Old 05-19-2014, 09:46 PM   #113
NYC BRZ
AutoX Addict
NYC BRZ's Avatar
Drives: 08 Pontiac G8 GT,13 GBS BRZ Limited
Alright guys I'm finally picking a set of CS tires this week. Hankook RS3 V2 or Dunlop Z2. I spoke to Sam Strano (multi time SCCA national champ) and he is convinced the RS3 V2 needs a wider width that what we can fit on the 7" wheel to be effective. I had Z2s last year that I autox'd on and daily drove on and they were great. I plan on doing the same with the RS3 V2s. Thoughts?
2013 BRZ Limited- GBS - 6MT -VIN #0937
~~NYR SCCA # 18 C Street R (CSR)~~
"But there’s no mistaking the noise. This car is loud, and not in a particularly nice way. There’s no crisp exhaust note, no induction wheezing. It’s just the sound of petrol exploding in a metal box." - Jeremy Clarkson
NYC BRZ is offline   Reply With Quote
Old 05-19-2014, 11:48 PM   #114
renfield90
The Stig's German cousin
Did Sam say why? At any rate, it is surface/weather/setup dependent.
Old 05-20-2014, 12:39 PM   #115
G_Ride
G_Ride's Avatar
Drives: Some kind of Subaru
Smile
Like renfield90 said, it's surface/weather/setup dependent. What kind of surfaces and weather do you usually see for your events?
G_Ride is offline   Reply With Quote
Old 05-20-2014, 02:41 PM   #116
Kido1986
Dodging cones
Kido1986's Avatar
Drives: 2013 BRZ Limited, 93 Z28
If you're going to DD the same tires, Z2 all the way. RS3 like to heatcycle out, assuming the V2 is similar in behavior. Z2s also handle cooler and wetter wether better than RS3.
I LOVE the Rs3 but it like a lot of camber, and we can't provide that. When I go STX, RS3 will be my weapon of choice but I'm stay on Z2s while running Street
Originally Posted by trevorovert View Post
Originally Posted by mrbillclintong View Post
If you guys spot any riced frs/brz post them here just for laughs no hating please.
Isn't there already a thread like this? It's called aggressive wheels or summat...
C Street Build/Progress Questions about C Street Autocrossing?
Kido1986 is offline   Reply With Quote
Old 05-20-2014, 03:39 PM   #117
DylanFRS
Lost in Kansas
DylanFRS's Avatar
Drives: 2013 Scion FRS (Raven)
I agree with this.
DylanFRS is offline   Reply With Quote
The Following User Says Thank You to DylanFRS For This Useful Post:
NYC BRZ (05-20-2014)
Old 05-20-2014, 05:55 PM   #118
AustinTX
Pawn in game of life
AustinTX's Avatar
Drives: 19 STX BRZzz
I will report my thoughts between the Z2 and RS3 on a CS BRZ after the next event. I've been on the 235 Z2's for 3 months, and I'm switching to 245 RS3V2's.
Autocross nut
AustinTX is offline   Reply With Quote
The Following User Says Thank You to AustinTX For This Useful Post:
G_Ride (05-20-2014)
Old 05-20-2014, 10:25 PM   #119
NYC BRZ
AutoX Addict
NYC BRZ's Avatar
Sam is convinced we don't have the wheel width necessary to stuff an RS3 large enough on there to be 100% effective. I agree that wheel width is this car's CS Achilles heel. I don't have the experience on the RS3 to say yay or nay. Unfortunately the RS3 V2 is too new and I can't find any reviews on folks who have daily driven on them.
Old 05-20-2014, 10:29 PM   #120
NYC BRZ
AutoX Addict
NYC BRZ's Avatar
Pretty loose asphalt surface. The Z2s were great last year I've just been thinking about switching it up to try something new. I was going to go Rivals but I can't DD them. Supposedly the V2s are supposed to have a better operating range and are better in the wet than the V1s.
Old 05-21-2014, 12:13 AM   #121
renfield90
I guess the only way I see that happening is that the slightly softer sidewall is soft enough to ruin the gains you get by stuffing more tire than you should. Mr. Hale's test should be very enlightening.
Old 05-21-2014, 01:00 AM   #122
SeanRTR
C-Street AutoX
SeanRTR's Avatar
Why not? Z2's will apparently heat cycle out over time with street miles. I've not noticed a drop off in performance whatsoever in full depth rivals,.to chorded rivals. Those that think you're going to die if you drive rivals in the rain, are either fueled on estrogen, or just bad drivers in general. Daily driving rivals is fine, I don't get it.
SeanRTR is offline   Reply With Quote
Old 05-21-2014, 02:18 AM   #123
G_Ride
G_Ride's Avatar
I've had two events on the RS3 v2 and so far it seems to be true about the lower operating temperature. I still don't know about Hankook's better wet traction claim. It's been very dry in the California Bay Area.
Old 05-31-2014, 09:42 AM   #124
rx3
I think I read somewhere that different rim diameters are going to be allowed in stock class (next season)?
Has anyone considered to run on 16" instead of 17" rims?
A taller 245 tire on a 7" wide 16" rim would be less pinched and therefore possibly deliver more grip (as opposed to a 17" rim).
(I understand that the sidewall would flex more, but this could be overcome by turning sooner).
rx3 is offline   Reply With Quote
Old 05-31-2014, 11:09 AM   #125
neurokinetik
neurokinetik's Avatar
Drives: 2013 Scion FR-S Firestorm
This is also true of the Hankook RS3, whether old or new version. Even at temperatures down into the high to mid 30's, and dry pavement, the old RS3s still provided significantly more traction than a set of Blizzaks, which is what I run the "other" six months out of the year. Rain does not become a problem until you've got them worn to a pretty shallow tread depth, but that holds true for any tire.
At least they don't have to be shaved to not self-destruct during autocross or track time, that is what makes for a bad daily driver tire, IMO.
neurokinetik is offline   Reply With Quote
Old 05-31-2014, 02:48 PM   #126
DylanFRS
Lost in Kansas
DylanFRS's Avatar
Agreed. Some people don't seem to understand that there is a difference between optimal grip on an autocross course and adequate grip for driving on the street.
SCCA Solo C Street Discussion Kido1986 Tracking / Autocross / HPDE / Drifting 4831 07-08-2020 04:52 PM
Let's discuss SCCA Stock Class ayau Tracking / Autocross / HPDE / Drifting 314 04-18-2013 03:03 PM
SCCA RTR Vs C stock theredtape Tracking / Autocross / HPDE / Drifting 7 03-27-2013 04:26 PM
Motion Control Suspension Singles---SCCA Stock legal are done! Sam Strano Tracking / Autocross / HPDE / Drifting 25 01-16-2013 03:42 PM
2012 BRZ/FR-S Stock Class Autocross Discussion EMguy Tracking / Autocross / HPDE / Drifting 183 01-04-2013 04:17 AM
