go_a_way1
Old 02-19-2014, 12:58 PM   #2157
2point0
2point0's Avatar
Drives: '13 BRZ Ltd WRB
Originally Posted by Gps360 View Post
Need some help guys,
Will the wheels with 18x9 - 5x114.3 with offset 35 and 215/40/18 tires (all corners) will fit to my stock 2013 FR-S? Currently, the OEM wheels are 17 inch.
With these specs, will the wheels tuck in or perfect flush with the fender?
I am thinking putting the Eibach Pro-kit later.
Thanks.
These will not fit at all, since the bolt pattern is wrong. You need 5x100. You can use spacer adapters, but that effectively lowers the offset and it'll get ridiculous real fast. Or you could swap to 5x114.3 hubs, but I think they're hard to find now.
Otherwise, that size and offset has plenty of room and should be fairly flush with maybe a little poke out. See any of my multiple posts that state I had 17x9 +28 on stock suspension with 235/45 tires that run wider than normal, with no rubbing. I think you should put something wider than 215 on there, but I'm not into the stretch/poke thing.
Even with springs, I can't see any issues since Pro-Kit isn't that low.
2013 BRZ Limited - SOLD
2008 Forester XT Sports
1967 Mustang Coupe - 289 V8
2point0 is offline   Reply With Quote
Old 02-19-2014, 01:24 PM   #2158
Gps360
Drives: 2003 FR-S
Oh, I see. I will get the 5 x 100 instead.
Regarding the Eibach Pro-kit, do you guys use the stock shocks? Are the Pro-kit springs very hard? Will they damage the OEM shocks in the long run?
Gps360 is offline   Reply With Quote
Old 02-19-2014, 02:04 PM   #2159
Slick
Slick's Avatar
Drives: FR-S Firestorm 6MT
ProKit ride is excellent, stock shocks are up to the task especially for street driving.
Better damping is always better and Koni Sports are a great match for these springs.
I'm currently running the stock shocks but planning to upgrade soon as I do alot of track driving. They won't blow out the OEM shocks though.
Btw, the revised balance of the ProKit springs makes for a much more predictable drive, less tail-happy unless you induce it and very gradual shift. Love these. I'm even running them through the winter, no issues and better grip all around.
Slick is offline   Reply With Quote
Old 02-19-2014, 02:13 PM   #2160
Gps360
Drives: 2003 FR-S
What is the revised part number for the Pro-kit springs?
Old 02-19-2014, 02:25 PM   #2161
Slick
Slick's Avatar
Revised??
Part # is 82105.140
Old 02-19-2014, 03:15 PM   #2162
Gps360
Drives: 2003 FR-S
Originally Posted by Slick View Post
Revised??
Part # is 82105.140
Thanks.
Old 02-19-2014, 08:37 PM   #2163
Goodmanner
10 Series TRD
Goodmanner's Avatar
Drives: 2013 FRS 10 Series, 2013 IS250
Hello everyone! I really do appreciate this ongoing thread as it has been extremely informative! I plan on getting 18x8.5 +45 5x100 wheels -- what tire size would you all recommend? I currently have the Eibach Pro Springs installed so that's about a 1" drop on both front and back from stock.
Goodmanner is offline   Reply With Quote
Old 02-21-2014, 10:39 PM   #2164
Slick
Slick's Avatar
That's gonna be pretty close to the strut, don't think you'll make it fit.
I have about 4mm clearance, you'll be about 0 unless you have very mild camber settings but you already have a 1" drop so likely at -1.5 already. If it fits and doesn't touch the strut, then you will likely rub the tires on the inner fender liner on maximum lock.
Ideal offset fit that size wheel is +35 to +40 on coils. With coilovers you can run a higher offset (less poke, more tuck) but still not ideal anyway.
245/35R18 is the best tire size for that rim width.
Old 02-25-2014, 09:10 PM   #2165
gord1895
gord1895's Avatar
Drives: 2014 Lightning Red BRZ Limited
I have hit a wall trying to figure out what is going to clear on my car haha. I want an 18 inch wheel and since I am planning FI soon I need some more width. 8.5,9, 9.5...guess it depends what I can fin in the wheels I like. My car is on the pro kit springs on stock shocks and will be going to konis eventually. My biggest concern is I dont want rubbing but want to maximize width. What is a safe tire size and wheel width/offset with my suspension. Thanks a lot to the knowledgable guys on here because eve with my engineering degree I am still struggling to determine what will be best for me haha.
gord1895 is offline   Reply With Quote
Old 02-25-2014, 10:11 PM   #2166
Slick
Slick's Avatar
18x9 +35 done.
Can fit 255/35R18 square and even 265s in the rear if you want staggered (on your spring combo stated above.
Old 02-25-2014, 11:54 PM   #2167
gord1895
gord1895's Avatar
Really, so with being almost an inch lower and adding some camber and say a 245 tire all around the 18X9 +35 is a go? Thanks a bunch for some reason I was thinking I would either be rubbing the spring perch or sticking outside the fender a bit.
Old 02-26-2014, 09:22 AM   #2168
Slick
Slick's Avatar
That's exactly what I'm running: 18x9 +35 with 245/35R18. Fits perfectly, great stance, does not rub anywhere. I also track the car extensively with no issues.
I also added factory crash bolts in the front for a bit more camber (so wheel rim is a bit closer to the strut), so I'm running -2.2 up front and about -2.0 in the rear.
Old 02-26-2014, 05:54 PM   #2169
IAmNotTheDriftKing
IAmNotTheDriftKing's Avatar
Drives: I own an FR-S. . . whatelse!
Alright, so I have decided on a 17x9 wheel with a 42mm offset. I was wondering on stock suspension how much camber can you add before rubbing. I was hoping to get -1.5 degrees.
IAmNotTheDriftKing is offline   Reply With Quote
Old 03-03-2014, 12:25 PM   #2170
terenshu
Drives: rav4
Hey guys! 18x8.5 with 245/35 tires 1.5 inch drop, Safest offset? Just would like to know.
Sent from my Diamond V7 using Tapatalk
terenshu is offline   Reply With Quote
Determining the proper width size of the tire CyberFormula Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 49 05-23-2014 10:11 AM
Correct tire width for each wheel width DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 08-16-2012 03:03 PM
TIRE SIZE CALCULATOR White64Goat Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 08-15-2012 03:31 AM
Tire Width vs Wheel Width Synack Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 40 08-13-2012 12:21 AM
