Old 02-10-2014, 03:05 AM   #155
h4nh
h4nh's Avatar
Drives: Turbo BRZ & Supercharged E90 M3
Originally Posted by Drift&Drag View Post
Very nice clean build Hanh! I'm here in Dallas too. Do you every go to any of the meets such as the Coffee & Cars meet?
I made it out to one of them with this car, but the weather has been shit lately and my car is taken apart half the time.
The local meets are all stock cars the past few times I've been so I'm not really interested. I might as well go park my car at the Subaru dealership. lol
The only meets I really go to is with my friends and we actually go drive our cars instead of stand around in a parking lot.
h4nh is offline   Reply With Quote
The Following User Says Thank You to h4nh For This Useful Post:
akahenry (03-18-2014)
Old 02-10-2014, 10:17 PM   #156
Drift&Drag
TURBOLICIOUS
Drift&Drag's Avatar
Drives: a machine :]
I totally know what you mean! I have been out of the scene for a while but jumping back in. I definitely do not want to waste my time with lame meets lol ... Just sent you a message.
Drift&Drag is offline   Reply With Quote
Old 03-01-2014, 07:55 PM   #157
h4nh
h4nh's Avatar
So here's a lil update. After installing the Ohlins suspension I wasn't happy with the ride height and almost sold it off. I really liked the ride quality of it so I tried to figure out a solution to make it lower. The gap in the rear was so bad it looked almost like factory springs. Anyways I did my research and didn't find anything. I looked around for different camber plates and top hats and ended up with the HVT front adjustable camber plates / Raceseng rear top hats. After playing around with the bearing configurations I got it to work!
This was after the Ohlins was installed.
Another shot of the rear to show how high it really was.
Trying to figure out how this is going to go together. I ended up not using the bearing and silver hat piece from the HVT set up.
I ended up using the bearing that came with the ohlins on top of the ohlins hat instead.
Final set up for the front.
Ohlins rear piece.
I used the thicker bearing from the top portion and brought it down here. Then the spacer from the Raceseng set up placed above that.
This is how much lower it went with the Raceseng rear top hat.
I move the thinner bearing that was on the bottom to the top. Then the black nut above that.
Installed. The front has more room the go lower. Maybe another 1/2 inch to an inch. The rear is maxed out here.
Here's a shot in the day light. I still need to either raise the back up or lower the front a lil more.
Old 03-01-2014, 08:02 PM   #158
Acree
Acree's Avatar
Drives: 13 CSB BRZ Ltd
Absolutely fucking ridiculous what you had to go through to get a $3k setup to work. I'm glad Brian could get you setup with a proper set of plates. Looks great.
Andrew
2011 BMW M3 (No torque dip)
2013 Subaru BRZ - SOLD - Build Thread
Acree is offline   Reply With Quote
Old 03-01-2014, 08:07 PM   #159
h4nh
h4nh's Avatar
Andrew
Thanks bro, I ended up buying the plates from FT86 speed factory since they had them in stock.
I'm just glad it worked out the way I wanted it to and didn't give these ohlins away lol
Old 03-01-2014, 08:19 PM   #160
h4nh
h4nh's Avatar
I lied.. I went to cars & coffee this morning. LOL. It was good weather though.
http://www.ft86club.com/forums/showthread.php?t=59587
Old 03-01-2014, 08:53 PM   #161
OICU812
Just a dude
OICU812's Avatar
Drives: Scion FR-S 2013
Turned out great!
Well I'm glad you figured out a way vs sold em, I was sure wishing I could've got em from ya lol. But....now you got it setup where you have the height you want and a great quality comfortable ride. IMO that's win win really. The day I can get ohlins I'll likely be looking at similar ideas. I have stance lca so that drops a full inch on back and for front was thinking of ground control tops
With what you did use here no clunks or oddities at all?
Old 03-01-2014, 09:10 PM   #162
h4nh
h4nh's Avatar
Originally Posted by OICU812 View Post
Turned out great!
No clunks. It rides perfect so far. I will test it out further at the track at the end of the month. I got some more stuff going on for the car next few weeks
Old 03-01-2014, 10:02 PM   #163
ZionsWrath
Thanks
ZionsWrath's Avatar
how is the AVO turbo performing? Any issues tracking or street?
Are you running an oil cooler and/or bigger radiator?
I like the kit a lot not sure what FI route I want to go yet though...
Old 03-01-2014, 10:51 PM   #164
h4nh
h4nh's Avatar
Yeah it runs fine. It didn't over heat at the track. My cooling system is still oem.
4500 miles on it so far and it's okay so far.
ZionsWrath (03-01-2014)
Old 03-02-2014, 02:01 AM   #165
h4nh
h4nh's Avatar
Update. I just lowered the front just to see how low it'll go.
Max low in the front now.
Disregard the ghetto ebay led license plate light that went out. lol
This the max low on the new set up. I'm pretty happy with it now. The rear is 1/8 inch lower than the front. I'll probably make some adjustments later and get it aligned.
Old 03-02-2014, 02:12 AM   #166
AznKirby
Are you 20/20?
AznKirby's Avatar
Drives: Hopes and dreams
Perfect height! Not too low, not too high.
2014 FR-S Monogram
2005 Acura RSX Type-S
IG: @MonKehC
Old 03-02-2014, 02:30 AM   #167
Dezoris
Dezoris's Avatar
The reason the Ohlins do not go lower is because the dampers already have a short stroke. Dropping it lower, not a good thing.
I like a lot of this build, though.
Old 03-02-2014, 02:38 AM   #168
AznKirby
Are you 20/20?
AznKirby's Avatar
^ Oh shit, it's savagegeese.
I watched most of your reviews. Good stuff!
2014 FR-S Monogram
IG: @MonKehC
The Following User Says Thank You to AznKirby For This Useful Post:
Dezoris (03-02-2014)
White Smoke cold start up in Cold Weather (turbo cars) whitefrs Forced Induction 17 09-25-2013 06:05 PM
Turbo, white smoke out the exhaust, ideas? Synack Forced Induction 44 09-09-2013 10:57 AM
Green light for Nissan GTR R36 Giccin Other Vehicles & General Automotive Discussions 39 06-05-2013 02:48 PM
Would FB Green or Red fit any existing kit? HighLife Forced Induction 17 01-04-2013 06:18 PM
CBS FRS at Green Toyota Integratedfool Great Lakes 0 06-25-2012 01:24 PM
