Old 04-07-2014, 10:27 PM   #995
keen as
keen as's Avatar
Drives: 86 GT MT
Originally Posted by shiv@vishnu View Post
Quick update: New single channel data viewing option is coming soon. Attached is a design we mocked up. The purpose is to give the user an easy-to-see read gauge with both numerical and color-coded bar graph display. The user will be able to pick from any of the channels displayed in the realtime data screen (which is configurable). Simply touch any single channel in the realtime display and it will zoom in We are working on this update now but it shouldn't be too long until it is released. Should save some people the expect of having to buy separate a boost, wideband AFR or temp gauges!
Good stuff. Very useful.
Option of double or quadruple channel data viewing would be nice.
I don't have any suggestion to make the interface easy to view more than one channel data.
keen as is offline   Reply With Quote
Old 04-08-2014, 12:08 AM   #996
DC2R
Drives: 2014 Scion FR-S
Just ordered Amazon one
Sent from my GT-N5110 using Tapatalk
DC2R is offline   Reply With Quote
Old 04-08-2014, 12:21 AM   #997
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
You ordered an OFT from amazon? Or are you referring to the obd cable extension?
Shiv@Openflash is offline   Reply With Quote
Old 04-08-2014, 12:36 AM   #998
toyotaAlex
toyotaAlex's Avatar
Drives: 2013 Scion FR-S Auto- OFT Stage 2EL
i just ordered my OFT + OFH combo, cant wait to get it!
toyotaAlex is offline   Reply With Quote
The Following User Says Thank You to toyotaAlex For This Useful Post:
Shiv@Openflash (04-08-2014)
Old 04-08-2014, 07:40 AM   #999
DC2R
Lol yea the extension
Sent from my SM-N900T using Tapatalk
Old 04-08-2014, 02:39 PM   #1000
shif7i7down
Erected Member
Drives: frs
Lol, i bet you had the same facial expression as the picture in your sig when you thought he order his oft from Amazon
shif7i7down is offline   Reply With Quote
The Following User Says Thank You to shif7i7down For This Useful Post:
DC2R (04-08-2014)
Old 04-08-2014, 02:45 PM   #1001
Wepeel
Drives: '13 BRZ Ltd
Hi guys,
Quick FYI for those who plan on purchasing an OFT soon: We have less than 20 in stock as of now. New stocking order probably wont be arrive until end of next week so if you want one to ship the same (or next) day you order, we advise ordering soon. We expect to be out of stock within 24hrs.
Placed my order last night. Hope I made it
Wepeel is offline   Reply With Quote
Old 04-08-2014, 03:38 PM   #1002
Shiv@Openflash
Drives: 2013 FRS
lol... I did. We have been getting report of scams involving OFT sales on ebay and Amazon. So we are on high alert
The Following User Says Thank You to Shiv@Openflash For This Useful Post:
DC2R (04-08-2014)
Old 04-08-2014, 03:39 PM   #1003
Shiv@Openflash
Drives: 2013 FRS
Yes, i think you are good to go
Old 04-09-2014, 01:35 PM   #1004
Shiv@Openflash
Drives: 2013 FRS
Small teaser video posted on our Facebook
Still tweaking the design (font, size, color, etc,.) a bit but functionality is spot-on! This feature will be released later this week
Luckrider (04-09-2014)
Old 04-09-2014, 01:43 PM   #1005
Luckrider
My Other Ride's a Jeep
Luckrider's Avatar
Drives: 2013 BRZ Limited
Looks pretty cool. An AFR/Boost gauge (two semidials) would be nice for Phantom and OFT300 owners.
Luckrider is offline   Reply With Quote
Old 04-09-2014, 01:47 PM   #1006
Shiv@Openflash
Drives: 2013 FRS
Yep! That will come later. The colorful bar graph on the bottom would actually display AFR while the numberical value would show boost.
The Following 2 Users Say Thank You to Shiv@Openflash For This Useful Post:
keen as (04-10-2014), Luckrider (04-09-2014)
Old 04-09-2014, 01:58 PM   #1007
nelsmar
Only guessing here but seem to remember reading the second o2 sensor was only to monitor header CAT efficiency and pop up cel code. Don't Ecutek guys hijack that sensor input for wideband fail safe, think the OFT guys also setting up a wideband on this input as well that can be read by oft, but if I understand it correctly it just monitored by oft by reading ram address in ecu.
It would appear you may need and ecu code patch to actually do something with the input data.
Yes on ecutek we can use it as an input. However in factory form there is a fuel trim compensation for rear o2. I have a local who has a problem and is getting DTC's that I have resolved by setting these values to 0 from -0.5 / 0.5 (factory values). The oem ecu uses these values to apply minor fuel trims. I never tested to what extent it will trim through, its a bit of a PITA to test something like that!
My flickr - Canibeat
Local magazine scout
Old 04-09-2014, 02:19 PM   #1008
1Cor10:23
1Cor10:23's Avatar
Drives: '13 Whiteout FR-S (M/T)
I've got a right angle one and tuck it into the trim.
Nice setup - where do you have the other end coming out? Cheers.
1Cor10:23 is offline   Reply With Quote
#lolwut, divinecomedy, dopeandcashcabinet, free shiv now, goddamitimissedit, golden cage, i missed the show, looks good, missed the fun, omgbbq, shiv 2016, thefatandthefurriest
Tablet on the dash ! TRD_86 Electronics | Audio | NAV | Infotainment 23 05-16-2015 04:48 AM
Tablet Install ThugNasty Electronics | Audio | NAV | Infotainment 4 04-13-2013 04:15 PM
Blutooth OBD II and a 9.7 tablet.. Scooby South Electronics | Audio | NAV | Infotainment 10 12-16-2012 09:11 PM
7.0 Tablet w/ Torque App Thatruth2001 Northwest 26 11-21-2012 12:53 PM
