Old 05-16-2014, 01:46 PM   #113
RehabJeff86
RehabJeff86's Avatar
Drives: 2013 WhiteOut FR-S
Originally Posted by ddeflyer View Post
When you had the seals fail do you think it was just the ambient temperature pushed things too hot? If that is the plausible cause do you suspect and oil cooler would have helped prevent it?
Yes that would be the only reason i could think of, my car was bone stock at the time except MXP exhaust
After a long research on what causes DI failure, no one knows lol but i concluded a software tune and oil cooler are the best bet to prevent DI failure again
Sent from my iPhone using TapatalkfQ
2013 Scion FR-S whiteout
2012 Porsche Panamera S carbon grey
2008 Range Rover Sport SS black - sold
2004 BMW M3 alpine wies - sold
RehabJeff86 is offline   Reply With Quote
Old 05-16-2014, 02:08 PM   #114
SirBrass
Trust me, I'm the Doctor
SirBrass's Avatar
The car's biggest advantage is its stability at 80+, IMO.
High spring rates =/= upset chassis. The suspension's job is to absorb the road and maximize contact, not make the chassis move in accordance to every flaw on the driving surface. It all comes down to the damper.
Okay, and how do the dampers interact with the springs? I know what each does individually, but I'm not so clear on how their interaction affects handling.
^GT5 Replay Photo Mode^
Old 05-16-2014, 02:20 PM   #115
CSG Mike
CSG Mike's Avatar
Dampers "give" when needed, and "push back" when needed.
Ever been on a kart over a rough surface? It's painful; everything is transmitted directly toward the chassis. Now imagine if you can go over that same rough surface, but to the kart's chassis, the surface is smooth. That's what suspension does.
Note how the wheel moves, but the chassis does not. Gopro mounts are not rigid; if the chassis is upset, you'll see it as camera shake.
[ame="https://www.youtube.com/watch?v=NiA_Pq5YVaU"]S2000 Suspension in Action - YouTube[/ame]
[ame="https://www.youtube.com/watch?v=nGBZWkoQO-s"]CSG BRZ Buttonwillow 2:00 lap - YouTube[/ame]
Old 05-16-2014, 02:21 PM   #116
SirBrass
SirBrass's Avatar
Right. I get that. But how do they interact with spring rates?
Old 05-16-2014, 05:07 PM   #117
CSG Mike
CSG Mike's Avatar
I'm not sure I understand what you're asking.
Higher spring rates generally mean you need less compression damping (dynamic spring) and more rebound damping (so the spring doesn't extend too fast). Not enough rebound damping results in weight transitions that "gain momentum" and swing the way across the car too fast, resulting in traction loss.
When you turn in, the outer wheel compresses(compression damping), and the inner wheel extends (rebound damping).
SirBrass (05-16-2014)
Old 05-16-2014, 05:23 PM   #118
SirBrass
SirBrass's Avatar
Ah, okay. That answers my question.
And when you exit the turn, the inner wheel rebounds and the outer wheel compresses.
The Following User Says Thank You to SirBrass For This Useful Post:
CSG Mike (05-16-2014)
Old 05-16-2014, 08:06 PM   #119
Scottemad123
Drives: 2014 SWP BRZ Limited
Well I was going to ask the CSG guys questions about their new packages, but a lot of my questions are getting answered here. Cheers!
Scottemad123 is offline   Reply With Quote
The Following User Says Thank You to Scottemad123 For This Useful Post:
CSG David (05-16-2014)
Old 05-16-2014, 08:18 PM   #120
CSG David
CSG David's Avatar
Don't be afraid to ask!
Old 05-26-2014, 09:09 PM   #121
ddeflyer
So this is primarily aimed at the CSG folks, but if others have an opinion please chime in. Could you tell me about the difference between the "JRZ RS PRO - Double Adjustable Club Sport Damper" and the "JRZ RS - Double Adjustable Twin Tube Damper"? Also, do both of those come with camber plates? I don't think I see an option for them on the raceseng plates.
Fun car leads to autocross, autocross leads to track days, track days lead to lemons, lemons leads to racing school, racing school leads to spec Miata...
No idea where it leads next!
ddeflyer is offline   Reply With Quote
The Following User Says Thank You to ddeflyer For This Useful Post:
RehabJeff86 (05-29-2014)
Old 05-29-2014, 04:40 AM   #122
scioneric
scioneric's Avatar
Drives: Firestorm FR-S
Does Swift Spec R spring over kill our stock shocks with its higher kg/mm?
scioneric is offline   Reply With Quote
Old 05-29-2014, 05:13 AM   #123
CSG Mike
CSG Mike's Avatar
It'll be a bit underdamped on the rebound side, but nothing terrible. Anyone who needs/wants more damping wouldn't be considering the setup to begin with.
scioneric (05-29-2014)
Old 05-29-2014, 10:05 AM   #124
Racecomp Engineering
JRZ RS PRO is a monotube 2 way. JRS RS is a twintube 2 way.
A twintube can be plenty good, but we've tested both and really prefer the RS PRO over the RS. We actually prefer the RS1 monotube 1 way over RS.
Camber plates would be an option for either one.
- Andy
ddeflyer (05-29-2014), RehabJeff86 (05-29-2014)
Old 05-29-2014, 01:32 PM   #125
RehabJeff86
I likey u r looking at some serious stuff!!
The Following User Says Thank You to RehabJeff86 For This Useful Post:
Old 05-29-2014, 02:15 PM   #126
ddeflyer
The pain of spending so much money on the car is significantly reduced after spending $4K+ (maybe 5K? I haven't added it all up since I was also buying stuff like a fire suit for a lemons race at the same time) getting a proper, full safety system (custom weld in roll bar, two fia certified seats, harnesses for both, hans device, mounting stuff, etc.) for the car. Building a good dual purpose machine is pricey (but very fun).
Need advice on ticket/suspension Muskokan CANADA 43 04-05-2014 04:43 PM
suspension setup advice edsbreezy Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 02-03-2014 11:14 PM
Need some Suspension advice! LazerBrZ Mid-Atlantic 6 10-09-2013 09:36 AM
Suspension advice? GTBRZ Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 08-25-2013 11:38 AM
Some advice on suspension from serious drivers NON-VTEC Tracking / Autocross / HPDE / Drifting 15 02-01-2013 01:12 PM
