Old 06-13-2014, 06:07 AM   #57
s2d4
s2d4's Avatar
Originally Posted by DeliciousTuning View Post
7. You have an automatic transmission?
- Supercharger
Why?
Old 06-13-2014, 06:40 AM   #58
Calum
That Guy
Drives: 2013 asphalt FRS MT
Originally Posted by s2d4 View Post
Why?
The rpm range that they operate at during normal driving. Unless you use a very small turbo you'll be a long way from boost when you try to get on it.
Old 06-13-2014, 08:02 AM   #59
FR-S Matt
Or you can just sell your car and buy a 5.0 if you want a good V8.
Old 06-13-2014, 09:25 AM   #60
s2d4
s2d4's Avatar
Changing gears is extremely fast, only morons try to jump on it way below the boost threshold, it ain't a V8 so don't drive it like one?
Old 06-13-2014, 10:46 AM   #61
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Questions to help determine what you might want.
1. Do you daily drive the car and use to big V8 torque and response?
- Turbo
2. Do you plan on going to the drag or track with your setup?
- Turbo
3. Are you worried about smog and being CARB legal?
- He is Canadian, Turbo
4. Do you want to continue building the power up in large steps, with basic mod upgrades?
- Turbo
5. Do you want to be able to resell your vehicle easily?
- Turbo, sold my turbo BRZ in 4 days
6. You do not mind being loud, therefore having less back pressure to make power?
- Turbo
- He doesn't, still Turbo
fixt.
The Following 2 Users Say Thank You to King Tut For This Useful Post:
andrew20195 (06-13-2014), cdrazic93 (06-15-2014)
Old 06-13-2014, 10:47 AM   #62
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Originally Posted by glamcem View Post
to the OP, you can always @King Tut if you want to learn what the linear torque is all about
He isn't ready for that conversation yet. He said he wants 300 torques, but I didn't ask him how linear he wants his horsepower curve, haha.
cdrazic93 (06-15-2014), glamcem (06-13-2014)
Old 06-13-2014, 10:54 AM   #63
AJPG
Drives: 22RE, FA20, 4G63
If you use your AT in manual and sport mode there should be no issue with turbo it!
If use it full auto with default mode then (depending on the turbo you chose) lag could be an issue. But if you want to have some fun get a passenger, centrifugal sc and default mode, then hit the throttle (WOT) and you have near max boost as soon as the car change gears, then and only then you would see the thing people talk about instant boost
You could also see that if you let the car at 5k with out use of throttle (like engine braking) follow with WOT, be careful on turns and have tons of fun!
AJPG is offline   Reply With Quote
Old 06-13-2014, 11:16 AM   #64
AJPG
But please don't compare sc (positive pressure or centrifugal) with turbos, is not fair... This is my second sc car, all others turbo from oem to custom made and both are the slowest of all.
As a side note this is the only one I think would make it to 100k before engine repair, is not due to taking care of the car, more that could not rise boost if found some one faster.
Also temps under the hood are better than expected (live in the tropic) oil range 200-220f, coolant 194-210f, sc oil 195f.
Old 06-13-2014, 02:31 PM   #65
Calum
That Guy
Meh, I haven't driven a flappy paddle gear box, I have no idea how the transmission will respond when you tell it to change gears. BUT, the automatics do keep the rpms very low.
Old 06-13-2014, 02:39 PM   #66
J_kennington
Drives: 2013 asphalt scion FRS
Car responds near instantly to manual downshift inputs. And the only time it keeps the rpms low...is in full auto with no sport mode. Even full auto with sport mode engaged, it will stay in the powerband for quite awhile before shifting up.
But, none of that matters. OP has a manual...
2013 raven frs(dd/grocery getter)
1990 mitsu eclipse gsx(street/strip car)
1995 gmc 1500 4x4(off road toy)
2005 Yamaha yz250f
J_kennington is offline   Reply With Quote
Old 06-13-2014, 03:16 PM   #67
D K
Stig's dark passenger
If you want to make crazy dyno numbers - Turbocharger
If you want to drive only one lap at a time - Turbocharger
If you want to melt everything in your engine bay - Turbocharger
If you want to make reliable, usable power - Supercharger
If you want to track all day, many sessions - Supercharger
If you want engine that feels like stock, but much moar powerful - Supercharger
D K is offline   Reply With Quote
The Following User Says Thank You to D K For This Useful Post:
CSG Mike (06-13-2014)
Old 06-13-2014, 04:07 PM   #68
King Tut
NASA SpecE30 Racer
King Tut's Avatar
If you want to melt everything in your engine bay - Visconti/Accelerated
If you want to make reliable, usable power - Turbocharger
If you want to track all day, many sessions - Turbocharger
If you want engine that feels like stock, with not much torque, but slightly moar powerful - Supercharger
fixt again.
The Following 4 Users Say Thank You to King Tut For This Useful Post:
andrew20195 (06-13-2014), Cross (06-17-2014), D K (06-13-2014), Fear (06-14-2014)
Old 06-13-2014, 05:18 PM   #69
glamcem
glamcem's Avatar
Drives: 2022 BRZ Limited
fixt again.
How often did you track your TCed BRZ? Have you datalogged?
This is a serious question because in my previous turbo cars (OEM turbo) heatsoak and transient response were my problems (inconsistent power delivery too since turbos are more temperamental) ...I am just curious I just want to know what kind of temps and experience people have since I don't see many people share their opinions on tracked TCed BRZ/FRS
I am really curious how a big turbo in the engine bay is not causing any heat issues.. Do people really push their cars at the track?
glamcem is offline   Reply With Quote
Old 06-13-2014, 05:22 PM   #70
King Tut
NASA SpecE30 Racer
King Tut's Avatar
I didn't track mine at all, but I am 100% confident that I would have worked on it till it did five 20 minute sessions a day no problem. Is a supercharger the easier solution, yes. Is a C5 Z06 an even easier solution, yes.
Installing a Turbo Kit + other mods chiefshayan Forced Induction 21 01-22-2014 11:58 PM
Unnecessary Boost needed (Turbo or Supercharge) Nickse30 Forced Induction 32 05-27-2013 01:57 PM
turbo kit supporting mods lbroskee Forced Induction 13 03-30-2013 09:56 PM
NA engine mods for turbo money? subatoy Engine, Exhaust, Transmission 62 11-28-2012 05:32 PM
if going FI, would you turbocharge or supercharge? tibsy92 AUSTRALIA 35 08-18-2012 11:02 PM
