Old 04-06-2014, 08:31 PM   #15
Dipstik-sportech
Dipstik-sportech's Avatar
I'm here making 425whp on 91 pump tuned by LJ himself.
The Frozen North
Old 04-06-2014, 08:33 PM   #16
Reaper
in orbe terrum non visi
Reaper's Avatar
Drives: violent
Anyone running 550 injectors making 450?
Sent from my SAMSUNG-SGH-I747 using Tapatalk
Old 04-06-2014, 08:35 PM   #17
nelsmar
Do you have any logs at all from your vehicle after the turbo was installed? You were running on a base map, and unless we know more information as to what was going on in the logs it sounds like there could have been endless possible issues.
My flickr - Canibeat
Local magazine scout
The Following User Says Thank You to nelsmar For This Useful Post:
Sportsguy83 (04-10-2014)
Old 04-06-2014, 08:41 PM   #18
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
Drives: Whiteout Scion FR-S
Originally Posted by Dipstik-sportech View Post
Was the fuel pump correctly installed? What boost? What fuel? Are these AFR's under load or idling? People are so quick to blame the tune but there are other reasons that engines blow. Hell who knows if he even had the correct about of oil in the car
The Frozen North
The Frozen North
im not blaming the tune at all.... LJ is the best and he is one great tuner.
i ran his tune almost 4 months no issues at all
it also could be a bad fuel pump installation, maybe no o-rings
Old 04-06-2014, 08:43 PM   #19
Dipstik-sportech
I wasn't meaning you @whitefrs you're good people lol.
The Frozen North
Old 04-06-2014, 08:53 PM   #20
Reaper
Reaper's Avatar
Drives: violent
Good call on the fuelpump. That almost caused me an issue on the dyno. But like nelsmar said without a log diagnosing this over the internet is futile.
The Following User Says Thank You to Reaper For This Useful Post:
Old 04-06-2014, 08:58 PM   #21
frs87
Drives: red/black
the fuel pump was good well i think it was but there was no way for me to tell im no mechanic, the car pulled crazyyy, that didnt feel like 7 psi, the boost controller wasnt messed with at all, and my mechanic did mention somethin about lowering the compression to about 9 or 10 to run higher boost and getting stronger rods and pistons, i have 550 injectors and running the gt28 turbo, the tune loaded fine but i didnt have any of my racerom features at all, like 2step etc etc which wasnt my main concern, i babied the car as much as possible but that didnt work so i guess i will see the results tommorow after they take the engine apart, and i was on 93 premium, i was gonna send lj the log but my car didnt even last 3 hrs before the knocking took place which really sucks,
frs87 is offline   Reply With Quote
Old 04-06-2014, 09:01 PM   #22
frs87
Drives: red/black
and i used the 0w20 motor oil, full synthetic, did a oil change too, hopefully its the just the rods that needs to be replaced which isnt that bad, i just want to be on the safe side and get a reflash as well
Old 04-06-2014, 09:13 PM   #23
frs87
Drives: red/black
Originally Posted by BRZnut View Post
Correct me if I an wrong, but I've always thought that if going Turbo you had to beef up the internals of the engine before going live. Seems all I see is people getting only a tune.
i was stage 2 tune, with uel borla headers, intake , perrin pully before and was fine but wasnt satisfied,
Old 04-06-2014, 09:15 PM   #24
johnnyfast11
Drives: none yet
i came from 3 evos.
slapping on a turbo to a NA engine will require a tune before you start boosting.
seems like you leaned out your engine too much from the turbo sucking in too much air without adding fuel. running too lean will cause internal explosions that you dont want. literally. your engine was exploding in all the places internally.
idle you want around 14.7
boosting / wot you want around 11.5 afr.
sorry your car is down. i know its a horrible feeling.
idling is not as important as your 11.5afr wot. I think that's where you went wrong. your wot afr.
johnnyfast11 is offline   Reply With Quote
Old 04-06-2014, 09:18 PM   #25
Tromatic
I'm confused. The tune you were running after the turbo was installed was a not a turbo tune?
Old 04-06-2014, 09:18 PM   #26
Dipstik-sportech
You say you babied the car and yet u say it pulled like crazy at 7psi? Did you have a boost gauge on it?
The Frozen North
Old 04-06-2014, 09:21 PM   #27
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
not sure who you mechanic is but if this car's fuel pump doesn't have the orings needed it will run lean and can cause a blown motor.
so ask them to check the fuel pump and take pics and post them
Old 04-06-2014, 09:26 PM   #28
Tromatic
Is the person doing the autopsy the same person who installed the turbo?
Full Blown Turbo Kit! Unleashed Engine, Exhaust, Bolt-Ons 70 10-09-2013 10:46 AM
2013 FR-S Full Blown Motorsports Stage1 Turbo kit. Mustang Dyno results. Infamous Performance Forced Induction 10 07-03-2013 09:52 PM
FINAL RESULTS: Taking Full Blown Stage 1 To The MAX! @Pure Automotive (Dyno Inside!) Pure Automotive Forced Induction 57 03-28-2013 12:41 AM
The Results Are In!! Full Blown Stage 1 Kit @ Pure Automotive Performance! Pure Automotive Forced Induction 181 03-12-2013 03:11 PM
The Results Are In!! Full Blown Stage 1 Kit @ Pure Automotive Pure Automotive Mid-Atlantic 22 02-12-2013 11:13 AM
