Old 04-17-2014, 02:40 PM   #43
FRSupra
FRSupra's Avatar
Originally Posted by jadewbj View Post
I think beatsonic is JDM, not OEM JDM but JDM none the less.
I meant one thing but typed another, thanks for clarifying that.
FRSupra is offline   Reply With Quote
Old 04-17-2014, 03:14 PM   #44
extrashaky
Drives: 2014 BRZ Limited
Originally Posted by HunterGreene View Post
And when I read about the improved suspension, all I hear is "stiffer," which means for DDers like me, rougher ride on streets. I'm good with my MY13 at this point
Same here. I literally can't drive above 10 MPH over the rough roads in my neighborhood as it is. A stiffer suspension for me would result in lost teeth, or worse, damage to the car.
Originally Posted by Bristecom View Post
And frankly, I'm not a fan of shark fin antennas on this car either. I like the antenna to be as low profile as possible so the standard black box with the antenna removed was fine.
The stock long antenna has grown on me, and I'm thinking of actually going the opposite direction with it and mounting some sort of flag on it.
Old 04-17-2014, 03:24 PM   #45
Mikem53
Drives: FR-S 6MT
Originally Posted by DarkSunrise View Post
Seems like mild updates, but I'd be interested to see what "more rigid fixation of the front suspension" means. Perhaps they reinforced the mounting points?
That's what I'm thinking.. Or a different mounting system..
Mikem53 is offline   Reply With Quote
Old 04-17-2014, 03:42 PM   #46
OICU812
Just a dude
OICU812's Avatar
Drives: Scion FR-S 2013
Sharkfin... Who cares rather of seen a g37 style. I'm the oddball I suppose and don't care for sharkfins. Even though clearly all the news on new features and small add one guarantee there will be threads going till 2020 claiming turbo / sc "next year" lol
The Following User Says Thank You to OICU812 For This Useful Post:
Lonewolf (04-18-2014)
Old 04-17-2014, 03:54 PM   #47
Bristecom
Bristecom's Avatar
Drives: 2017 Subaru BRZ PP
And one of those horns that play songs?
Toyota + Subaru =
Bristecom is offline   Reply With Quote
Old 04-17-2014, 03:58 PM   #48
tahdizzle
So elite I'm 1338
Drives: WRB Subaru BRZ
a g37 style antenna would be something I'd be interested in.
The sharkfins on the market now, and even the oem ones stick out like a sore thumb.
I'm fine with my RC car style antenna. IMO its better than trying to church it up by taping on this HUGE plastic cover.
The Following User Says Thank You to tahdizzle For This Useful Post:
Bristecom (04-19-2014)
Old 04-17-2014, 04:24 PM   #49
Efferalgan
Drives: 2025 BRZ, ex-2012 GT86
Originally Posted by N1rve View Post
What's that button next to the mirror switch do?
Folding/unfolding mirrors
Efferalgan is offline   Reply With Quote
The Following User Says Thank You to Efferalgan For This Useful Post:
pascalbrax (04-23-2014)
Old 04-17-2014, 06:46 PM   #50
bdbx18
Drives: Present MDX, Civic Hybrid, BRZ
Originally Posted by tobin View Post
I like the two black dash panels...a lot.
I covered mine some time back but they missed the two vertical silver strips on the center console. I firmly believed my car performed better after the mod. The silver trim of the BRZ just hurts my eyes though.
Current: 07 MDX, 06 Civic Hybrid, 13 BRZL
Past: 03 M3 SMG, 99 540i, 01 X5 4.4, 01 X5 3.0, 03 MDX, 92 NSX, 89 Maxima, 86 Integra, 88 Odyssey, 88 Legend, Supra, MR2T, Pathfinder, MirageT, Accord
bdbx18 is offline   Reply With Quote
Old 04-18-2014, 02:38 AM   #51
NLS8520
Drives: N/A
I wonder if they will also include the BBS wheels and Sachs dampers/Dunlop Direzza's (that were pictured recently) as well in the form of an option?
