#85 |
Garden variety obsessive
Drives: 2009 Sti Hatch; 2015 Audi RSQ3
Ok, I've added to all roms on my Github repository:
https://github.com/TD-D/SubaruDefs/t.../RomRaider/ecu Remember, if you are downloading from here, make sure that you click on "raw" to get the actual XML (otherwise you will download an html page!) |
| The Following 4 Users Say Thank You to Td-d For This Useful Post: |
#86 |
Drives: UK GT86
I've made all rows the same using the lower ones as a template.
.: Stealth 86 :.
| The Following User Says Thank You to Kodename47 For This Useful Post: | troek (03-10-2014) |
#87 | ||
Drives: 2012 Toyota 86
#88 |
#89 |
yes this definitely made a difference, now im not afraid to start my car at 5 am lol. thanks. im runing all tables the same in the maf correction after start, 1400 rpm target idle, and reduced to -8 timing in the post start table. its a pretty significant change.
#90 |
#91 |
Drives: 2013 Asphalt FR-S
Any idea on the table logic for the post start maf correction? As in what the table actually does? Initially I thought it was just a post start reference or target value for maf g/s.
If this is a reference (initial estimated maf reading used for fueling right after it catches) then it would not make sense for this table to affect the cold start beyond the first second or so of the cold start. If, on the other hand, it is a maf target table used during cold start then it makes perfect sense and I would assume the ecu adjusts throttle plate angle to get the desired air flow. On 21*C cold start i see 18 - 19 g/s during the high idle cold start.
~Namaste~ |
#92 |
I'll dig into the logic but I don't believe it's a reference - that was already available as the post start airflow reference and the load reference tables.
#93 |
It's definitely an adder to MAF.
| The Following User Says Thank You to Td-d For This Useful Post: | mad_sb (03-12-2014) |
#94 |
Drives: Scion FR-S/Toyota Yaris
My car never idles over 900 rpm even if under 10F overnight. I'm hopefully about to buy BRZ edit, perhaps I could send my bin for those more familiar with these cars to compar (mine is a fall 2012 dealer flash.)
2013 FRS Argento Silver 6MT
Mods: Clear fender side lights Tactrix ZA1JB01C 2014 Calib |
#95 | |
#96 |
Thanks what about romraider?
#97 |
| Cold start question | retrosmiths | Scion FR-S / Toyota 86 GT86 General Forum | 106 | 11-15-2016 03:14 PM |
| Cold weather knocking during start ups. | JDMenrique | Issues | Warranty | Recalls / TSB | 38 | 01-13-2015 12:53 AM |
| backfire at cold start | FreaQshoQ | Scion FR-S / Toyota 86 GT86 General Forum | 15 | 10-16-2013 07:21 AM |
| White Smoke cold start up in Cold Weather (turbo cars) | whitefrs | Forced Induction | 17 | 09-25-2013 06:05 PM |
| Loud cold start and mpg drop since new | be6sti | Issues | Warranty | Recalls / TSB | 7 | 11-28-2012 02:35 PM |
