Old 05-29-2014, 06:18 AM   #1
Harvey
Drives: Celica 5th Gen, Tiburon 04, GT86
MiniVCI and Global Techstream
Anyone messing around with GlobalTechStream and the MiniVCI cable? I've got it all setup and done a few GenericOBDII scans on my older car (Nissan), but haven't had the guts yet to plug it into my brand new under garantee GT86... I've heard the dealer can detect it's been plugged up and break the warranty. Anyone know anything about this?
Harvey is offline   Reply With Quote
Old 05-29-2014, 08:43 AM   #2
Mikem53
Drives: FR-S 6MT
I use the minivci cable with techstream. I have changed options with it and
Used the diagnostics.
The dealer can't detect you using it unless you modify and save ECM code.
There are several options on the car you can modify. A very useful tool.
Mikem53 is offline   Reply With Quote
Old 05-29-2014, 08:46 AM   #3
J_kennington
Drives: 2013 asphalt scion FRS
I have it. Changed my DRL setting, lock/unlock settings, all the annoying alarm settings. It's the same software THEY use. So...I highly doubt they could void your warranty.
2013 raven frs(dd/grocery getter)
1990 mitsu eclipse gsx(street/strip car)
1995 gmc 1500 4x4(off road toy)
2005 Yamaha yz250f
J_kennington is offline   Reply With Quote
Old 05-29-2014, 11:35 AM   #4
Harvey
Thanks guys, well I guess I just have to plug it in now and check for myself... I'd like to turn the daylight leds off, I've seen there's an option for this in the repair manual
Old 05-29-2014, 11:37 AM   #5
J_kennington
Yes, the DRLs can be turned off.
2005 Yamaha yz250f
Old 05-29-2014, 02:34 PM   #6
jebuwh
Village Idiot
jebuwh's Avatar
Drives: '13 FR-S Ultramarine Manual
Does anyone have access to one here in socal? I would love to be able to turn those off.
jebuwh is offline   Reply With Quote
Old 05-29-2014, 02:47 PM   #7
Mikem53
Drives: FR-S 6MT
U can ask your dealer.. Some will do it for free.. I called an asked a local
Dealer here and they wanted 75 dollars to change the options.
So I bought the cable for $30 and DL the software here for free..
Installed on my win7 laptop and made the changes. It also has diagnostic functions and allows you to monitor the system temperatures and other operating specs. Very useful tool.
The Following 2 Users Say Thank You to Mikem53 For This Useful Post:
73TORANA! (06-04-2014), jebuwh (05-29-2014)
Old 05-29-2014, 03:34 PM   #8
J_kennington
Exactly why I purchased mine. Some people have even lucky and their dealer did it for free. Mine wanted to charge and say they couldn't turn off certain features due to safety.
2005 Yamaha yz250f
Old 05-29-2014, 04:01 PM   #9
phobos512
phobos512's Avatar
Drives: 2014 FR-S 6MT Whiteout
Which cable do you guys recommend?
Matt | '14 FR-S 6MT Whiteout | '13 Sonata Hybrid | '11 CBR1000RR
phobos512 is offline   Reply With Quote
Old 05-29-2014, 04:13 PM   #10
Harvey
Here's the one I've got.... nice thing is that it comes with the drivers and the GTS software, so you're all set to go:
http://www.ebay.com/itm/201078107255...R:3160&vxp=mtr
Old 05-29-2014, 04:36 PM   #11
J_kennington
I got mine from amazon. Actually came with drivers and the techstream copy for 30 bucks. But...I won't recommend it to anyone, for the simple fact the drivers are for XP. And it was a PITA to work around it to install on W7
2005 Yamaha yz250f
Old 05-29-2014, 11:50 PM   #12
HRTROB
HRTROB's Avatar
Drives: Toyota 86
In my 86 (not sure if it's JDM or European spec) there is no option to turn off the DRL LEDs in Techstream.
But you can do so manually by pulling out the DRL relay in the fuse box under the hood. DRL will no longer function, but the LED strip will still light up when you have your parking lights or headlights on. Just pop the relay back in if you want it to work again.
HRTROB is offline   Reply With Quote
Old 05-29-2014, 11:54 PM   #13
DarkCard
Drives: Asphalt Scion Frs 6MT
If only you could turn off the tpms.
DarkCard is offline   Reply With Quote
Old 05-30-2014, 04:32 AM   #14
Harvey
TPMS is an interisting one.... it seems to be a standard in USA FRS and not available at all in GT86 europe, whereas for most other things the european version seems to have more standard equipment (electric fold mirrors, auto headlights, dual A/C, plastic underpanels, trunc trim, .... but is much higher priced, but therefore less noobs with them, so I don't think we'll get the Honda Civic symptom you're on about in the US)
TechStream TIS - No work FRSFirestorm Engine, Exhaust, Transmission 19 07-10-2014 03:14 AM
Techstream/ECU customizations phanguy Northern California 60 10-05-2013 11:12 PM
techstream spitfire481 Mid-Atlantic 0 09-14-2013 09:37 PM
Toyota Techstream on BRZ? pinoy_dorifto Engine, Exhaust, Transmission 6 05-15-2013 11:56 AM
Techstream ECU Options mrjester Electronics | Audio | NAV | Infotainment 10 03-18-2013 10:24 AM
