Old 03-12-2014, 06:09 PM   #561
glamcem
glamcem's Avatar
Drives: 2022 BRZ Limited
Originally Posted by normancw View Post
Cool track - I like the "corkscrew" section before the front straight! In another thread in the VS forum, you'll have to post a comparison of the Grand Sport vs Miata vs BRZ at the track.
I sure will. I didn't get a chance to take the Miata to track but I might be able to drive my buddy's prepped Miata for a few sessions ( he bought the same model year car ). I really liked the Miata but couldn't really fit in comfortably and lack of back seats for the kids ..since I am a big guy so wanted to try another light car so hopefully BRZ will do the task..
This is the same track with the EVO X GSR (stage 2 bolt-ons, tune etc) , it is a great track
[ame="https://www.youtube.com/watch?v=1L4lBsiCLBc"]https://www.youtube.com/watch?v=1L4lBsiCLBc[/ame]
glamcem is offline   Reply With Quote
Old 03-12-2014, 06:11 PM   #562
CSG Mike
CSG Mike's Avatar
Originally Posted by glamcem View Post
Yes I heard someone also mentioned as an oil heater but I don't think that is true. It is still sold as "Oil Cooler"
It is an oil heater. The primary purpose is to get the oil up to temp faster in cold climates; the turbo is oil cooled, and needs proper lubrication.
Old 03-12-2014, 06:48 PM   #563
tendogy
What could be considered as the dangerous operating oil temp for these cars?
I believe the ECU starts pulling your power above 240F. Am on mobile though, so can't double-check.
tendogy is offline   Reply With Quote
Old 03-12-2014, 07:47 PM   #564
OrbitalEllipses
Drives: Attitude
It functions as both a heater (arguably just as important!) and a coolor - and having it is better than having nothing. I don't think you can disagree with that, Mike.
The Following 2 Users Say Thank You to OrbitalEllipses For This Useful Post:
CSG Mike (03-12-2014), glamcem (03-12-2014)
Old 03-12-2014, 07:54 PM   #565
CSG Mike
CSG Mike's Avatar
Absolutely agree!
Old 03-12-2014, 07:58 PM   #566
OrbitalEllipses
Drives: Attitude
Absolutely agree!
And the car comes with nothing stock...
In any case, I'd prefer the "OEM" cooler in-line with an air to oil cooler if that makes sense. The problem with coolers is that they are too efficient (see: winter) and this engine already has a cold oil issue as well as a hot oil issue - either a higher temp thermostat, a piece of cardboard, or the two cooler solution I speak of is what I'd be interested in.
Or this cooler with a more efficient radiator would also work and be less complex while still providing both adequate cooling and heating.
glamcem (03-13-2014)
Old 03-12-2014, 08:07 PM   #567
CSG Mike
CSG Mike's Avatar
That's why a thermostatic plate is supplied with the Jackson Racing oil cooler; you won't overcool your oil
Old 03-12-2014, 09:02 PM   #568
Calum
That Guy
Drives: 2013 asphalt FRS MT
This is why I like the robispec style radiator/oil cooler. It's self regulating, doesn't require running hoses to the front of the radiator where they could be damaged by FOD, is efficient enough to cool both fluids, and should be a cheaper solution than a proper oil cooler and upgraded radiator.
I just don't know if I'll need one in my climate.
Sent from my samstone
Old 03-12-2014, 09:43 PM   #569
Ralph Spoilsport
Ralph Spoilsport's Avatar
Drives: 2013 BRZ, WRB
Just an FYI -- the Robispec is *not* self regulating.
OEM sandwich coolers are inside the thermostatic loop (and therefore temperature regulated). The Robispec is *out*side the loop. It's really designed for track. You could, I expect, use it with thermostatic sandwich adapter, but that's not what it comes with (at least last I looked).
Ralph Spoilsport is offline   Reply With Quote
The Following User Says Thank You to Ralph Spoilsport For This Useful Post:
Calum (03-12-2014)
Old 03-12-2014, 10:19 PM   #570
OrbitalEllipses
Drives: Attitude
By thermostat I meant thermostatic sandwich plate - what temp does it start bypassing?
Old 03-12-2014, 10:36 PM   #571
CSG Mike
CSG Mike's Avatar
I believe 185 is when it trickles open, but don't quote me.
Old 03-12-2014, 10:36 PM   #572
CSG Mike
CSG Mike's Avatar
It is, in the sense that it's regulated by the coolant...
Old 03-12-2014, 10:37 PM   #573
*LongFella
*LongFella's Avatar
Drives: 2014 Scion FR-S|Whiteout
You're correct. It's 185F. I remember asking over expresso
My 2014 FRS build thread: http://www.ft86club.com/forums/showthread.php?t=52071
“You might be poor, your shoes might be broken, but your mind is a palace.” - Frank McCourt
*LongFella is offline   Reply With Quote
Old 03-12-2014, 10:41 PM   #574
OrbitalEllipses
Drives: Attitude
Yeah, 185* is the same as the Mocal - will still be too cold in the winter.
jackson racing, jrsc, rotrex, supercharger, track
Kraftwerks Rotrex Supercharger Discussion nelsmar Forced Induction 697 01-18-2022 01:06 PM
Jackson Racing Supercharger Press Release and Info CounterSpace Garage Forced Induction 110 01-03-2017 10:04 PM
Jackson Racing supercharger NoppyNop Forced Induction 241 06-26-2014 04:05 PM
HKS GT Supercharger (Rotrex) in development! madfast Engine, Exhaust, Transmission 206 12-14-2012 04:28 PM
Jackson Racing FR-S Unleashed FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 3 11-18-2012 03:29 PM
