Old 07-25-2014, 01:23 PM   #253
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
Only pre-08 rear calipers require the brackets...so you need to take that extra cost into consideration as well. Also, some brackets may require you to grind the hub carrier a tiny bit. For hassle free install the post-08 caliper are straight bolt on jobs.
Function wise the rear calipers perform the same between both as they have same piston size.
Fizz is offline   Reply With Quote
The Following User Says Thank You to Fizz For This Useful Post:
Fr-s.h (07-25-2014)
Old 07-25-2014, 01:25 PM   #254
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
Originally Posted by JasperNoone View Post
Pads are the same, rear calipers & rear rotors are different.
Incorrect. Rear rotors are the same regardless of whether you choose pre or post 08 calipers.
Fr-s.h (07-25-2014)
Old 07-25-2014, 02:08 PM   #255
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
I think he meant that the 04-07s STIs use a different rotor than the 08-13 STIs. You HAVE to use the 08-13 STI rear rotor regardless of what year caliper you purchase.
Fr-s.h (07-25-2014)
Old 07-25-2014, 02:19 PM   #256
JasperNoone
Drives: Car
Rear bolt pattern of USDM STI stayed the same, but the rotor hat offset (and obviously the caliper too) DID change to accommodate the new rear geometry.
JasperNoone is offline   Reply With Quote
The Following User Says Thank You to JasperNoone For This Useful Post:
Fr-s.h (07-25-2014)
Old 07-25-2014, 02:24 PM   #257
King Tut
NASA SpecE30 Racer
King Tut's Avatar
How do you know so much with being a relative n00b to this site? You must be a long time NASIOC poster or something. @ftc~brz
Old 07-25-2014, 04:30 PM   #258
JasperNoone
Drives: Car
Forum post count is not everything. I really like brakes.
Old 07-25-2014, 10:31 PM   #259
Fr-s.h
Drives: Golden White
Really appreciate you guys clearing things up. Think im going to hold off for a set of post -08 calipers. Thanks.
`13 Whiteout Fr-s.h
Fr-s.h is offline   Reply With Quote
Old 07-27-2014, 09:57 AM   #260
fooyc
fooyc's Avatar
Drives: GT86-JDM
ya. those gold sti caliper r the same for v7 to v9 sti. only diff r v9 hv a PCD114.3. Fornt caliper is PnP w/ the caliper & standard size of STI rotor.
Rear is abit tricky. U need a bracket to mount this gold caliper. I got it made from local machine shop. then the pc metal behind of the rotor u to cut abit so it will not touch the STI rotor later u will put in. Also if u put in the sti rotor for the rear u need to drill a small whole on the rotor hub for u to adjust the handbrake later. see ur stock 86/brz rotor....
fooyc is offline   Reply With Quote
The Following User Says Thank You to fooyc For This Useful Post:
Fr-s.h (07-28-2014)
Old 07-27-2014, 12:54 PM   #261
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
Or you could just get the DBA rear rotor part number 42656-10 which already comes dual drilled plus e-brake service hole.
If you get the DBA front rotor part number 4654-10 it would also be dual drilled so you won't need to worry which version rotors to look out for.
The Following 2 Users Say Thank You to Fizz For This Useful Post:
fooyc (07-29-2014), Fr-s.h (07-28-2014)
Old 10-28-2014, 03:44 AM   #262
slava
slava's Avatar
Drives: brZed
Planning on doing the 08-12 Brembo calipers front and rear over the winter. Had a question about hubs though. I'll be converting to 5x114 at the same time and would rather use all Subaru parts if I could. Do STI hubs also swap right over, front and rear? Thanks.
slava is offline   Reply With Quote
Old 10-28-2014, 11:06 AM   #263
King Tut
NASA SpecE30 Racer
King Tut's Avatar
I would think that just like the brakes that any STI front hub and the 08-12 STI rear hubs should swap over.
slava (10-28-2014)
Old 04-08-2015, 07:15 AM   #264
gtishtar
Drives: 86
Originally Posted by fooyc View Post
Over here the ver10 sti black brembo is hard to get. so I just plug in the older ver STI gold color brembo.
hello..sir
is the project mu rotor you installed at rear? do you have the part number? also the front rotor too. tks in advance
gtishtar is offline   Reply With Quote
Old 04-09-2015, 12:02 AM   #265
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
Just look for rotors that will fit on any Brembo equipped Subaru vehicles.
This might help too: http://www.project-mu.co.jp/matching...R_matching.pdf
Old 04-09-2015, 08:24 AM   #266
AZP Installs
AZP Installs's Avatar
Drives: '11 STi->'14 BRZ | '14 Touareg TDi
Send a message via AIM to AZP Installs
Not any brembos actually. Most of the brembo equipped Subarus are 5x114 (except the 2004 STi) so if you just bought rotors for a brembo equipped car they won't bolt onto your hubs.
-mike
AZP Installs is offline   Reply With Quote
The Following User Says Thank You to AZP Installs For This Useful Post:
chanomatik (04-09-2015)
brakes, caliper, sti, swap
STI front brakes on BRZ (confirm) michael317 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 123 05-23-2016 01:41 PM
GTS Front Brakes + Rotors + Pads GC GTS Aero Kit Australia Classifieds 2 11-16-2012 06:20 AM
R35 Brembo Brakes - Full set 2013GTRNate Suspension | Chassis | Brakes -- Sponsored by 949 Racing 8 10-06-2012 11:08 AM
