Old 03-10-2014, 01:38 PM   #211
CSG Mike
CSG Mike's Avatar
The question I ask, is are you spending $5000 for a faster car or $5000 for a prettier car? :p
The Following 7 Users Say Thank You to CSG Mike For This Useful Post:
ATL BRZ (03-10-2014), Deep Six (05-05-2014), MidnightRunner (03-10-2014), Powersfrs (03-10-2014), quality_sound (09-21-2014), ramiram1984 (03-10-2014), Sonolin (03-10-2014)
Old 03-10-2014, 01:39 PM   #212
utekineir
blowhard
Drives: frs, project forester
You'll attract more men with a faster car, and isn't that what we're all here for?
utekineir is offline   Reply With Quote
The Following User Says Thank You to utekineir For This Useful Post:
mit_peid (03-10-2014)
Old 03-10-2014, 02:03 PM   #213
CSG Mike
CSG Mike's Avatar
Nothing beats a GT-R for that.
Old 03-10-2014, 02:23 PM   #214
utekineir
blowhard
Bang for the buck seems kinda low
Old 03-10-2014, 04:02 PM   #215
PRORICAN
PRORICAN's Avatar
Both!
PRORICAN is offline   Reply With Quote
Old 03-10-2014, 04:10 PM   #216
OrbitalEllipses
Drives: Attitude
Old 03-10-2014, 04:34 PM   #217
mid_life_crisis
Drives: FR-S 10 #103 AT
uhm, Mike, are you coming out of the closet?
“Sex is like Bridge. If you don't have a good partner, you'd better have a good hand.” - Mae West
Papa said, "son there's a lot of evil temptations out there. Best to try 'em all so you know which ones to avoid."
mid_life_crisis is offline   Reply With Quote
The Following User Says Thank You to mid_life_crisis For This Useful Post:
Calum (03-10-2014)
Old 03-10-2014, 04:38 PM   #218
Mrpolarbear
Drives: 2013 DGM BRZ - MT
That's the kind of retard that will just see the bar graphs and go [buy] that despite the disclaimer.
I think it's brilliant then. More people will buy the JR kit and then we can have increased sample data to even out the smallest data set so far. (could be wrong, too lazy to check, but I thought all the other kits have sold more or at least more feedback posted here)
Mrpolarbear is offline   Reply With Quote
Old 03-10-2014, 06:22 PM   #219
glamcem
glamcem's Avatar
Drives: 2022 BRZ Limited
Originally Posted by tendogy View Post
The utekineir Addendum
Utekineir really really wanted the vortech idler/belt thread added to their pile, so here it goes!
That thread discussed two separate issues which resulted in belts breaking. First, some pulleys being shipped by Vortech were crappy; there was no final word on whether it was a bad batch or a bad manufacturer. Regardless, Vortech began shipping new, different pulleys in their kits.
The second issue was a pipe-rubbing clearance issues where the pipe going over the Vortech pulley was rubbing the pulley. Vortech responded by redesigning this pipe in their kit.
There were a total of 10 owner-reported incidents reported in posts 1, 7, 12, 17, 90, 108, 114, 125, 143 of that thread. Two of them (posts 12 and 124) were already accounted for in the compilation of the larger "discussion" thread. Again, I did not include nelsmar's issues because he states those were caused by fa20club and not Vortech.
Here is the revised chart for Total Number of Issues:
Vortech's bar has gotten substantially taller (heh) as they increased from 14 to 22 issues. They've been on the market the longest though, so how does it affect their issues-per-month (IPM) number?
Their IPM has increased from 1.17 to 1.80.
Innovate would need to go issue-free for roughly 5 months to match Vortech's revised IPM.
Kraftwerks would need to go issue-free until August 2015 to match Vortech's revised IPM. If you want to disregard the "lack of oil cooler solution" row, then they could catch up in July 2015!
Jackson Racing would need seven issues reported next month to match Vortech's revised IPM.
