Old 02-19-2014, 03:16 AM   #169
SirBrass
Trust me, I'm the Doctor
SirBrass's Avatar
Exactly. All the power on the bottom means you spin your wheels and then have no power to haul off.
3k is reached VERY fast. 2-3k is excellent for cruising and efficiency, so having not so much power there is good for maintaining fuel economy for a DD'd FI car. Want the power, then drop gears and keep above 4k.... assuming the tune (whether with FI or staying NA) and exhaust has eliminated the torque dip.
Debating between the KW and Vortech. I don't want to build the engine, and I don't want to keep climbing a power mountain whenever I upshift, but I don't want the power to give out a full 1-1.5k rpm before redline.
Maybe Vortech with smallest pulley offered that keeps the blower's revs within the 50k spec?
Innovate really should have put a blower on there that can keep up up top. They picked the better blower design but didn't use enough of a blower.
^GT5 Replay Photo Mode^
Old 02-19-2014, 03:35 AM   #170
Kodename47
Kodename47's Avatar
Drives: UK GT86
Its not really innovate is it, seeing as they don't manufacture the kit.... Oh, and they do have a new blower coming that will equal the others
.: Stealth 86 :.
Kodename 47 DJ:
Old 02-19-2014, 03:36 AM   #171
SirBrass
SirBrass's Avatar
We'll just have to see when they finally come out with it and when someone properly dynos it with a tune.
Old 02-19-2014, 04:49 AM   #172
Coheed
Coheed's Avatar
Drives: DGM BRZ Limited
I'm on the fence because I see so many downsides to each setup. These may not be downsides to everyone, but here's what I don't like about each kit:
Vortech requires washer reservoir modification and doesn't work in cold temps.
Innovate doesn't provide top end power like the other kits. I am not a fan of the whine.
The kraftworks uses the cogged belt iirc. This will make it difficult to find a replacement?
JR kit uses stock belt but still takes a fluid that is way overpriced. WAY more overpriced than the Vortech system.
Coheed is offline   Reply With Quote
Old 02-19-2014, 04:54 AM   #173
shaunsweeney
shaunsweeney's Avatar
Drives: 2014 FR-S MT Asphalt Grey
Innovate with the rumored upgraded blower is the only one I'm truly interested in at this point.
shaunsweeney is offline   Reply With Quote
Old 02-19-2014, 12:09 PM   #174
CSG Mike
CSG Mike's Avatar
It uses a fluid that you change every 50k miles. 50,000. Works out to... 0.2 cents per mile, ($0.002 dollars per mile)
Your engine oil will work out to a higher cost per mile than that, even using the cheapest oil available.
CSG Mike is online now   Reply With Quote
The Following 4 Users Say Thank You to CSG Mike For This Useful Post:
ATL BRZ (02-21-2014), SkAsphalt (02-20-2014), sklimo (02-19-2014), Sonolin (02-19-2014)
Old 02-19-2014, 12:50 PM   #175
evo4g63
evo4g63's Avatar
Drives: 2016 Subaru WRX
The Innovate stg2 w/ 70mm pulley, header, exhaust, e85 and a good tune will surprise you quite a bit I think
-2016 Subaru WRX
-2013 Scion FR-S: Wastegated Vortech V3'd, E85 SOLD
evo4g63 is offline   Reply With Quote
Old 02-19-2014, 12:54 PM   #176
xwd
Sprintex does have the new 210+ kit coming shortly and of course the 335 which is a huge blower for this car. I think the 210+ kit will put it in the same ballpark as the centrifugal kit while keeping the flat torque curve, and of course the whine. The 335 will eclipse any other superchargers out now but it's going to require good gas and for longevity a built engine.
Old 02-19-2014, 01:14 PM   #177
utekineir
blowhard
Drives: frs, project forester
that could be said about any of the kits with header, exhaust, e85 and a good tune.
utekineir is offline   Reply With Quote
The Following 3 Users Say Thank You to utekineir For This Useful Post:
CSG Mike (02-19-2014), mashal (02-19-2014), tendogy (02-19-2014)
Old 02-19-2014, 04:07 PM   #178
tendogy
Innovate stg 2: $4195
70mm pulley: $65
Header: $600
Exhaust: $855
Tune: $500
Inconvenience of E85 for most people: priceless
tendogy is offline   Reply With Quote
The Following User Says Thank You to tendogy For This Useful Post:
Shiv@Openflash (02-19-2014)
Old 02-19-2014, 05:10 PM   #179
SirBrass
SirBrass's Avatar
That's understating the price of a good quality header by quite a bit, actually.
The Following User Says Thank You to SirBrass For This Useful Post:
shu5892001 (04-15-2015)
Old 02-19-2014, 10:02 PM   #180
Coheed
Coheed's Avatar
Originally Posted by vgi View Post
how so?
vortech: 4oz, 3 bottles, $31.95 - 1 bottle per fill (fill every 7.5k), $70 for 50k
rotrex: 1L, 1 bootle , $99.99 - 3/4 per fill (fill very 50K), $75 for 50k
The problem here is that several people have had to remove the system for a plethora of reasons. Any time the system is serviced, removed, disconnected etc, it's going to lose fluid and cost money to replenish. Unless, of course, you are really lucky and never have to remove the supercharger or have the possibility of losing fluid. If you can go a full 50k miles and be lucky enough to only go through one bottle, that's fantastic.
But it is a risk you take with either of these setups.
Old 02-19-2014, 10:40 PM   #181
OICU812
Just a dude
OICU812's Avatar
Drives: Scion FR-S 2013
I gotta say unless you're doing a world tour challenge why would the price of the SC oil be a real concern? By time your deep into FI those are just items where you're tripping over nickels trying to save dollars you've long past anyhow?? Just saying.
The Following 3 Users Say Thank You to OICU812 For This Useful Post:
shaunsweeney (02-20-2014), SirBrass (02-20-2014), SkAsphalt (02-20-2014)
Old 02-19-2014, 10:41 PM   #182
OICU812
Just a dude
OICU812's Avatar
Ya by like half??
The Following User Says Thank You to OICU812 For This Useful Post:
Kraftwerks Supercharger Owners Thread projek_01 Forced Induction 4310 04-07-2025 02:12 PM
Kraftwerks Rotrex Supercharger Discussion nelsmar Forced Induction 697 01-18-2022 01:06 PM
Kraftwerks Supercharger kit-Now stocked at JRP Stav Canada Classifieds 4 05-27-2014 10:07 PM
Kraftwerks Supercharger?? umpadupa Forced Induction 1 08-05-2013 06:27 PM
Innovate and Vortech Acceleration Comparison Video 2 Dezoris Forced Induction 36 07-18-2013 10:32 PM
