Old 11-11-2012, 11:41 AM   #1
ScionFR-S
ScionFR-S's Avatar
Drives: Raven Scion FR-S
Bright White LED Headlights and Front Signals
soon i will be ordering the JDM clear side marker so that the white led installed there will be able to shine white instead of the orange/amber color of the OEM
these look awesome as do the rear signals that i will be posting later on when it gets darker out tonight, the flasher relay really makes a difference and slows down the flasher timing to a normal pace.
These Match So nicely its perfect!
these are from HID_Powerhouse
"To make it in America you need three things, a smile, a gun, and a plan. If you need to give up one thing, give up the smile. If you need to give something else up, lose the gun. But never, ever, give up your plan."
ScionFR-S is offline   Reply With Quote
Old 11-11-2012, 12:46 PM   #2
boredom.is.me
Custom User Title
boredom.is.me's Avatar
Drives: Asphalt FR-S MT
I thought LEDs weren't go for headlights. How far do your's project.
Old 11-11-2012, 01:20 PM   #3
KI_ZN6
KI_ZN6's Avatar
Thanks ScionFR-S for the photos and purchasing our B-Max Super White front and rear turn signals LEDs.
They look really good with your PlatinumR 6000K HID kit. Enjoy!!!
KI_ZN6 is offline   Reply With Quote
Old 11-11-2012, 04:04 PM   #4
ScionFR-S
ScionFR-S's Avatar
the LEDs arein the front and rear turn signals, they dont project as the HID Headlights do but they do have a decent lighting when just having them on without the headlights. they arent like foglights but they are just as good! the combonation of both the 6000K Platinum HIDs and the Super B Max White LEDs light up the road like no other!
Old 11-11-2012, 09:58 PM   #5
DarkCard
Drives: Asphalt Scion Frs 6MT
where is the flasher relay located? no load resistors?
and what kit?
I'm looking into this for my car
DarkCard is offline   Reply With Quote
Old 11-11-2012, 11:39 PM   #6
rhood168
rhood168's Avatar
Drives: Black Subaru Brz Limited
and what kit?
Right under your steering wheel. Pop your head under and you should see it at the top in the middle.
rhood168 is offline   Reply With Quote
Old 11-12-2012, 04:36 PM   #7
ScionFR-S
ScionFR-S's Avatar
its very very hard to get to, this is no easy task as i really didnt know how to pop out the OEM Signal relay and cracked it in half resulting in two popped fuses and the car not going into gear, signals not working, and gears and gauges not working. be careful and try not to cut up your fingers like me lol be gentle and HAVE PATIENCE.... totally worth it and without the relay for the LEDs , your LEDs will blink 5x the pace and wont look that great
Old 11-12-2012, 04:37 PM   #8
ScionFR-S
ScionFR-S's Avatar
search HID_Powerhouse on the forums and find his signal relay kit, all his stuff is top notch and great quality , highly highly recommend him!
Old 11-12-2012, 05:05 PM   #9
2point0
2point0's Avatar
Drives: '13 BRZ Ltd WRB
Take off the lower part of the dash (under the steering column) then remove the metal plate that's behind that (2 screws). This made it SOOOO much easier to get to that stupid relay.
A long slim flathead through the top of the clip will detach it. Took a few tries, but you can figure out the way it works by looking at the new relay (if it's designed to clip in).
I couldn't even get my big paws in there to remove the harness without taking the whole thing out.
2013 BRZ Limited - SOLD
2008 Forester XT Sports
1967 Mustang Coupe - 289 V8
2point0 is offline   Reply With Quote
Old 11-12-2012, 05:12 PM   #10
SupraLove
Drives: 2007 Toyota Camry LE, 5AT i4
Wow, this is potentially illegal, I believe. Front turn signals must be amber in color where I live, and I think it's that way for nearly all 63 states.
SupraLove is offline   Reply With Quote
Old 11-12-2012, 05:19 PM   #11
akuhei
akuhei's Avatar
Drives: Raven M/T FR-S
I dont know about him, but I got the switch back blinkers that switch to amber color when the turn signal is in use. When not in use, they are white. Ultimately, it leads to being legal. The one I am more concerned about is the side marker, which is also supposed to be amber in a lot of states.
Akuhei's Blog
"Inconceivable"
akuhei is offline   Reply With Quote
Old 11-12-2012, 08:13 PM   #12
PNW FRS
PNW FRS's Avatar
To clarify... when you're running the headlights... the "Turn signal" bulbs are white -- UNTIL -- you turn on the turn signal... then the white light (right or left) turns amber?? If that is the way it works... I want this mod!!
PNW FRS is offline   Reply With Quote
Old 11-12-2012, 08:22 PM   #13
akuhei
akuhei's Avatar
That is correct.
Akuhei's Blog
"Inconceivable"
Old 11-12-2012, 09:46 PM   #14
akuhei
akuhei's Avatar
http://www.ft86club.com/forums/showthread.php?t=20290
These are the ones I bought. They arent perfect (they are big so they barely fit with a little light push), but they are as described. White during normal driving conditions, amber when using the turn signal.
Akuhei's Blog
"Inconceivable"
hid_powerhouse, leds, signals
***Group Buy: FR-S LED Turn Signals (Dual Color, White/Regular, Amber/Turning)*** Vicious LED Groupbuys 293 08-22-2013 05:26 PM
***FR-S/BRZ LED Turn Signals (6K WHITE/AMBER FOR TURNING, NO HYPER FLASHING!)*** Vicious LED Exterior Parts - The Rest 7 11-02-2012 10:05 AM
LED Front Signals with Resistor Flash Correctors DarrenDriven Cosmetic Modification (Interior/Exterior/Lighting) 38 09-20-2012 02:05 PM
Which is easier? FRS front or BRZ headlights? huma Cosmetic Modification (Interior/Exterior/Lighting) 26 06-23-2012 05:00 AM
