#1401 | |
Drives: 2013 Asphalt 6spd
... After I look up/research about half those words
#1402 | |
Drives: Silver Premium Edition BRZ
I am 99.999% certain I could rev all the way to red line on the Stage 1 tune as long as I was in neutral and had my foot off the clutch. Shortly after the tune I was at the DFW Cars & Coffee and first discovered the LC limit when rolling in first with the clutch in. |
#1403 | |
Drives: FT86
FFS limit active when clutch depressed LC limit active (if set) if car doing less than the LC disable speed regardless of clutch or gear selection. the LC limit is definitly active at a standstill with a gear selected thats the whole point of LC :-) |
#1404 |
Daesondei
Drives: Scion FRS
??? since when did tuning or modifying a vehicle become a gimmick? increased horsepower and drivability is something all ft86 owners can benefit from. I promise if you test drive someones car with an e85 tune then, you will understand...
Sent from my SAMSUNG-SGH-I577 using Tapatalk 2
"No greater love is this, than a man laying down his life for his friends... I call you friends."
#1405 | |
Drives: FT86
| The Following User Says Thank You to steve99 For This Useful Post: | Trettiosjuan (07-09-2014) |
#1406 |
Drives: 2013 Scion FRS in white out
So quick question...anyone running a vortech sc with the OFT OTS map...if so how is it? I'm starting to look at the vortech SC since I already have OFT. Just wondering what kind of numbers people are pulling?
#1407 | |
Daesondei
Drives: Scion FRS
| The Following 2 Users Say Thank You to Daesondei For This Useful Post: | steve99 (07-09-2014), Trettiosjuan (07-09-2014) |
#1408 |
Drives: '22 BRZ
Took a look through a lot of the tables out of sheer boredom waiting for my OFT... It's very different than what I'm used to (MegaSquirt), heh.
I noticed something that seems slightly odd in the idle speed tables of what seems to be every map in the 1.59 maps. Is there a reason that the 140* column is a higher idle target than the 122* column? Heck, I don't even know when this idle table is used... |
#1409 | |
Drives: FT86
![]() Imagine they just copy/paste data to maps, pretty sure the 700c 900C A00C A01C maps the same just the calid changes and they are all actually based on A01c calibration. Then they just alter the calid so the oft will load the map corresponding to your calid as the OFT will only load a map with matching calid. In this way the guys on older calid's actually update to latest calid even though the calid shown in map is the original. |
#1410 |
Drives: '22 BRZ
hmm. I guess it takes a while for the ECU to re-learn the throttle pedal? First 1/4" at least literally does nothing, doesn't even register. Torque dip is massively reduced and the powerband definitely feels smoother.
I'm a bit less than satisfied (a bit of an understatement, to be honest) with the quality of the OFT and cables, but I guess we're paying more for the programming than anything else. |
#1411 |
Spline Reticulator
Drives: 2013 FR-S Whiteout
@DocWalt That is normal for the throttle. I had the same thing when I reset my ecu for an intake change.
Johnny was a chemist's son, but Johnny is no more. What he thought was H2O was H2SO4. ![]() |
| The Following User Says Thank You to Semprini For This Useful Post: | DocWalt (07-12-2014) |
#1412 | |
Yep. Both my Stage 1 and Stage 2 tunes had this for a short while. Almost stalled pulling away from stops the first little while. |
| The Following User Says Thank You to Wankel Rex For This Useful Post: | DocWalt (07-12-2014) |
#1413 |
Drives: '22 BRZ
Figured. Didn't go away with ~10 minutes of tooling around, so I was slightly concerned. Any idea how long it takes to go back to normal?
#1414 | |
Drives: '13 DGM BRZ Limited
Sent from my Transformer using Tapatalk |
| Tags |
| #lolwut, divinecomedy, dopeandcashcabinet, free shiv now, goddamitimissedit, golden cage, i missed the show, looks good, missed the fun, omgbbq, shiv 2016, thefatandthefurriest |
| Tablet on the dash ! | TRD_86 | Electronics | Audio | NAV | Infotainment | 23 | 05-16-2015 03:48 AM |
| Tablet Install | ThugNasty | Electronics | Audio | NAV | Infotainment | 4 | 04-13-2013 03:15 PM |
| Blutooth OBD II and a 9.7 tablet.. | Scooby South | Electronics | Audio | NAV | Infotainment | 10 | 12-16-2012 08:11 PM |
| 7.0 Tablet w/ Torque App | Thatruth2001 | Northwest | 26 | 11-21-2012 11:53 AM |
