Old 04-05-2013, 08:55 PM   #57
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Originally Posted by jmaryt View Post
keeping it in 6th (overdrive) most of the time will get you those results,as well as taking it out of gear and coasting to lights if possible,but truthfully,THAT can be a giant (p.i.t.a.)
All vehicles built in the last decade have fuel cutoffs to save gas, when you're coasting in gear the engine doesn't use and gas and your momentum powers the accessories. When you pull it out of gear the engine will have to use fuel to power the accessories (water pump, A/C, brake booster, alternator etc. etc.).
In addition fuel consumption is a function of rpm, load and throttle position; basically having your foot flat on the floor to accelerate in 6th gear is less efficient than downshifting and using half throttle in 5th or 4th gear and then upshifting when you reach the desired speed, it will also take less time.
The less time you spend accelerating and using the brakes the more efficient you will be.
ineedyourdiddly
Old 04-05-2013, 09:30 PM   #58
jmaryt
Drives: 2012 honda civic ex
i agree,and one must accelerate to reach 6th,and then,stay there without lugging the engine to achieve the best mileage. you should ''always" down shift to apply more power before shifting back into overdrive,as it is more efficient fuel wise to do so,and imparts "less" stress on the engine. this is true. also correct is less time spent accelerating,and braking creating kinetic energy,thus,burning fuel at a faster rate. again,being in "overdrive" as much as possible alleviates these concerns.
jmaryt is offline   Reply With Quote
Old 03-09-2014, 11:36 PM   #59
emantron
Drives: 2014 Scion FR-S
Just driving in no real hurry: I shift at 2,500
A little bit in a hurry/Im a little bored: I shift at 4,000-4,500 ish.
Having fun: I shift at redline
Someone just cut me off: I downshift.
emantron is offline   Reply With Quote
Old 03-09-2014, 11:40 PM   #60
Luis_GT
Nice thread bump!
Anyways
DD I shift at around 3K-3.5K
Road rage mode: 4.5 to 5.5K
Fun time: Redline limits ne
Old 03-10-2014, 12:01 AM   #61
cjsporl1996
Drives: WRB BRZ, Monte Carlo SS
To be honest i beat the crap out of my car. WOT out of every gear, shift at redline as long as I am not excessively going over the speed limit. I never get 25 combined which i drive on the highway and on the street almost everyday. But who bought a performance car for gas mileage anyway.
cjsporl1996 is offline   Reply With Quote
Old 03-10-2014, 08:29 AM   #62
regal
Drives: Scion FR-S/Toyota Yaris
Originally Posted by whaap View Post
For normal, round town driving I will down shift if I get down to 2,000 rpm's and I will up shift when I get above 2,500 rpm's. This would be conservitive driving by an old man which I am.
This is what I do, but the crank and rod bearing probably don't like that 2k rpm. I did notice a big improvement at low rpm with the Mazda 0w20 oil.
2013 FRS Argento Silver 6MT
Mods:
Clear fender side lights
Tactrix ZA1JB01C 2014 Calib
regal is offline   Reply With Quote
Old 03-10-2014, 04:41 PM   #63
Slow_86
Cpt. Slow
Drives: 2015 series.Blue
DD I shift between 2k-3k
Trying to enjoy my drive, 3k-5k
Rarely do i take it to redline. Maybe once a week.
Slow_86 is offline   Reply With Quote
Old 03-10-2014, 04:46 PM   #64
SloS14
SloS14's Avatar
Drives: 2013 FR-S whiteout
Hay guise. Who uses the front drink holder for hot beverages? I use the front drink holder but this guy at my school said you should use the rear cup drink holder for hot beverages because of science. What do you guys think?
