Old 03-17-2014, 04:59 PM   #407
JDLAutoDesign
JDLAutoDesign's Avatar
Drives: 13 FRS
Originally Posted by scionsalesjay View Post
Any UEL headers in stock? I am running an innovate supercharger. Would the NA UEL headers be a good fit? I saw the Youtube video from MOTO-EAST with your UEL header and a few other exhaust mods. Impressed with your welds and collector work.
We should have stock in a day or so
JDLAutoDesign is offline   Reply With Quote
Old 03-17-2014, 05:25 PM   #408
JDLAutoDesign
Drives: 13 FRS
More heading to coating this evening for stock
Old 03-17-2014, 09:40 PM   #409
FR-S Matt
So upon torquing my header to 35 ft lbs, I have an exhaust leak on the upper part of the JDL overpipe and JDL header connection. Not sure how to flatten this out or if its warped. Using a Grimmspeed gasket as well.
Old 03-17-2014, 11:05 PM   #410
JDLAutoDesign
Drives: 13 FRS
If you loosen and re torque the head flange bolts you should also do the same for the over pipe. Make sure everything is aligned including the gasket
Old 03-18-2014, 12:29 AM   #411
FR-S Matt
I loosened it up and re-tightened. I noticed it was leaking previously due to the black soot on the top part of the gasket. I may try to just completely remove the overpipe and line it up again.
Old 03-18-2014, 10:38 AM   #412
DAN_BRZ
DAN_BRZ's Avatar
Drives: 2013 WRB BRZ Sport Tech
why are u using grimmspeed gaskets over just grabbing some new oem gaskets?
DAN_BRZ is offline   Reply With Quote
Old 03-18-2014, 11:03 AM   #413
Malt
Drives: 2015 WRX
Grimmspeed gaskets are MUCH better quality than OEM gaskets. If you have an exhaust leak, they may help with fixing the leak.
Malt is offline   Reply With Quote
The Following 2 Users Say Thank You to Malt For This Useful Post:
DAN_BRZ (03-18-2014), GrimmSpeed (03-18-2014)
Old 03-18-2014, 11:14 AM   #414
FR-S Matt
They're a lot thicker and you can see the quality difference in them. They should last over the years as well.
Think I'll be getting back under the car again today after work. I'm not convinced my overpipe is fully sealed to the header as I could feel a small gap with my finger even after tightening. I'll try to push up more on the overpipe before tightening to see if I can close that gap and end the small leak. I did torque the header to 35 ft lbs though starting with the front nut on the passenger side first, working my way back, then moving to the driver side. There was some soot around the flange on the overpipe I rubbed off and the top part along with the gasket. I'll try to get it as flat as I can against the header before tightening.
The Following User Says Thank You to FR-S Matt For This Useful Post:
Old 03-18-2014, 01:37 PM   #415
Jesse@JDLAutodesign
Jesse@JDLAutodesign's Avatar
Drives: 2013 Raven Black FRS
Thank you! We have 2 coated ones coming back in the next day or so instock. We will have uncoated ones by the end of the week in stock. I prefer the UEL over the EL in just about any application just by the sound alone. Let me know if you have any other questins!
Jesse@JDLAutodesign is offline   Reply With Quote
Old 03-18-2014, 02:38 PM   #416
DAN_BRZ
DAN_BRZ's Avatar
My uel just arrived, it got delayed beacuse of this never ending winter weather. too bad im at work, last half of my work day is going to drag on. Will post pics and my intial review when i get home tonight!!!!
The Following User Says Thank You to DAN_BRZ For This Useful Post:
JDLAutoDesign (03-18-2014)
Old 03-18-2014, 02:52 PM   #417
FR-S89
Hey,
I PM'd you for pricing
FR-S89 is offline   Reply With Quote
Old 03-18-2014, 03:06 PM   #418
Jesse@JDLAutodesign
Originally Posted by FR-S89 View Post
Hey,
replied
Old 03-18-2014, 03:08 PM   #419
Jesse@JDLAutodesign
I don't miss that one bit! Played a lot of hockey up you're way when growing up...Winters up there and Western NY are brutal...80's and sun here
Old 03-18-2014, 05:12 PM   #420
transition
Got the headers installed and the overpipe in. Just starting the front pipe installation although i'm noticing the side the connects to my Perrin catback (where the donut gasket goes) the OD of the front pipe where the donut gasket goes is bigger then donut ID. What donut gasket am i supposed to use here?
transition is offline   Reply With Quote
JDL Auto Design ft_sjo User/Vendor/Sponsor Reviews, Feedback, Comments 58 04-28-2017 11:13 AM
JDL Auto Design alexand3r User/Vendor/Sponsor Reviews, Feedback, Comments 4 12-11-2013 01:05 PM
New Scion FR-S products by Coverking are now at TAP Auto parts TAP Auto Parts Interior Parts (Incl. Lighting) 9 06-06-2013 08:43 AM
Check out some of the new products from Auto Finesse DetailersDomain Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 2 05-08-2013 09:42 AM
JDL Auto Design...What We Do JDLAutoDesign Announcements, Contests, Giveaways 21 10-30-2012 10:05 PM
