Old 03-05-2014, 01:05 PM   #15
laley81
Scion FR-S
laley81's Avatar
Drives: Scion FR-S 2013
Getting mine literly in 1 hour lol.. I love the way the v style looks. Im having my center triangle completely off. We have the tail light brakes and rear winshield brake light already. too much with the flashing center trianlge. ill post some pics up later.
laley81 is offline   Reply With Quote
Old 03-05-2014, 02:33 PM   #16
raytrix
Drives: Series 10 FR-S
Originally Posted by modena View Post
As you stated:
"LED triangle lights up ONLY when brake is depressed WITH flashing.
it's WITH the Flashing or F1 Light Function upon breaking."
That is what I want
Anyone has pics of the wiring to do this style?
raytrix is offline   Reply With Quote
Old 03-13-2014, 12:42 AM   #17
raytrix
bump to see if anyone figure out how to rewire the triangle to only light up and blink 3 times when you hit the brakes. Don't want the triangle to be on with the parking lights.
Old 03-14-2014, 12:15 PM   #18
tiz22
tiz22's Avatar
Drives: 2013 Scion FR-S (Raven) MT
Originally Posted by SPCorBUST View Post
I used a connector for the Single Red (previously Orange/Black) to cut Blue wire, the one between the light bar and triangle.
I don't know much about wiring, but I did not see the need to solder the cut Blue wire to the ModBargains provided Blue wire and then solder that to the Single Red wire, so I left it alone, and it seems to be working fine - again though, I am not an electrician by any stretch of the imagination!
For those of you that have Green and Green/Yellow wires instead of the Blue, Red, Yellow, and Black wires for your taillights, here's how I did mine, with Blue to Green and Red to Red:
Turned out great!
Note: while this works, it seems like you give up the F1 function for the chance to use the light bar and the triangle separately, one as a brake and the other as a parking light. @Phaedrus29 has indicated in this post that it might still be able work though!
I notice you have TOMs tails installed...I'm about to install the reverse bar tonight probably but all the DIYs are with valenti tails installed so I'm guessing a few of the steps (wire colors) will be different...
Can you link me an accurate step-by-step DIY/video that does it with TOMs tails? Or can you provide me the steps you took?
My Car Journal: Raven FR-S w/ TRD Flavour
Click for my AVIC Z150BH Head Unit DIY Install
tiz22 is offline   Reply With Quote
Old 03-14-2014, 03:18 PM   #19
raytrix
Anyone have a picture of the wiring inside the housing with the LED triangle retaining it's 3 flashing mode when the brakes depressed? I want exactly the way the OP has it setup but with the triple flashing included with the braking.
Old 03-17-2014, 10:48 PM   #20
raytrix
Since no one wanted to help. I figured it out with a help of a friend. I believe this is what most people want the setup to be like. With the flashing built-in.
The Following 3 Users Say Thank You to raytrix For This Useful Post:
Efferalgan (04-08-2014), ibmdajerk (07-15-2015), Vincenttam (06-05-2015)
Old 04-06-2014, 06:12 AM   #21
melon
melon's Avatar
Drives: Toyota 86
GREAT JOB!!! Could you post how you did the wiring?
melon is offline   Reply With Quote
Old 04-11-2014, 03:22 AM   #22
shadow017
Drives: BRZ WR Blue
I ended up having to figure out the wiring myself but thanks to raytrix's video I had to do this to my friends car. I used the OPs instructions for reference.
V on with headlights
LED triangle lights up when brake is depressed with flashing
Reverse- no changes
Instructions:
1. Remove 10 phillips screws from the back of the light.
2. You will see a dark blue wire connecting the V to the LED triangle
3. Remove the Blue and Red wire from where it is connected to the Triangle by either cutting or desoldering it.
4. Solder the Blue and Red wires together. Then cover exposed wire with electrical tape or heatshrink tubing.
5. Now solder a new wire from the Triangle to the Orange/Black Wire.
6. Check your work. Make sure there are no loose connections and test it out.
7. Reassemble fully and have a beer. You earned it.
shadow017 is offline   Reply With Quote
The Following 7 Users Say Thank You to shadow017 For This Useful Post:
b rawr z (02-08-2015), DeadStar7 (07-26-2014), Efferalgan (07-05-2014), FRStrent (03-17-2015), LXXXV1 (06-04-2014), melon (04-18-2014), unsurety (06-19-2014)
Old 04-11-2014, 03:42 AM   #23
headlikeahole
headlikeahole's Avatar
Drives: Ultramarine toyobaru
I wonder how many idiots drive around with the rear fog on because they think it looks cool. Anoying the shit out of everyone else on the road.
headlikeahole is offline   Reply With Quote
The Following User Says Thank You to headlikeahole For This Useful Post:
Efferalgan (04-19-2014)
Old 04-11-2014, 02:35 PM   #24
cdo221
Drives: 2013 Ultramarine FR-S, 2015 RS 1.0
How's it annoying? the lower V isn't blinding or anything. Same thing as driving around during the day time with low beam on... not required by law but I think it makes cars more aware of your presence (kinda like DRLs).
cdo221 is offline   Reply With Quote
Old 04-11-2014, 03:18 PM   #25
headlikeahole
The lower V isn't a fog light. I'm talking about the actual fog light that is 3 times brighter then your normal tail lights (about the same as brake lights).
cdo221 (04-11-2014)
Old 04-11-2014, 03:36 PM   #26
cdo221
Ah I see, misunderstood you
Old 04-19-2014, 06:41 PM   #27
Efferalgan
Drives: 2025 BRZ, ex-2012 GT86
Does anyone know how to the wiring so that the triangle left as the fog light but the V-shaped light turns on when the headlights are on (together with the taillights)?
Efferalgan is offline   Reply With Quote
Old 05-10-2014, 08:40 PM   #28
Frank5364
Frank5364's Avatar
Drives: 2014 Subaru BRZ white limited
Is there a way to this without re wiring and soldering the actual lamp?
Frank5364 is offline   Reply With Quote
rear fog, valenti
Wiring BRZ rear fog light to only come on with front fogs Scenic Driver DIY (Do-It-Yourself) Guides 4 09-12-2015 10:36 AM
Valenti Japen LED Reverse Tailight USDM Wiring Furtive DIY (Do-It-Yourself) Guides 12 08-21-2015 10:31 AM
Valenti 3rd brake light wiring SPCorBUST Southern California 4 09-24-2013 12:57 PM
Valenti Tail Lamps and Tommy Kaira Rear Spoiler harajukukei Cosmetic Modification (Interior/Exterior/Lighting) 19 06-04-2013 08:01 PM
Alternate TRD Rear Bumper Possibilities Breeze Loo Cosmetic Modification (Interior/Exterior/Lighting) 3 05-06-2013 02:06 PM
