| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
#43 |
Drives: 2013 FRS Asphalt
I have broke two stock studs myself. Both drivers side front. Even @Guff broke two or 3 and he is completely stock. I keep extras in stock now. I torque down to 89
2013 Scion FR-S AT Picked up 5/30/2012
| The Following User Says Thank You to feldy For This Useful Post: | Guff (06-14-2014) |
#44 | |
In all seriousness, I have also broken a few studs on this and previously owned Subarus. I try to keep at least 2 extra studs in my garage now.What I'm thinking happened (along with a few others in this thread) is the open ended nuts allowed rust to form on the stud where the nut threads weren't making contact with the stud threads. When you backed the nut off, it got caught in this rust and then "welded" the nut to the stud, forcing you to break the nut and stud off. Keep your threads clean and this shouldn't happen. Also try to switch to closed nuts. |
#45 |
Drives: 2013 Subaru BRZ
are you putting them on crooked?
you should be able to spin them on by hand all the way until they hit the wheel, then you snug them up with a 1/2" ratchet and then torque in sequence to 80ftlbs edit: or 75ftlbs, or 90ftlbs, or whatever you want to believe. I can't believe that you broke 4 studs in such a short time and there's not some element of user error here.
1jz salvaged brz build thread brought to you by visconti tuning --> Pipe dreams and poor life choices
#46 |
Drives: Whiteout FRS, Audi A4, 135i (sold)
I had a stud shear off yesterday. Apparently the tuner lugs were loose though, so that may have been the cause.
boooooooooooooooooost
#47 |
Both times my lugs broke was with the factory lugs.
#48 | |
There are now 2 carseats!
Drives: 2013 DGM BRZ
Why are you using open ended lug nuts? |
#49 |
Drives: Diesel daily / FR-S
#50 |
I'm using the same lugs on ARP lengthened studs without antiseize and haven't had any problems. My wheels are off every couple weeks at least, though.
#51 |
#52 |
Drives: 2005 Toyota Camry
ARP studs.
Track events once a month or more. Wheels swapped out about 2x per month. Open-ended lug nuts. A few long roadtrips across California and other places. Every time I change wheels, I wipe the studs clean. Been doing this since my S13 days, when I did the same thing every time I changed my wheels out (Nismo extended studs). No issues with my ARP studs after about 6 months. Close to 10k miles on the car in that timeframe. -alex |
#53 |
Just a few autoxes since the studs were installed. 245 race tires.
#54 | |
Should buy a new torque wrench too... I'm still wondering if I should be looking into better quality lugs. |
#55 | |
Also, half of the time I'm taking the wheels off the car is hot after autox. Not sure if it makes a difference.
#56 | |
My sequence is: Break lugs free with breaker bar Change wheels Hand thread lugs on at least 3-5 turns Impact gun to tighten (less than 60 ft-lbs torque) Torque wrench to finish I clean the studs about every 2-4 weeks, or whenever the wheels come off. Use anti-sieze with caution, as it tends to collect contaminates and make the threads dirtier. Also: cheap lugs often have coating on them that are also on the inside. They collect on the threads. I guess I should add a +1 for ARP studs: I have KICS R40 lugs, and earlier this year I managed to almost cross-thread all 5 studs on the same corner because the wheels weren't torqued 100%. The lugs ended up being junk, however the ARP studs were fine and held up okay. -alex |
| MAX Spacer thickness for stock studs? | FRSpdDmn | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 21 | 06-09-2016 02:02 PM |
| HELP! Lug nut and wheel stud stripped! | jaydee_do_work | Scion FR-S / Toyota 86 GT86 General Forum | 17 | 07-26-2015 02:50 PM |
| spacers and stock studs | abutterman | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 9 | 07-17-2013 11:55 PM |
| Extended studs with stock setup | eckoflyte | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 13 | 05-10-2013 10:13 AM |
| flush with stock wheels. with Stud installation. | adamturbo | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 43 | 12-10-2012 05:30 AM |