Old 03-10-2014, 04:48 PM   #65
spyingwind
Drives: White '17 86
Top heavy drinks have a tendency to fly out of the holder under heavy breaking. Red light! Shit! *breaks hard* hot coffee all over the place.
spyingwind is offline   Reply With Quote
Old 03-10-2014, 05:11 PM   #66
Photonic
Drives: 2014 Premium BRZ
Originally Posted by 6-Shift View Post
Drop from 6th to 4th. If you REALLY need the power you can actually drop into 3rd if you're going right around 60 but if you're going 70 4th is best. The process is put in clutch, press on the gas so it revs around 5.5k or so and then move over into 4th. Quickly let the clutch out before the revs fall and keep on the gas to maintain the revs. It's a super quick shift and the quick rev is necessary to make you not lurch as much as the clutch re-engages. If you have an intake/exhaust it sounds godly too. It's fun to experiment with downshifting and upshifting. If you can start to learn where the rpm's are at each mph, you can downshift and upshift much easier while being an overall smoother driver too. Hope I helped.
yup ..from 45-57 you can really be in second gear from 5-7.4k..57mph = stock rev limiter warning in second gear at 7395.
Photonic is offline   Reply With Quote
Old 03-10-2014, 05:23 PM   #67
xxBrun0xx
xxBrun0xx's Avatar
Drives: 2014 WRB BRZ Limited
I don't shift. Just stay in second all the time. At 1600 miles now, no issues so far! You'll find if you don't shift, notchiness of the gears, difficulty shifting 1-2, and concerns about speeding on the highway are all non-issues!
xxBrun0xx is offline   Reply With Quote
The Following 4 Users Say Thank You to xxBrun0xx For This Useful Post:
civicdrivr (05-28-2015), strat61caster (03-10-2014), Tcoat (05-28-2015), zaptorque (07-22-2014)
Old 03-10-2014, 06:37 PM   #68
Squishy86
Squishy86's Avatar
Drives: Your Car
Bump from the dead much...
Squishy86 is offline   Reply With Quote
Old 03-10-2014, 09:32 PM   #69
Slysdexia
Slysdexia's Avatar
Drives: '14 Monogram 6MT FR-S - Hot Lava
The general rule as I've always heard it is 2500RPM or so for sedate driving, with 3500 or so for more acceleration.
In my cars I've always tried to keep it above 2k for anything but neighborhood puttering. It helps me stay in the band where I can get some response from the engine if I want it on a whim.
Slysdexia is offline   Reply With Quote
Old 03-18-2014, 02:24 PM   #70
6-Shift
Señor Member
6-Shift's Avatar
Drives: 2013 Raven, Drifty things
Funny story about this. I was driving home from work one day and had a 44oz drink in the middle cupholder because it wouldn't fit in the door cupholders. Well, I crest a hill and there's a huge cattle trailer pulling into this two lane highway. Naturally I slam on my brakes, but to my horror I watch as the cupholder, with the drink STILL IN IT, slow motion flies into my passenger footwell...Needless to say I was a little mad for the rest of the drive home...
T O U G E - C U L T U R E
Follow me on instagram! :@tougeculture_chris
'13 FR-S, SBD Turbo kit, Tein Flex Z coils, other stuff. Drifting and autocross.
6-Shift is offline   Reply With Quote
Saturday 3/23 DRIVE: Last chance to drive "The Most Dangerous Road in California" PMok Northern California 173 05-02-2013 03:11 PM
TGIF[R-S]: Can You Drive a Rear-Wheel Drive Sports Car All Year Long? No5ki Scion FR-S / Toyota 86 GT86 General Forum 27 01-06-2013 09:30 PM
How do you shift? Carbon420 Scion FR-S / Toyota 86 GT86 General Forum 27 12-30-2012 02:11 PM
Shift Knob yomchi1989 Cosmetic Modification (Interior/Exterior/Lighting) 0 12-07-2012 10:19 PM
Subaru BRZ First Drive Review by Automobile Magazine - "A Great Drive" Sport-Tech BRZ First-Gen (2012+) — General Topics 36 12-07-2011 04:13 PM
