#113 | |
Drives: 2013 WhiteOut FR-S
Yes that would be the only reason i could think of, my car was bone stock at the time except MXP exhaust After a long research on what causes DI failure, no one knows lol but i concluded a software tune and oil cooler are the best bet to prevent DI failure again Sent from my iPhone using TapatalkfQ
2013 Scion FR-S whiteout 2012 Porsche Panamera S carbon grey 2008 Range Rover Sport SS black - sold 2004 BMW M3 alpine wies - sold |
#114 | |
Trust me, I'm the Doctor
Daily Driver: 2014 BRZ 6MT Limited ^GT5 Replay Photo Mode^ |
#115 | |
Ever been on a kart over a rough surface? It's painful; everything is transmitted directly toward the chassis. Now imagine if you can go over that same rough surface, but to the kart's chassis, the surface is smooth. That's what suspension does. Note how the wheel moves, but the chassis does not. Gopro mounts are not rigid; if the chassis is upset, you'll see it as camera shake. [ame="https://www.youtube.com/watch?v=NiA_Pq5YVaU"]S2000 Suspension in Action - YouTube[/ame] [ame="https://www.youtube.com/watch?v=nGBZWkoQO-s"]CSG BRZ Buttonwillow 2:00 lap - YouTube[/ame] |
#116 |
Right. I get that. But how do they interact with spring rates?
#117 |
I'm not sure I understand what you're asking.
Higher spring rates generally mean you need less compression damping (dynamic spring) and more rebound damping (so the spring doesn't extend too fast). Not enough rebound damping results in weight transitions that "gain momentum" and swing the way across the car too fast, resulting in traction loss. When you turn in, the outer wheel compresses(compression damping), and the inner wheel extends (rebound damping). |
| The Following User Says Thank You to CSG Mike For This Useful Post: | SirBrass (05-16-2014) |
#118 | |
And when you exit the turn, the inner wheel rebounds and the outer wheel compresses.
| The Following User Says Thank You to SirBrass For This Useful Post: | CSG Mike (05-16-2014) |
#119 |
Drives: 2014 SWP BRZ Limited
Well I was going to ask the CSG guys questions about their new packages, but a lot of my questions are getting answered here. Cheers!
| The Following User Says Thank You to Scottemad123 For This Useful Post: | CSG David (05-16-2014) |
#120 |
#121 |
So this is primarily aimed at the CSG folks, but if others have an opinion please chime in. Could you tell me about the difference between the "JRZ RS PRO - Double Adjustable Club Sport Damper" and the "JRZ RS - Double Adjustable Twin Tube Damper"? Also, do both of those come with camber plates? I don't think I see an option for them on the raceseng plates.
Fun car leads to autocross, autocross leads to track days, track days lead to lemons, lemons leads to racing school, racing school leads to spec Miata...
No idea where it leads next! |
| The Following User Says Thank You to ddeflyer For This Useful Post: | RehabJeff86 (05-29-2014) |
#122 |
Drives: Firestorm FR-S
Does Swift Spec R spring over kill our stock shocks with its higher kg/mm?
#124 | |
A twintube can be plenty good, but we've tested both and really prefer the RS PRO over the RS. We actually prefer the RS1 monotube 1 way over RS. Camber plates would be an option for either one. - Andy |
| The Following 2 Users Say Thank You to Racecomp Engineering For This Useful Post: | ddeflyer (05-29-2014), RehabJeff86 (05-29-2014) |
#125 | |
| The Following User Says Thank You to RehabJeff86 For This Useful Post: | ddeflyer (05-29-2014) |
#126 |
The pain of spending so much money on the car is significantly reduced after spending $4K+ (maybe 5K? I haven't added it all up since I was also buying stuff like a fire suit for a lemons race at the same time) getting a proper, full safety system (custom weld in roll bar, two fia certified seats, harnesses for both, hans device, mounting stuff, etc.) for the car. Building a good dual purpose machine is pricey (but very fun).
| Need advice on ticket/suspension | Muskokan | CANADA | 43 | 04-05-2014 04:43 PM |
| suspension setup advice | edsbreezy | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 3 | 02-03-2014 11:14 PM |
| Need some Suspension advice! | LazerBrZ | Mid-Atlantic | 6 | 10-09-2013 09:36 AM |
| Suspension advice? | GTBRZ | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 0 | 08-25-2013 11:38 AM |
| Some advice on suspension from serious drivers | NON-VTEC | Tracking / Autocross / HPDE / Drifting | 15 | 02-01-2013 01:12 PM |
