #5
dhoeze
Drives: Toyota 86
But what I read is that the pic above is the fr-s rs 1 where they customed created a 8.5 and 9.5 wheel.. That's why it cleared the Trd 6pot 4pot brakes....
Old 08-14-2014, 02:31 PM   #6
dhoeze
Drives: Toyota 86
I am from the PI, so the lact of fitting time is my challenge prior shipping
Old 08-14-2014, 02:33 PM   #7
dhoeze
Drives: Toyota 86
Super thanks in your replies
Old 08-14-2014, 04:39 PM   #8
nzer
nzer's Avatar
Your wheels will poke 14mm less than mine with my spacers in so worst case you might need to run a 10mm spacer.
The templates are easy to use if you can get hold of one.
Old 08-14-2014, 09:59 PM   #9
JonAvalon
SCBYD0
JonAvalon's Avatar
Well if this helps, they did the 7.5's all around with the big brake at the front (stock at rear) for the celeb race.
http://www.ft86club.com/forums/showp...6&postcount=31
Old 08-15-2014, 01:16 AM   #10
dhoeze
Drives: Toyota 86
Wow!!! Spot on sir.perfect.so looks like it will clear the bbks... Hope they are ok with square 7.5
Old 08-15-2014, 07:56 PM   #11
dhoeze
Drives: Toyota 86
Thanks jonavalon and nzer
The Following 2 Users Say Thank You to dhoeze For This Useful Post:
JonAvalon (08-15-2014), nzer (08-16-2014)
Old 08-15-2014, 11:31 PM   #12
btoast
I really dig these wheels and I have BRZ!.
btoast is offline   Reply With Quote
Old 08-16-2014, 12:12 AM   #13
nzer
nzer's Avatar
You could always change the centre cap to a Subaru one or STi
Old 08-16-2014, 12:54 AM   #14
btoast
Yeah. As funny as I think it would look, as my car is not a "Toyota," I would probably leave the TRD caps as they are TRD wheels. Anyone that gives me shit over it probably does not realize how intertwined Subaru and Toyota are in this car. Hell, I'm running TRD springs on my car right now
I don't plan on getting wheels for a while (I just got spacers to hold me over), but these in 18x7.5 square are on my short list. I also really like the STI wheels but was saddened to see they are 17" here in the US. The cost to get the 18" versions from Japanparts is too much to be justifiable. ASGA Spirits might be the way to go in that instance.
? about magnesium alloy parts radroach Cosmetic Modification (Interior/Exterior/Lighting) 0 07-22-2013 11:56 AM
Blowout Sale $270 set Alloy Wheels 17"-19" Drag Concept Tubano-shop Wheels and Tires 0 06-14-2013 01:45 AM
WTB: OEM 16" wheels/tires or similar 16" skinny alloy wheels (USA, CA) smmmurf Wheels and Tires 0 04-05-2013 01:42 PM
What socket size and what torque amount for stock alloy wheels? Takeshi Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 11-01-2012 11:25 PM
Alloy wheels (http://www.tirerack.com/wheels/) Loki556 AUSTRALIA 8 08-22-2012 11:13 PM