NLS8520 is offline   Reply With Quote
The Following User Says Thank You to NLS8520 For This Useful Post:
radroach (04-21-2014)
Old 04-18-2014, 04:54 AM   #52
Yoniyama
Drives: BRZ 2018
I am not sure Toyota is installing a 'stiffer suspension', as in harder springs/bushing and tighter dampers. My impression is that Toyota is trying to improve handling and ride quality by:
1 Increasing the rigidity of the suspension set-up; (with bigger bolts) and
2 Reducing internal friction (or sometimes called stickion) of the dampers. The usual way to reduce internal friction is to use a hydraulic fluid with lower viscosity, and increase the rigidity of the damper body and rod (hence thicker rod). Because internal friction increases exponentially when the damper bends (or flexes) under stress, and a strong body and thicker rod bend less under stress.
I doubt if the ride will feel much stiffer after the 2015 modification.
Yoniyama is offline   Reply With Quote
Old 04-18-2014, 07:37 AM   #53
dnieves
Drives: FR-S 10 Series
Originally Posted by campy View Post
So basically
-stiffer suspension
-a slightly-more-realistic-looking fake CF trim
-a sharkfin antenna (which will increase aerodynamics)
Nothing to write home about. Hopefully people will learn to calm down with model year upgrade speculation.
Hahaha. More realistic fake carbon fiber! That's like Chrysler's real Corinthian leather made from vinyl cows. Judging from the DIYs in YouTube it looks do-able to make that trim in front of the passenger in CF since you already have the original you can use as the basis for a mood.
I'd try it if I could figure out how to keep the EL panel intact.
dnieves is offline   Reply With Quote
Old 04-18-2014, 07:51 AM   #54
dnieves
Originally Posted by tahdizzle View Post
USDM is a unique market.
in the US, Sat Radio is popular. Everywhere else.... Not so much.
Does that Shark fin, fit a USDM antenna?
If it doesn't, will they produce one just for the US market?
Just wait and see.
We have satellite (XM) radio? Is this with the 2014 Bespoke because I thought it only had HD radio?
Old 04-19-2014, 10:41 AM   #55
BlueDubbinTDI
BlueDubbinTDI's Avatar
Drives: 2013 FR-S, 2012 MCS
Looks like my lease is going to run out at the perfect time after all so happy nothing crucial happening for 2015
Old 04-19-2014, 11:30 PM   #56
Bristecom
Bristecom's Avatar
Yeah, I doubt those will be available here in the US. My beef with those wheels, although they are very nice, from what I saw they are different sized front and rear. That means you can't rotate front and back and it also means less fun/oversteer and higher cost of tires. So frankly, I'd rather just have the 17's. Now if they made that style of BBS wheel in the lighter stock 17 inch size, I'd be rollin' 'em!
Interesting points. However, it looks like they just switched supplier to Sachs from Showa. Which yeah, the Sachs may have those design advantages. Showa is probably the best Japanese shock maker but Sachs is likely a little higher performance.
Toyota + Subaru =
No factory turbos for GT86 says Karl Schlicht (Toyota Motor Europe VP) vh_supra26 Scion FR-S / Toyota 86 GT86 General Forum 163 03-17-2014 10:53 PM
20$ Shark Fin Antenna srt4_night_rider Cosmetic Modification (Interior/Exterior/Lighting) 13 05-08-2013 02:13 AM
Shark Fin Antenna Sparda29 Cosmetic Modification (Interior/Exterior/Lighting) 3 01-20-2013 11:49 PM
Tom's antenna shark fin Hanzo Cosmetic Modification (Interior/Exterior/Lighting) 15 10-28-2012 01:44 PM
2013 Toyota GT86 - Driving Dynamics(english) carbonBLUE FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 3 05-11-2012 05:39 AM
