Old 08-24-2012, 06:10 PM   #1
srt4_night_rider
20$ Shark Fin Antenna
Well i just couldnt justify spending 100 dollars on a sharkfin antenna so i improvised. I looked online at all different types of cars that come stock with shark fin style antennas. I found a stock black antenna cover that came off of a BMW on ebay for 20$ shipped, and decided what the heck ill give it a try. Well it finally came in today, it wasnt an exact fit but with just a little bit of customizing it turned out perfect.
Sorry for the bad picture qualtiy i took them with my iphone
So this is what it looked like when i got it.
So our stock antenna was a little wide so i had to shave a little off of both sides of the cover, and there was a dimple that i shaved off so that it would sit flush
Then i just put new double sided tape on it,
And then just put it on,
I dont know how much someone would charge you to paint match one of these but i bet it would still end up being cheaper then buying one for $100.
srt4_night_rider is offline   Reply With Quote
Old 08-24-2012, 09:40 PM   #2
Ericfrs
New Member
Ericfrs's Avatar
Drives: 6AT Ultramarine FR-S
That looks great!! Something I want to do in the future.
One question though, does the radio still work? If it is only a cover, I assume it only improve the appearance but doesn't keep the radio?
Ericfrs is offline   Reply With Quote
Old 08-25-2012, 03:04 AM   #3
encity5
encity5's Avatar
Clever! But yes curious if you have antenna signal anymore
encity5 is offline   Reply With Quote
Old 08-25-2012, 03:05 AM   #4
86_ZN6
86_ZN6's Avatar
Drives: 86 ZN6
if you take out the stock antenna rod you still get a little signal but not that great
im assuming this is the same since it is a cover
86_ZN6 is offline   Reply With Quote
Old 08-25-2012, 07:47 AM   #5
miodculae
FRS Adept
miodculae's Avatar
Drives: Firestorm FRS
All the other fins sold here have an antenna.
The VG I installed maintains the same signal strength as the OEM.
miodculae is offline   Reply With Quote
Old 08-26-2012, 02:59 AM   #6
srt4_night_rider
Sounds exactly the as it did with the antenna rod still on it, easy way to see how your stations are gonna come in if you do this is just unscrew your rod and ride around for a day.
Old 08-26-2012, 08:08 AM   #7
bakerr6
Drives: 2013 raven black fr-s
you can buy an aftermarket antenna and modify it anyways, should only cost around $10. Nice find btw
bakerr6 is offline   Reply With Quote
Old 05-02-2013, 02:01 PM   #8
srt4_night_rider
That was exactly my idea, just haven't done it yet because I usually only listen to my ipod.
Old 05-02-2013, 11:59 PM   #9
FRSGT86
FRSGT86's Avatar
Drives: 2013 Raven FR-S, 2005 Dodge Ram
That came out nice!
2013 FRS 6AT in Raven!
FRSGT86 is offline   Reply With Quote
Old 05-03-2013, 01:30 AM   #10
Frsexxxy
Drives: White Virgin frs
Ghettooo to the bone
Frsexxxy is offline   Reply With Quote
Old 05-05-2013, 02:09 AM   #11
srt4_night_rider
Originally Posted by FRSGT86 View Post
That came out nice!
Thanks!
Old 05-05-2013, 02:13 AM   #12
OICU812
Just a dude
OICU812's Avatar
Drives: Scion FR-S 2013
Looks lots smaller then rest I've seen if so good, I like shark antennas but all offerings are too large IMO.
Old 05-08-2013, 01:10 AM   #13
srt4_night_rider
I think it may be a tad shorter, but the biggest thing is that it's longer with a gradual rise in height instead of having that sharp rise.
Old 05-08-2013, 01:13 AM   #14
OICU812
Just a dude
OICU812's Avatar
Yup like it hope someone makes something similar made for it!
Flat low profile antenna (non shark fin) Enigmus Cosmetic Modification (Interior/Exterior/Lighting) 177 09-02-2015 04:13 PM
Visual Garage Shark fin antenna EvoXDD Cosmetic Modification (Interior/Exterior/Lighting) 86 08-02-2015 02:20 PM
Tom's antenna shark fin Hanzo Cosmetic Modification (Interior/Exterior/Lighting) 15 10-28-2012 12:44 PM
Beat-Sonic USA Shark Fin Antenna for Subaru BRZ, DOES NOT FIT! xcelir8brz Electronics | Audio | NAV | Infotainment 2 06-04-2012 11:44 PM
