Old 06-07-2014, 09:33 PM   #15
sshole
Don't torque your lug nuts to 89 ft-lbs if you're using anti-seize on the threads. That's how you break studs.
sshole is offline   Reply With Quote
Old 06-07-2014, 09:37 PM   #16
dem00n
Member of the year - 2016
dem00n's Avatar
Drives: Scion FRS
Are you crossthreading?
Squeeze one out before putting the lug nuts on, i know for some guys it's the most irrigating thing on earth.
Could it be the way you're putting the wheel on? The hole for the studs on the wheels can rub up against and cause damage to threads.
That's another good point, what type of torque wrench do you have? Mechanical type? Whens the last time it was recalibrate.
Old 06-07-2014, 10:00 PM   #17
Kostamojen
It was the lack of anti-seize. But if it happens again, its the lugs.
Torque wrench is fine, no damaged threads, no cross threading (hand tightening first as I mentioned), not over or under torqued.
Old 06-07-2014, 10:23 PM   #18
robot
There are now 2 carseats!
Drives: 2013 DGM BRZ
Mcguard lug nuts. Closed ones that seat with a spinning ball bearing seat.
robot is offline   Reply With Quote
Old 06-07-2014, 10:46 PM   #19
sshole
If you put anti-seize on the threads and torqued the nuts to 89 ft-lbs, you're over torqued.
The Following User Says Thank You to sshole For This Useful Post:
FRSpappa (06-08-2014)
Old 06-08-2014, 01:32 AM   #20
FRSpappa
FRSpappa's Avatar
Drives: 2014 FR-S Whiteout
Been in the auto industry for 30yrs, never herd of anti seize on studs...
FRSpappa is offline   Reply With Quote
The Following 4 Users Say Thank You to FRSpappa For This Useful Post:
8R6 (06-11-2014), deliroast (08-30-2014), OICU812 (06-11-2014), Wes (01-02-2015)
Old 06-08-2014, 02:36 AM   #21
Andreas83
Andreas83's Avatar
Drives: 2013 Subaru BRZ
You are absolutely correct.
If a anti-seize compound is applied, the torque value has to be reduced according to the compounds friction coefficient.
I use Molykote G-rapid plus on my wheel studs. We use this stuff offshore on studs all the time.
Andreas83 is offline   Reply With Quote
The Following 2 Users Say Thank You to Andreas83 For This Useful Post:
FRSpappa (06-08-2014), mattbenich (06-11-2014)
Old 06-08-2014, 03:41 AM   #22
Kostamojen
80 with the anti-seize.
The Following User Says Thank You to Kostamojen For This Useful Post:
Old 06-08-2014, 10:56 AM   #23
sshole
That's still higher than I'd be comfortable with.
Old 06-08-2014, 12:06 PM   #24
Kostamojen
Well I don't want the lugs to fall off, and its what a couple of actual RL mechanics not in this thread and have experience with ARP studs recommended, so ya...
Old 06-08-2014, 05:15 PM   #25
sshole
My real life experience with nuclear submarines tells me you're still doing it wrong. So, there's that...
The Following 2 Users Say Thank You to sshole For This Useful Post:
JazzleSAURUS (10-07-2015), SomeoneWhoIsntMe (06-12-2014)
Old 06-08-2014, 05:19 PM   #26
gramicci101
Off Topic
Yeah, but how many times have you had to change the tires on your nuclear submarine??
Uh-huh, that's what I thought...
The Following 2 Users Say Thank You to gramicci101 For This Useful Post:
JazzleSAURUS (10-07-2015), sshole (06-08-2014)
Old 06-08-2014, 09:54 PM   #27
Kostamojen
Its made by Lotus
Old 06-11-2014, 11:09 AM   #28
lightdir
Drives: 2013 Raven FRS 6MT
Those lugs come with a warning no more than 85 ft/lbs or you will damage them
lightdir is offline   Reply With Quote
MAX Spacer thickness for stock studs? FRSpdDmn Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 21 06-09-2016 02:02 PM
HELP! Lug nut and wheel stud stripped! jaydee_do_work Scion FR-S / Toyota 86 GT86 General Forum 17 07-26-2015 02:50 PM
spacers and stock studs abutterman Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 9 07-17-2013 11:55 PM
Extended studs with stock setup eckoflyte Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 13 05-10-2013 10:13 AM
flush with stock wheels. with Stud installation. adamturbo Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 43 12-10-2012 05:30 AM
