#15 | |
Drives: fr-s
#16 |
Drives: 2013 Raven Scion Frs
Funny part is these transmission so "rated" to handle 300hp
#17 |
Drives: RAVEN
My gut feeling is that gearboxes are going to be an Achilles heel on these cars. They sure do hate the cold.
#18 | |
In Autobahn withdrawl
Drives: 2015 BRZ Limited Man., WRB
I'd also make an early gear oil change, in the rear dif as well, part of your break-in. Both have been dirty as hell for everyone draining them. |
#19 |
Drives: fr-s
I was using Pentosin MTF2 which worked great at solving cold operation issues until the ACT clutch mucked everything up. Ultimately, I'm going to dump this unit and go with some as of yet unidentified unit in the near future.
#20 |
Drives: 2013 Black BRZ Limited 6MT
New Trans is in.. seems smoother.. but time will tell. Is there any break in procedure I should use or just drive normal?
Zeta Stage 2 Drop In + Red Silicone Tubing || Zeta SS Cat Back || DC Sports Cat-Delete Front Pipe || Torque Pro + MiniOBD Bluetooth || Fumoto F-108 Drain Valve || Konig Daylite Gold 17x7 +40 14.2lbs || Anarchy Motive Shift Knob
![]() Future: Catted header, OEM Audio+ |
#21 | |
Drives: fr-s
Not really any break-in unless they changed the clutch too. I would be skeptical of the mtf they put in there. I know that Motul, Pentosin and RL MTL has worked better for others.. |
#22 |
Drives: Yes
I would think the same as the initial break-in... don't shift at too high of RPM's for a while, run it through all gears, engine-brake, etc. just to let all the teeth in each gear "mate" properly
"If thy pleaſure be in Underſteere, thou art Weird." - Distraxi
#23 |
Drives: Asphalt FR-S
New manual gearboxes come from Toyota pre-filled with factory fill fluid at the correct level. The auto's ship to us empty.
| Speeds at each gears. | mickey177 | Engine, Exhaust, Transmission | 10 | 08-25-2016 07:40 PM |
| fs: Perrin trans mount and whiteline trans bushing | RWD_FR-S | Transmission and Driveline | 1 | 01-02-2014 06:34 PM |
| You know what really grinds my gears...... | z3ro | Off-Topic Lounge [WARNING: NO POLITICS] | 7 | 10-10-2013 02:55 PM |
| 2nd gears a b*tch | Carbon420 | Scion FR-S / Toyota 86 GT86 General Forum | 32 | 01-29-2013 06:09 PM |
| Changing Gears | Naughty | AFRICA | 10 | 01-09-2013 01:30 PM |
