#211 |
Corner Junkie
Drives: 13 BRZ, 11 STI, 99 RS
Well, looks like the cat in the manifold is the primary cat.
Found this in another thread (ignore the red arrow): The downstream O2 sensor is immediately after the first cat. The second cat is completely un-monitored. So moving the primary downstream will require extending the second O2. EDIT: Yay! Looks like those stupid little tips are removable. It's a little ricey, but it seems we can replace them with something bigger to fill out the bumper cutouts. |
#212 | |
Drives: 2002 honda civic ex
#213 |
Drives: Clio TCE
I think we could use the room for the 2nd cat for the headers and place the sports cats even more downstream.
I need to see if the pre-cat sensor wire is long enough for the header design I have in mind, it would be a hassel to extend both the cables. I see there is a resonator on the centre section...guess this car really tends to drone. If all the components have flanges how it looks like in that drawing a modular system will be easy to make, with no cut in the stock one. Depending on the room available around the rear diff we could put a Y-pipe where the centre silencer is and use two separate mufflers with longitudinal piping, but that would mean an axle back won't be available. To answer Grip Ronin about the stock system: Design of the header and the sequential cats id because of the gas regulations. The centre silencer (or resonator) is to avoid drone. The rear box is designed to be cheap. The silencer is a not a straight flow one, the pipe ends and inside there are some chambers, then the two pipes start again to reach the endpipes. Is a common design on 4 pots cars with twin exits, for example the VW Golf GTI. |
#214 | |
Corner Junkie
#215 |
Drives: Clio TCE
Yes, that's true, especially with chamber mufflers.
#216 |
Drives: 2006 Subaru LGT
#217 | ||
#218 |
The Mechanic
Drives: Civic Turbo,FR-S
i cant imagine a Helmholtz res not having an effect on performance
#219 |
Rocket Surgeon
Drives: PSM GGA OMG
Imagine harder.
#220 |
The Mechanic
lol it doesn't effect the flow? i mean its offers a passage for the fumes that is just a dead end
#221 |
FWES racer, R FT drifter
Drives: BMW, Chevy, Soon to be FR-S
ok why cant you collect the two exhausts on the right together and the left side together then all 4 just before the cat? wouldnt that increase flow and be less restrictive? and delete the 2nd cat altogether or create a resontating chamber there
EDIT: or would the angles be to sharp? |
#222 | |
Kuruma Otaku
Because titanium. |
#223 |
ok thanks
#224 |
Yes i have a stutter
Drives: 94 Acura Integra
Any one know if RS-R will have a Exhaust coming out (or any other products) for the FR-S or BRZ. I have one of the Exmag's (not the GT2 Version) now and a friend has one on his 06 Evo and i love the sound. Very quiet in low RPM's but sounds great in high.
| Aftermarket battery | speed-wiz | Scion FR-S / Toyota 86 GT86 General Forum | 59 | 08-07-2012 11:23 PM |
| BRZ Aftermarket Sources | brzmaybe | BRZ First-Gen (2012+) — General Topics | 50 | 01-02-2012 09:57 PM |
| Aftermarket wheels? | Levi | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 21 | 12-06-2011 07:19 AM |
| What Aftermarket parts would you like to see for the FT86/FRS | mkivalex | Scion FR-S / Toyota 86 GT86 General Forum | 78 | 11-14-2011 10:50 AM |
