Old 08-11-2014, 09:41 PM   #1
lfgrdwill
Headlights - Bright Enough?
What do you guys think of the headlights? Are they too dim? I know of the manual adjustment feature.
I would be coming from a 2006 civic with HIDs added myself.
lfgrdwill is offline   Reply With Quote
Old 08-11-2014, 10:11 PM   #2
cnk
Drives: '13 DGM BRZ Limited
I think they're fine. However, if you are coming from a civic that just had the regular reflector housings with a HID lamp kit, then you may think that the lights aren't as bright. I say this because a reflector housing shoots light all over the place while a projector housing has a distinct cut off so as to not blind oncoming traffic.
I had 5000K HID's in a projector housing on my 02 WRX and the BRZ lights are just as bright.
Old 08-11-2014, 10:30 PM   #3
mike the snake
I find the low beams to be too low. They cut off abruptly, and do so too close to the front of the car. Basically they don't shoot light out far enough.
I found that I could raise the lights slightly by loosening the top screw that holds the headlight on, and lifting the light, and while holding the light up and tightening the screws the lights adjustment stayed higher. Much more acceptable.
Old 08-11-2014, 10:34 PM   #4
Cope52
Drives: 2014 BRZ
^^ did you spin the dial up on the dash?
Cope52 is offline   Reply With Quote
The Following User Says Thank You to Cope52 For This Useful Post:
JohnJuan (08-13-2014)
Old 08-11-2014, 10:47 PM   #5
Majik
Majik's Avatar
Drives: '14 Subaru BRZ SWP Limited
This
Majik is offline   Reply With Quote
Old 08-11-2014, 10:50 PM   #6
krayzie
Drive From Home
krayzie's Avatar
Drives: BRZ STI Performance
A good set of headlights have to offer good contrast so you can see different objects properly, brighter doesn't necessarily mean better.
Fitting a cheap ricer HID kit in a halogen housing is illegal and just retarded by blinding on-coming traffic.
krayzie is offline   Reply With Quote
The Following 3 Users Say Thank You to krayzie For This Useful Post:
Akari (08-12-2014), ToyoburuBRZ (08-13-2014), ZionsWrath (08-11-2014)
Old 08-11-2014, 10:51 PM   #7
ZionsWrath
Thanks
ZionsWrath's Avatar
I have mine set to the highest setting. At times I feel they are too low but the majority of roads I drive have lighting so it's not an issue for me.
Old 08-11-2014, 10:58 PM   #8
Formula Vee
Lando.Ricciardo.Hamilton.
Formula Vee's Avatar
Drives: 2014 SWP BRZ Limited (MT)
They're absolutely fine. I've owned cars with regular halogen headlights most of my life, and those were fine too.
OFT Stage 1 -- Grimmspeed Strut Tower Bar -- Perrin Inlet Tube -- K&N Engine Filter
Formula Vee is offline   Reply With Quote
Old 08-11-2014, 11:51 PM   #9
HeadBanger
HeadBanger's Avatar
Bright enough?
Hell yes!
This is my first vehicle with HIDs - First with projectors even. I'm not too fond of the way the light just cuts out, but I'm getting used to it.
Life's too short to drive a boring car
HeadBanger is offline   Reply With Quote
Old 08-12-2014, 12:13 AM   #10
ayilar
Drives: BRZ, MB C350
Indeed. On my C350, the bi-xenons' illumination of the road is good with normal beams but truly like daylight if I can turn on the high beams: they are _that_ good. The BRZ's xenons are nowhere close. Love my BRZ but not its headlights.
2013 BRZ Premium MT (lightning red)
2008 MB C350 PII (steel grey)
ayilar is offline   Reply With Quote
Old 08-12-2014, 03:49 PM   #11
mike the snake
Yes, I did adjust the headlights up via the dial on the dash. The low beams still do not project far enough forward, and cut off too abruptly.
Raising the lights as I did helped a little.
My BRZ lights don't compare to the Xenons on my previous car (BMW 135i).
Old 08-12-2014, 06:59 PM   #12
Akari
Drives: 2013 DGM BRZ
The OEM lights on my BRZ are plenty adequate with a great cut off line. It sounds like a lot of people in this thread are used to crappy headlights that throw light all over the place which is dangerous as hell.
The goal of headlights isn't to throw as much light as high as possible but rather to light up the road in front of you and have a good, solid cut off line. This provides contrast to help you see yet doesn't blind oncoming traffic.
Akari is offline   Reply With Quote
Old 08-12-2014, 07:03 PM   #13
Cope52
Drives: 2014 BRZ
Yeah the sharp cutoff is dangerous. If you go down hill for a bit you literally can't see anything until the nose of the car comes up again. I have to drive with my high beams on just to see deer. Every halogen on all my previous cars were better. And the horn wouldn't scare a racoon.
Originally Posted by LeeMaster View Post
I cannot stress this enough, when I changed my rear differential fluid with Motul 300, my clutch engagement point felt smoother.
Old 08-12-2014, 09:49 PM   #14
HeadBanger
HeadBanger's Avatar
I live in the country.
When I say country, I mean bum-fuck-nowhere. You can't always have your high beams on. I feel the beam doesn't go far enough forward, and then the high beams seem to never end.
I guess that in my opinion the headlights are a little too focused. I came over from a '91 Civic wagon. Those lights sucked (was probably just my bulbs that are due), but it's as if I prefer them since they spread what little light they emit better.
I drive with my lights set at 1. 0 is the highest setting. The adjustment seems pointless to me if I'm truthful. I've never though "HEY! You know what would be great? If I could only see 3 feet in front of my car!"
Stock HIDs too bright? Sniper2606 Cosmetic Modification (Interior/Exterior/Lighting) 26 01-10-2014 09:00 PM
My car got broken into. Thieves not too bright... hansthegerman Scion FR-S / Toyota 86 GT86 General Forum 17 10-26-2013 06:41 PM
Are Your LED's Bright Enough?? Check This Out! 86_ZN6 Cosmetic Modification (Interior/Exterior/Lighting) 4 09-19-2013 07:31 PM
Super bright headlight modifications AtlasMick Cosmetic Modification (Interior/Exterior/Lighting) 9 04-17-2013 04:17 PM
Bright White LED Headlights and Front Signals ScionFR-S Cosmetic Modification (Interior/Exterior/Lighting) 13 11-12-2012 10:46 PM
