Old 03-18-2014, 09:18 PM   #365
8686
8686's Avatar
Drives: 86
Originally Posted by nelsmar View Post
How many miles since flash, are you, and what intake?
I have more than 200 miles since flash.
Drop in intake, Mishimoto intake tube, and HKS air intake duct that replace the snorkle
VOLK LE37 17X7.5, SWIFT Springs, Bilstein B8, HKS intake duct, Cosworth Air Filter, HKS headers, PLM Over Pipe, EVS Down Pipe & Exhaust, FD 4.55, GFB pulleys, Axle-Exchange Drive Shaft, Mishimoto oil cooler, Cusco F&R strut bar, TRD door stabilizer, Innovate SC, Delicious Tuned
8686 is offline   Reply With Quote
Old 03-18-2014, 09:21 PM   #366
nelsmar
I edited my post since you quoted me. Mind you this is looking a minor single incident FLKC which iirc subaru even considers "okay" but some tuners consider more on the aggressive side. It is not enough to pull the IAM for being considered major knock. Your AFR's honestly aren't that much richer than a lot of others, may just need to pull some of the upper voltage area down by a small percentage. I prefer turning of fuel trims for tweaking the maf and then re-enabling. They can swing up and down here and there and getting them to land consistently close to 0 is a bit of a task which is why its a good idea to keep on the conservative side of tuning with the LTFT enabled for WOT.
My flickr - Canibeat
Local magazine scout
The Following User Says Thank You to nelsmar For This Useful Post:
8686 (03-18-2014)
Old 03-19-2014, 03:12 AM   #367
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
v1.57 RELEASED
Hi guys,
v1.57 Maps released and available for download HERE
3/18/14
v1.57 Changes:
-Added full tuned map and XML support for A01N (EH 6MT) ROMs.
-Beta status removed
So unless you have an A01N ecu and have been waiting for new tunes, there is no reason to update from v1.56
Cheers,
Shiv
Shiv@Openflash is offline   Reply With Quote
The Following 3 Users Say Thank You to Shiv@Openflash For This Useful Post:
1Cor10:23 (03-19-2014), Captain Insano (03-19-2014), zc06_kisstherain (03-19-2014)
Old 03-19-2014, 01:28 PM   #368
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
Originally Posted by shiv@vishnu View Post
Hi guys,
3/18/14
v1.57 Changes:
Cheers,
Shiv
Any changes to the maps? My IAM has been getting dialed back unexpectedly under low load conditions. Starting to get really annoying.
Old 03-19-2014, 02:13 PM   #369
Shiv@Openflash
Drives: 2013 FRS
There are no mapping changes with the last release. Just added ROM support for N series ROMs.
If you have a log showing the the conditions your IAM is betting reduced, I may perhaps give you a suggestion of what to change in the map.
Shiv
The Following User Says Thank You to Shiv@Openflash For This Useful Post:
solidONE (03-19-2014)
Old 03-19-2014, 02:41 PM   #370
1Cor10:23
1Cor10:23's Avatar
Drives: '13 Whiteout FR-S (M/T)
We are still a while away from releasing the new maps. Currently working on them now. But still plenty of testing to do!
Quick suggestion - it would be pretty amazing if you guys do a development blog. Would be a great place to throw down your thoughts and prevent people from asking the same questions over and over again. It would definitely benefit the community as it will be a compilation of official statements from you guys, makes it a lot more manageable than flipping through massive threads. Perhaps also gives opportunity to shed some light on future developments.
I would subscribe to that ASAP
1Cor10:23 is offline   Reply With Quote
Old 03-19-2014, 02:52 PM   #371
wparsons
wparsons's Avatar
Possibly but have a look at the engine load at 15% throttle it can still be quite high in high gear low rpm driving . The other thing I found is it appears to be cumulative, if you only get one knock event (fbck generally) of greater than say -1 then its fine but get several in a relatively short period maybe a minute or two then you see IAM drop.
