Old 03-31-2014, 01:33 PM   #883
shif7i7down
Erected Member
Drives: frs
I'm not sure to what extent the ecu is doing after reflash but the car feels sluggish after every reflash, but feels fine after 80 or so miles. The logs also shows very rich afr at wot during this learning time.
Edit: just for shitz and grinds. Try running your logs in virtual dyno right after reflash with those after 80+miles. Only seems logical..since if you reset a ecu because of a cel. It'll return only after the ecu relearn and can determined that there's an issue
shif7i7down is offline   Reply With Quote
Old 03-31-2014, 01:40 PM   #884
shif7i7down
Erected Member
Drives: frs
Sry for double post but my point is that it makes it hard to tune if you are not absolutely sure that the ecu is running at optimal efficiency with the new changes/tweaks
Old 03-31-2014, 01:43 PM   #885
jamesm
that sounds like you either took off before the exhaust cam turned on (unlikely), or that your fueling calibration is wrong and is requiring a trim in open loop to lean it back out. if that's the case, just make sure that everything is scaled properly and trims are minimal (i.e. <2%), and turn them off in open loop.
by ensuring that there are no trims operating in open loop and initial IAM is set to 1.. you should be able to flash the car, wait 30 seconds or so max for the exhaust cam to turn on, and go do power pulls. the throttle learning may need to take place but that won't effect a WOT pull.
The Following 2 Users Say Thank You to jamesm For This Useful Post:
gonzo (03-31-2014), Ironsquid (03-31-2014)
Old 03-31-2014, 02:02 PM   #886
shif7i7down
Erected Member
Drives: frs
Will give that a shot. If all goes well then I'll be much happier with the oft
Old 03-31-2014, 02:30 PM   #887
jamesm
email me and i can send you tables that will fix the issue for you. i can't receive pm's until they upgrade my account.
The Following User Says Thank You to jamesm For This Useful Post:
shif7i7down (03-31-2014)
Old 03-31-2014, 04:27 PM   #888
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
After you flash your ecu, make sure you start the engine and let it idle for a minute until the revs drop to ~800rpm. Then you can start driving. If you start driving right away, you will be in a low power mode that disables VVT. The car will drive ok but will feel very anemic. You can confirm this condition by plugging in the OFT, going to the realtime data screen and looking at VVT intake and VVT exhaust values. One or both of them will be 0.
Shiv@Openflash is offline   Reply With Quote
Old 03-31-2014, 06:30 PM   #889
DC2R
Drives: 2014 Scion FR-S
Just received tablet today . Flashed 1.42 stage one map at lunch and feels good so far. I noticed those maps seen to be static since December. Would you recommending flashing beta tunes? I have stock 2014 FR-S with drop-in filter. Waiting patiently for open flash header to arrive.
Sent from my SM-N900T using Tapatalk
DC2R is offline   Reply With Quote
Old 03-31-2014, 06:43 PM   #890
Superhatch
AIM4APX
Superhatch's Avatar
Drives: 2013 WRB BRZ Limited
New OFT user here. I feel like I'm getting conflicting stories about eh E85 EL tune. Can/should it be used with a stock exhaust system? I've read people using it with no issues and others saying a header is required. Could anyone help out with that?
Also, I've got a Perrin intake and tube. Will those be ok to use with the STG 1 tune?
TIA.
"It's very difficult to present technology as an overtly positive sales device to people who want an emotional car" -Chris Harris
Superhatch is offline   Reply With Quote
Old 03-31-2014, 06:54 PM   #891
Shiv@Openflash
Drives: 2013 FRS
The v1.5x OTS maps haven't been "beta" for a few weeks so definitely try them as they are more refined than what you are running now
Old 03-31-2014, 06:55 PM   #892
Shiv@Openflash
Drives: 2013 FRS
TIA.
You can absolutely run the e85 maps with a stock header/stock exhaust. No problem there whatsoever.
The Following User Says Thank You to Shiv@Openflash For This Useful Post:
Superhatch (03-31-2014)
Old 03-31-2014, 07:05 PM   #893
shif7i7down
Erected Member
Drives: frs
did not know that, no wonder it drives like total crap after reflash..
Old 03-31-2014, 07:15 PM   #894
8686
8686's Avatar
Drives: 86
is the 1.6 maps just around the corner or am I day dreaming.
VOLK LE37 17X7.5, SWIFT Springs, Bilstein B8, HKS intake duct, Cosworth Air Filter, HKS headers, PLM Over Pipe, EVS Down Pipe & Exhaust, FD 4.55, GFB pulleys, Axle-Exchange Drive Shaft, Mishimoto oil cooler, Cusco F&R strut bar, TRD door stabilizer, Innovate SC, Delicious Tuned
8686 is offline   Reply With Quote
Old 03-31-2014, 07:17 PM   #895
jebuwh
Village Idiot
jebuwh's Avatar
Drives: '13 FR-S Ultramarine Manual
Just got mine! Reading as we speak then headed to fill up with e85. Wooo!!!
jebuwh is offline   Reply With Quote
Old 03-31-2014, 07:29 PM   #896
Kodename47
Kodename47's Avatar
Drives: UK GT86
The cams need to test calibrate straight after an ECU reset. If you listen you can hear when they start to operate correctly. If you're doing it on a warm engine its about 20-30 seconds and really obvious after you 1st notice it.
You can also clear the accelerator pedal learning too by pushing the pedal through its full range 5 or 6 times while the ignition is on without the engine running.
.: Stealth 86 :.
Kodename 47 DJ:
The Following 2 Users Say Thank You to Kodename47 For This Useful Post:
Andrew025 (04-01-2014), steve99 (03-31-2014)
#lolwut, divinecomedy, dopeandcashcabinet, free shiv now, goddamitimissedit, golden cage, i missed the show, looks good, missed the fun, omgbbq, shiv 2016, thefatandthefurriest
Tablet on the dash ! TRD_86 Electronics | Audio | NAV | Infotainment 23 05-16-2015 04:48 AM
Tablet Install ThugNasty Electronics | Audio | NAV | Infotainment 4 04-13-2013 04:15 PM
Blutooth OBD II and a 9.7 tablet.. Scooby South Electronics | Audio | NAV | Infotainment 10 12-16-2012 09:11 PM
7.0 Tablet w/ Torque App Thatruth2001 Northwest 26 11-21-2012 12:53 PM