Ralph Spoilsport & normancw, you're welcome!
thanks for summarizing the data, I appreciate the time you guys took to come up with something like this.. It'd be also nice/beneficial if we knew the total amounts sold so that we can have another graph for error margins (percentage numbers of the issues to the actually sold amounts) maybe it's time to start a poll to gather more and more data..as someone also mentioned earlier, maybe the makers' willingness and the effort they put to overcome the QC issues are more important than the actual figures, in other words everybody makes mistakes but being in denial is the worst thing I could ever expect from a company
glamcem is offline   Reply With Quote
Old 03-11-2014, 01:25 AM   #220
mit_peid
Boosted Noob
mit_peid's Avatar
Drives: '13 FRS MT KW SC, '05 4Runner 4WD
I went to Kraftwerks directly with a list of my issues and it at least sounds like they're trying to address each one. I'm going to give them some additional time to get things right as I view most of them to be relatively minor.
mit_peid is offline   Reply With Quote
The Following User Says Thank You to mit_peid For This Useful Post:
Kakawate (03-12-2014)
Old 03-11-2014, 08:35 AM   #221
gmsii
gmsii's Avatar
Originally Posted by Coheed View Post
I'm on the fence because I see so many downsides to each setup. These may not be downsides to everyone, but here's what I don't like about each kit:
Vortech requires washer reservoir modification and doesn't work in cold temps.
Innovate doesn't provide top end power like the other kits. I am not a fan of the whine.
The kraftworks uses the cogged belt iirc. This will make it difficult to find a replacement?
JR kit uses stock belt but still takes a fluid that is way overpriced. WAY more overpriced than the Vortech system.
KW sells the replacement belts. You should note that if you had an issue with a belt, you would not be left stranded...you could just keep driving the car without boost until you get a new belt
gmsii is offline   Reply With Quote
Old 03-11-2014, 09:22 AM   #222
gmsii
gmsii's Avatar
i think this thread should be renamed 'BroScience Gone Wild!'
while i understand the good intentions of this thread, creating dyno graphs on interpolated data based on dyno runs of non-similarly modified vehicles and quality issue graphs based on only partial and self-admitted flawed data seems a bit misleading and irresponsible.
if you are going to compare dyno graphs in an overlay format...you cant use different cars...and you certainly cannot use different cars with different mods tested on different dynos.
if you are going to have a discussion about quality....shouldn't we take an emergency room approach and triage the issues? perhaps you can weight the issues factoring in 1)how easily and quickly can the issue be resolved 2)how catastrophic are the effects of the issue. certainly a mispackaged bolt is less serious issue than a design related issue that snaps belts and leaves you stranded by the side of the road.
i feel i can freely speak for KW when i say...
1) KW has and will continue to actively resolve any reported issues. customer service is very important to us. Seems like most of the 'issues' we have experienced are packaging related issues which result in inconvenience more than anything, nonetheless we deeply apologize for any inconvenience our packaging issues have caused or for any missed expectations in terms of service level. We are constantly taking corrective and preventative measures internally to improve our service and we stand behind our products.
2) an important point to note about the KW kit is that it is available with a you-tune big-blower C38 option that will easily make upwards of 400-500hp.
what is maximum possible upgraded hp with the other kits? and how much of their kit needs to be replaced to achieve that? KW just requires you to replace the blower and injectors+pump when you want to upgrade or you can just order it with the big blower option now if you wanted.
3) utlimately we are confident in the design, quality, and performance of our kit and we realize that time and happy customers will be the true test. my personal belief is that as time progresses you will see the KW kit gap the field. hopefully all the spin and misleading information in the BroScience gone wild thread wont color the views of the unsophisticated and uninitiated.
The Following 3 Users Say Thank You to gmsii For This Useful Post:
djdnz (03-11-2014), DriftinFRS (08-18-2014), themajesticone (01-20-2015)
Old 03-11-2014, 11:56 AM   #223
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Cool science bro.
Old 03-11-2014, 12:59 PM   #224
ATL BRZ
TEQSPORT Brand Manager
ATL BRZ's Avatar
Drives: '24 GR86 + '16 FR-S
The Following User Says Thank You to ATL BRZ For This Useful Post:
zdr93523 (01-06-2015)
Kraftwerks Supercharger Owners Thread projek_01 Forced Induction 4310 04-07-2025 02:12 PM
Kraftwerks Rotrex Supercharger Discussion nelsmar Forced Induction 697 01-18-2022 01:06 PM
Kraftwerks Supercharger kit-Now stocked at JRP Stav Canada Classifieds 4 05-27-2014 10:07 PM
Kraftwerks Supercharger?? umpadupa Forced Induction 1 08-05-2013 06:27 PM
Innovate and Vortech Acceleration Comparison Video 2 Dezoris Forced Induction 36 07-18-2013 10:32 PM