Would be good to know the exact logic ie x number of fbkc events greater than y value in time period z causes coarse correction, but its probably more complex. The stuff on RR is ok but its for WRX ECU so imagine may not apply totally to FA20
I can't pull FLKC, but I'll try to remember to get a log showing IAM and FBKC. It's pretty crazy how fast I an get the IAM to drop and climb. 5 minutes of stop and go driving and it's down under 0.70 easily, a couple good WOT blasts and it's up to 1.0 again.
flickr
steve99 (03-19-2014)
Old 03-19-2014, 03:17 PM   #372
Shiv@Openflash
Drives: 2013 FRS
Another release v1.58!
3/19/14
v1.58 Changes:
-Added full tuned map and XML support for 700I (EU 6AT) ROMs.
No mapping changes.
Old 03-19-2014, 03:17 PM   #373
Shiv@Openflash
Drives: 2013 FRS
That's do-able for sure. And a great idea. I'll talk to the boys and see what we can do. Thanks
Luckrider (03-19-2014)
Old 03-19-2014, 03:23 PM   #374
Luckrider
My Other Ride's a Jeep
Luckrider's Avatar
Drives: 2013 BRZ Limited
Give it a subscription feature with email notifications and commenting.
You know what, I am going to make my own Vishnu update blog with blackjack and hookers!
Luckrider is offline   Reply With Quote
The Following User Says Thank You to Luckrider For This Useful Post:
Shiv@Openflash (03-19-2014)
Old 03-19-2014, 06:12 PM   #375
wparsons
wparsons's Avatar
I did another Log this morning as adviced. The AFR look too rich after 5,500 rpm.
http://www.datazap.me/u/haririmm/155...ata=1-2-7-9-11
I did 3 runs starting in third and then shifting to fourth. Below video for the second run. Note, Speed is in KM/H
Appreciate your comments
First step, get your MAF scaled properly. You're working with some pretty huge trims in places. At WOT it's not bad, but at partial throttle they're pretty big. Each car is different, and the trims are keeping you safe, but ideally you don't want to rely on them. Nothing wrong with the tune, this is to be expected with canned tunes.
As for the AFR, that's a question more for Shiv. There's a decent gap between the AFR commanded and the actual AFR with a pretty small LTFT, not sure what his comments would be.
flickr
8686 (03-19-2014)
Old 03-19-2014, 06:18 PM   #376
Kodename47
Kodename47's Avatar
Drives: UK GT86
Remember that LTFTs are set by STFT occurances. There are no STFT in open loop operation so the LTFT at higher RPM will take longer to set in. Its another reason to target richer AFRs at the top end. IIRC the last LTFT area is set for over 60g/s operation.
.: Stealth 86 :.
Kodename 47 DJ:
8686 (03-19-2014)
Old 03-19-2014, 06:48 PM   #377
FRS_Jack
Duel Canister 2X the Fun
FRS_Jack's Avatar
Drives: 2013 scion frs
Shiv from 1.57 what kind of performance/stability changes should I see?
Thanks
3/19/14
v1.58 Changes:
No mapping changes.
Performance: Vishnu Tune, HKS Catback Exhaust, Revworks UEL Header, Perrin CAI/Inlet Hose, Cusco Front Strut Bar + MCB, Cusco Catch Can
Interior: Blox Titanium Shift Knob, Customer Name Badge
Exterior: Black-out Headlights, Redout Tail-light, 8K DDM HIDs, BlueBatMobile Foglight Overlays, Toyota Badged, 5 Axis Spoiler, 30%/70% tint
FRS_Jack is offline   Reply With Quote
The Following User Says Thank You to FRS_Jack For This Useful Post:
Jolaessss (03-19-2014)
Old 03-19-2014, 07:11 PM   #378
Shiv@Openflash
Drives: 2013 FRS
Thanks
None. There are no tuning changes. Just added ROM support.
OpenFlash Tablet Rombinhood@OpenFlash Software Tuning 1838 07-29-2023 07:35 PM
FS: Openflash Tablet Sgt.Beardface Engine, Exhaust, Bolt-Ons 8 01-04-2014 12:12 PM
FS: Openflash tablet nguyen_er Engine, Exhaust, Bolt-Ons 6 12-30-2013 01:31 PM
new OpenFlash tablet autobrz Engine, Exhaust, Bolt-Ons 5 12-23-2013 10:05 AM
WTB Openflash Tablet Vlady Want-To-Buy Requests 0 10-25-2013 01:10 AM
