Old 02-22-2014, 12:06 AM   #1
StormTrooper
StormTrooper's Avatar
Drives: Pavement MT GR86
Koni inserts.....
Does anyone sell the inserts already in Stock housings for the front?
GR86 MT premium
StormTrooper is offline   Reply With Quote
Old 02-22-2014, 12:19 PM   #2
FastWhite
Drives: Subaru BRZ Limited M/T
Try Turn In Concepts. I remember reading that a member here bought a set already done.
FastWhite is offline   Reply With Quote
The Following User Says Thank You to FastWhite For This Useful Post:
StormTrooper (02-23-2014)
Old 02-22-2014, 12:36 PM   #3
Grimlock
Grimlock's Avatar
Drives: BRZ and NA
Yep. TIC sent me my Koni inserts in housing pre-made. That way I have the originals to swap back into the car if necessary.
Grimlock is offline   Reply With Quote
The Following 2 Users Say Thank You to Grimlock For This Useful Post:
StormTrooper (02-23-2014), suaveflooder (02-22-2014)
Old 02-23-2014, 01:09 AM   #4
StormTrooper
Was that a custom order? Didn't see any options for the koni inserts or rce Springs for stock housings.
GR86 MT premium
Old 02-24-2014, 02:59 PM   #5
Grimlock
Grimlock's Avatar
Drives: BRZ and NA
I don't think it was a 'custom' order. They were advertising it in thread here on the forums. It may have been one of those 'sales' threads that has since been deactivated (since I can't find the thread searching now).
I do have a review thread from last year where I mentioned it: http://www.ft86club.com/forums/showt...+concepts+koni
I don't have the paperwork in front of me, but I want to say that the shock bodies plus installation was an additional $300. I could be wrong, though. Your best bet is to give them a call and ask. I know using a telephone these days is scary, but they are seriously good guys.
EDIT: Here's a post where TIC mentions it: http://www.ft86club.com/forums/showp...5&postcount=22
Old 02-24-2014, 03:07 PM   #6
OrbitalEllipses
Drives: Attitude
I bought new front strut housing from TIC that were pre-cut with the inserts already inserted. Unfortunately, one of the front inserts was leaking on adjustment from the factory and I had to RMA it. Aside from the extended wait from Koni's warranty team, I enjoyed that I didn't have to cut stock strut housings and now have a backup set to use if anything ever happens.
Is it worth $300? Well that depends how much your time is worth to you. Two new housings ain't exactly cheap, but the labor on cutting isn't "intense" - it just made sense to me to go that route as I didn't have the cutting tools or a place to cut (and vent the fluid).
Old 02-24-2014, 04:49 PM   #7
StormTrooper
The rears are just a swap right? No cutting?
So if I can find this I would be out 1k instead of the 750ish. And still need/want Springs.
GR86 MT premium
Old 02-24-2014, 04:54 PM   #8
mrk1
Drives: Sterling BRZ Ltd
rears just require a bit of drilling on the top hats to allow the thicker threads to come through. Other then that straight in.
The Build Thread
GT28RS - eBoost2 - 3.91 Final Drive - Supra LSD
mrk1 is offline   Reply With Quote
Old 02-24-2014, 05:30 PM   #9
husker741
Drives: 2013 Whiteout Scion FR-S 6MT
Look at the Bilsteins. They aren't inserts.
husker741 is offline   Reply With Quote
Old 02-24-2014, 05:45 PM   #10
OrbitalEllipses
Drives: Attitude
^ If the Bilsteins were out when I bought the Konis...I'd have bought the Bilsteins instead.
Yep, that's it. Just insert a drill bit to enlarge the through-hole. If you have the space (or can get it) and the tools (or can get them) and have done woodwork or tile you can do the cutting - I just preferred to have replacement dampers in case something happened.
DIY: Cutting OEM struts (front) for Koni Yellow inserts mit_peid DIY (Do-It-Yourself) Guides 25 06-20-2014 01:16 PM
Update on Koni inserts Turn in Concepts Suspension | Chassis | Brakes -- Sponsored by 949 Racing 25 06-18-2014 05:39 PM
koni inserts vs budget coil overs StormTrooper Suspension | Chassis | Brakes -- Sponsored by 949 Racing 29 08-23-2013 05:21 PM
KONI Inserts - Installation Advice? autoXracer Tracking / Autocross / HPDE / Drifting 15 06-16-2013 04:36 PM
Koni inserts or wait for full Koni replacements Mango22 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 18 05-18-2013 06:48 PM
