View Poll Results: Have you blown your stock motor with boost?
Yes complete failure needs rebuild 32 5.39%
No been boosting and running strong 188 31.65%
Nope because I am not boosting my motor 374 62.96%
Voters: 594. You may not vote on this poll
Old 07-28-2014, 12:48 PM   #211
Jaden
Road-hole
Drives: 2013 Whiteout FR-S
anyone who's running boost...
I 100% agree. The only way to know that your tune is working is to be able to monitor it while driving with the use of a boost gauge and a wideband.
Anyone running FI without having a wideband is foolish, anyone running a turbo without wideband AND a boost gauge is flirting with disaster.
Jaden
Jaden is offline   Reply With Quote
Old 07-28-2014, 12:57 PM   #212
BRZPDX
Boosted Member
BRZPDX's Avatar
Drives: 2013 SWP BRZ Limited
I'm just running a boost gauge currently, and reading the AFR through the factory O2 sensor with Scanguage II. Although the factory sensors can only see to 12.0 ish to 20.1, won't that range be good enough? I know when I go WoT, it will be at 12.0 for a while, knowing its below that. Cruising, about 14.7 to 14.0, idling/coasting at 20.1 to 19.8.
Are widebands more accurate, or is it better just seeing a wider range of AFR's?
Suzuki Swift GTI '89, Subaru Impreza L '96, Lancer OZ '03, Subaru Impreza WRX '06, Honda CBR600RR Graffiti, Volvo c30 T5 R '11, Subaru BRZ '13, Audi RS4 2007
SUV's: Mercedes Benz R500 '06, Mercedes Benz ML350 '12
BRZPDX is offline   Reply With Quote
Old 07-28-2014, 03:12 PM   #213
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Widebands are more accurate, have more range, and sample quicker than you can sample with a Scanguage II. By the way you should be idling closer to 15:1. I would also worry about how far below 12:1 I was going under WOT.
Old 07-28-2014, 05:04 PM   #214
Cross
It's the Mad Cow
Cross's Avatar
Originally Posted by nelsmar View Post
No one ever opened the block up. The car still ran but it ran very poorly last I heard. My friend now has the engine and we were going to tear it down and see what let loose soon. Its just too damn hot out right now in Phoenix to be doing a detailed tear down. I haven't seen the logs or talked to mike but from talking to @Cross and a mutual friend it sounds like something else may have caused the failure and not the tune. VVT is possible, or about 1,000 other failure points. hah
The codes I got after everything happened all align with the TSB issued regarding the Cam Timing Control basically. PCM Lost control of the cams, tried to regain control and gave the car way to much timing resulting in the heads lifting along with who knows what else.
Since there is no real fix I choose not to go with another FA motor, not that any other would have been better I think these motor's take abuse well but I could not risk running into the same problem again.
I have found myself asking though if there is a way to do a VVTI delete kit to prevent the problem...
I am still at the point I could sell the LS and everything else and put in another FA20 and be back up and running... I just don't know that I would ever trust it.
Old 07-28-2014, 05:06 PM   #215
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Might as well just get a different motor. Removing VVTI is equivalent to castrating it...
The Following User Says Thank You to Sportsguy83 For This Useful Post:
D K (07-29-2014)
Old 07-28-2014, 05:09 PM   #216
Cross
It's the Mad Cow
Cross's Avatar
But if the VVTi is going to cause failures at unknown times like mine then it just becomes a ticking time bomb until they finally make a replacement part that stops the issue from happening.
Old 07-28-2014, 05:17 PM   #217
Sportsguy83
Drives: Limited BRZ
VVTI is an integral system of the car making power, there is no way around it to "detele it" and it still being a good motor for making power.
Old 07-28-2014, 05:18 PM   #218
Cross
It's the Mad Cow
Cross's Avatar
And there is no real fix for when it fails and when you are boosted this kind of failure is the end of the motor.
I am not disagreeing with you but it's a double edged sword it seems, without it the car has no power. Yet having it there is a TSB for a known problem with it but no real fix.
Old 07-28-2014, 05:21 PM   #219
Sportsguy83
Drives: Limited BRZ
Which validates the point in telling you, it is better to have a different motor than keeping a VVTI-less FA20 to make power.
Also, there is no pattern or lots of failures of motors because of the VVTI. In general, cars that initially had the issue get it fixed at dealer and it never comes back.
It has been very rare for a car to have had no problems with VVTI from the start and develop it later. Your motor is the first one I've actually read it happened.
Old 07-28-2014, 05:25 PM   #220
Cross
It's the Mad Cow
Cross's Avatar
I found someone else while searching the forums here, I will see if I can find it again.
My issue is those that had it fixed there was no real parts replacement I was told by the tech so I could face the problem again and being boost when that happens it will result in the same problem if not worse should it happen while I am racing and not just driving normally.
If I could trust the FA20 I would just put in another and shrug it off as a fluke as I seem to face many strange situations. But at this point I do not know that I can.
Old 07-28-2014, 06:25 PM   #221
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
What is this VVTi problem? Im assuming it sounds like VTEC gone bad
Old 07-28-2014, 06:40 PM   #222
fast_dude
Drives: 2014 Scion FRS
If you don't blow your motor your lucky, but evently you will wear the motor out. I will stay away from the boosted application.
2014 Scion FRS- Kw2 suspension, Openflash headers, Openflash tablet, Invidia N1 exhaust, Invidia Overpipe, Nameless catted front pipe, TRD intake, Enkei RPF1s with Hankook RS3 tires, carbon fibre front lip, TRD knockoff spolier, SPC lower control arms.
fast_dude is offline   Reply With Quote
Old 07-28-2014, 06:50 PM   #223
Sportsguy83
Drives: Limited BRZ
Idle dip/CEL issue
Obvious troll post..
Old 07-28-2014, 07:12 PM   #224
s2d4
s2d4's Avatar
Avo knew this a long time ago apparently, there have been changes to the VVTi as evident by change in parts.
How much HP can the stock motor handle? FullTuneZN6 Engine, Exhaust, Transmission 34 11-16-2017 02:22 AM
Full Blown 521hp Stock Motor @ 20psi FullBlown Forced Induction 276 08-31-2016 03:05 AM
FBM 604Hp 472Tq -- Stock Motor Stage 2 Turbo Kit FullBlown Forced Induction 414 07-14-2014 10:52 PM
FRS300 Rebuild Has Begun..Blown Motor to Built Monster FA20Club.com Forced Induction 917 10-20-2013 07:26 AM
Highest HP on stock motor using only 93/94 octane? hmong337 Forced Induction 11 09-09-2013 11:53 AM
