#71 |
Drives: UK GT86
Sure thing. MAF Correction After Start x2- In Gear and Neutral (3d) Target Idle Maps x9 Ignition Timing after Starting Ignition Timing Idle x4 - 2x In Gear Above Threshold, In Gear Below Threshold, Neutral I've not touched the Idle air flow map or engine load map although I'm sure these should be dialled in. I just can't tie in the load to the air flow.
.: Stealth 86 :.
| The Following User Says Thank You to Kodename47 For This Useful Post: | troek (03-08-2014) |
#72 | |
Drives: 2013 Asphalt FR-S
I only played with the after start timing (set it to 0 rather than -15) and the 9 target idle tables. What I observed is that it overshoots the cold start idle by a large amount due to the extra 15 degrees of timing advance and then has to fight to bring the idle back down to where it should be, it may stabilize after a couple of cold starts. However, the Start of Injection table used during the cold start is NOT available yet with opensource tools and I suspect not in EcuTek either so the idea of just throwing an extra 15 or 30 degrees (if you set the after start to the post cold start base of 15 degrees advance) of timing advance with very late start of injection is not appealing to me. What we need is an on / off bit to flip to cancel the cold start routine. I suspect there is one, but if not we still need a couple more tables to have full control.
~Namaste~ |
#73 | |
Pick up a tactrix open port 2 cable and a free copy of techstream as a start, you can at least pull codes, code history, customize a few settings like drl's, seatbelt warnings etc, log all the obdII params etc etc. OP2 will work with all the opensource stuff, brzedit, and tech stream. You could also go the ecutek route if you want but the initial cost is MUCH higher. I also know someone selling their brzedit personal license, pm me if you want the details.
~Namaste~ |
#74 |
Drives: UK GT86
The MAF correction after start is the table that makes the real difference it seems. No codes have been turned off.
.: Stealth 86 :.
| The Following User Says Thank You to Kodename47 For This Useful Post: | mad_sb (03-09-2014) |
#75 |
Drives: 2012 Toyota 86
Do u still see injection at 45 degrees after youve modified this?
i also havnt been able to find the "maf correction after start" tables. anyone messed with the catalyst warm up tables under ignition ignition timing- compensation? Last edited by troek; 03-08-2014 at 09:19 PM. |
#76 | |
Drives: FT86
nope have not messed with them. If you give the accelerator a couple light taps it seems to speed up the process and it get out of the 1500rpm / ignition retarded idle faster. Although its pretty warm where I am so might not work in cold places. |
#77 |
Garden variety obsessive
Drives: 2009 Sti Hatch; 2015 Audi RSQ3
#78 |
#79 | |
Drives: UK GT86
Mode 1 is with the engine not running, 2 is the engine during cold start procedure.
.: Stealth 86 :.
#80 |
What values have u tried?
EDIT: I cant seem to find that table in RomRaider. Last edited by troek; 03-10-2014 at 03:18 AM. |
#81 |
I still need to implement these two tables. Will try today.
Sent from my iPad using Tapatalk HD |
| The Following 2 Users Say Thank You to Td-d For This Useful Post: | mad_sb (03-10-2014), Sportsguy83 (03-11-2014) |
#82 |
Ok, I've implemented into ZA1JA01C, download this definition:
https://raw.github.com/TD-D/SubaruDe...R_ZA1JA01C.xml |
#83 |
| The Following User Says Thank You to Td-d For This Useful Post: | mad_sb (03-10-2014) |
#84 |
@troek - what's your CAL id?
Nevermind, I've added to ZA1JA01A, here: https://raw.github.com/TD-D/SubaruDe...R_ZA1JA01A.xml Last edited by Td-d; 03-10-2014 at 10:54 AM. |
| The Following User Says Thank You to Td-d For This Useful Post: | troek (03-10-2014) |
| Cold start question | retrosmiths | Scion FR-S / Toyota 86 GT86 General Forum | 106 | 11-15-2016 02:14 PM |
| Cold weather knocking during start ups. | JDMenrique | Issues | Warranty | Recalls / TSB | 38 | 01-12-2015 11:53 PM |
| backfire at cold start | FreaQshoQ | Scion FR-S / Toyota 86 GT86 General Forum | 15 | 10-16-2013 06:21 AM |
| White Smoke cold start up in Cold Weather (turbo cars) | whitefrs | Forced Induction | 17 | 09-25-2013 05:05 PM |
| Loud cold start and mpg drop since new | be6sti | Issues | Warranty | Recalls / TSB | 7 | 11-28-2012 01:35 PM |
