Old 04-07-2014, 08:20 PM   #29
w00t692
Drives: 2008 Civic Si
Originally Posted by industrial View Post
Not being able to explain why you were not able to engage 1st gear is really killing your cred. PRE took it apart and found nothing wrong at all? That tells me that more than likely there was some kind of install error if the problem was something as drastic as not being able to engage a gear but nothing seemed amiss when disassembled. Especially considering that you were having issues from the very beginning but did not bother to take it to a professional. I'd guess you messed up the install, the shop found the error but said nothing and happily installed the new part.
I'm still trying to wrap my head around how a clutch and flywheel could prevent the engagement of 1st gear. Care to explain?
Or it was a faulty pressure plate, which don't show their face without testing them on a machine, or it had improper geometry which doesn't show it's face without knowing exactly oem specs and measuring against them.
Why are people so quick to blame some dude having issues. The DSM epidemic of crankwalk was mostly caused by the popularity of a very heavy pressure plate they ran very often by none other than ACT.
w00t692 is offline   Reply With Quote
Old 04-07-2014, 08:30 PM   #30
evan
Drives: fr-s
Simple: it's easy for people to sit behind a keyboard and talk shit.
evan is offline   Reply With Quote
Old 04-07-2014, 08:33 PM   #31
evan
Drives: fr-s
PSA: ACT vs EXEDY street clutches
PRE did the install of the ACT clutch. Why would you assume that I installed it without asking? They also disassembled it but found no problem. That doesn't mean there isn't a problem. Just not something verifiable by the naked eye. Even PRE thinks the ACT clutches are problematic. ACT wants the PP to test it. That should explain enough.
PRE also installed the new EXEDY. I never waited to have a professional look at it. It was looked at from day 2 but the problem has been very sporadic only getting worse over time.
Btw: my credibility is perfectly fine. Thank you very much.
Old 04-07-2014, 08:36 PM   #32
industrial
Add lightness!
industrial's Avatar
Drives: 17' WRX
Well, you are the one that started with the attitude. I know how mechanical things work and when something is malfunctioning like you described, there usually is some obvious culprit. Some signs that something was amiss. The fact that you drove your car for a year while it was messed up says alot about your rodeo experience.
Your story is missing something and you are shilling for exedy now with about 0 practical experience with the product. You just switch out the clutch and have fixed a problem that was existed since day 1 with the other clutch which was probably user error. Or it could've been a faulty product but why drive around for a full year on it??? Something just doesn't make sense.
It's like people that replace worn out tires with new tires and exclaim they are the best ever after driving a few on ramps at 4/10s.
industrial is offline   Reply With Quote
Old 04-07-2014, 08:39 PM   #33
evan
Drives: fr-s
Or I know how parts work and when something is malfunctioning like you described, there usually is some obvious culprit. Some signs that something was amiss. The fact that you drove your car for a year while it was messed up says alot.
Not trying to work you up. Just giving the community information. What you do with it is up to you. I thought that's what contributions are all about. Embedding my opinion in the data is normal human behavior. Have a nice day.
Old 04-07-2014, 08:40 PM   #34
industrial
Add lightness!
industrial's Avatar
Drives: 17' WRX
Then give us good information. Find out what failed or went wrong. You should get a job with Malaysian Airlines.
"I had this part, it always worked funny then a year later my car was messed up. A shop took the part off and everything looked great! I installed another part from Brand X and my car is much more better! Conclusion, Brand X is much more better!"
Old 04-07-2014, 08:42 PM   #35
Reaper
in orbe terrum non visi
Reaper's Avatar
Drives: violent
Can someone link a crankwalk issue related to an act clutch. Id like to see that
Sent from my SAMSUNG-SGH-I747 using Tapatalk
Old 04-07-2014, 08:42 PM   #36
evan
Drives: fr-s
When ACT tests the PP, you will get an answer. FYI, everybody I have talked to personally (in person) never has anything good to say about ACT. There is usually a reason for that. I don't need a job with Malaysia Airlines and to make fun of such a tragic thing is not nice.
Old 04-07-2014, 09:33 PM   #37
w00t692
It is NOT his place to have to pay for things just to give you a warm and fuzzy feeling inside.
At this point "x worked like shit, y worked perfectly" should suffice.
Old 04-07-2014, 09:33 PM   #38
w00t692
http://www.8thcivic.com/forums/clutc...ure-plate.html
Old 04-08-2014, 05:19 AM   #39
kiichiro
corolla specs/GTR looks
Drives: ooh oooh pretty tail lights
ACT clutches are responsible for all sorts of crank walk scenarios on multiple different engines as well. They're trash and i'd NEVER recommend an ACT clutch to anyone ever.
Exedy has always been a quality manufacturer and they make a LOT of different OEM clutches.
Act street light works great on my 300+hp brz, installed by azfa20
Works like a charm
SOLD THEM BOTH
Hers: 2007 987S
Mine: 2012 991S
That was fun, thanks Hachi
kiichiro is offline   Reply With Quote
Old 04-08-2014, 06:43 AM   #40
industrial
Add lightness!
industrial's Avatar
Drives: 17' WRX
I'm not the one issuing PSAs on shitty evidence.
Old 04-08-2014, 08:30 AM   #41
wparsons
wparsons's Avatar
What kind of evidence are you expecting? Just because there isn't a glaring fault that doesn't mean the clutch isn't defective. If the pressure plate is just slightly misaligned it could prevent the clutch from disengaging properly, but without very precise measurements and a good one to compare to you'd NEVER spot it. It would only take a mm or two to make the difference from a perfectly good clutch to one that doesn't disengage nearly enough.
The fact that ACT wants the parts back should be enough evidence alone.
flickr
Old 04-08-2014, 10:49 AM   #42
industrial
Add lightness!
industrial's Avatar
Drives: 17' WRX
The fact that ACT wants the clutch back means what? They want to see what/if anything is wrong before they warranty a part after the OP shit all over them prematurely to the world. That sounds absolutely reasonable to me. I would've at least waited to see if ACT would be scumbags or if they found something wrong before blowing it all over the internet like its a scientifically proven fact.
People today are so quick to speak out. What happened to critical thinking? The scientific process? This forum (to be fair, most forums) reminds me of idiotcracy more often than not. I'm not calling anyone an idiot but it's just the anti-intellectual, mob mentality that exists.
How about some hard facts of what went wrong before making a big deal about ACT. Is that SOOO much to ask? As an owner of their products, I'd really want to know if there is something to watch out for.
The stuff from 8th gen is interesting but not really applicable since it's a different problem specific to HD PPs on that platform.
Exedy Clutch KAR Engine, Exhaust, Transmission 28 01-03-2016 07:27 PM
exedy clutch questions ft86me Engine, Exhaust, Transmission 8 02-13-2014 09:58 PM
Lets talk about clutches charged86 Engine, Exhaust, Transmission 26 08-30-2013 04:13 PM
Clutches... Synack Engine, Exhaust, Transmission 19 12-16-2012 04:15 PM
Exedy BRZ specs sheet ayau BRZ Photos, Videos, Wallpapers, Gallery Forum 2 11-07-2012 09:56 PM
