Old 01-31-2014, 11:31 AM   #29
gdrider77
gdrider77's Avatar
Drives: Subaru BRZ Limited
Originally Posted by mkivsoopra View Post
Ok, so I did a bunch of testing with the ScanTool OBDLink SX.... it's better, but not perfect. It's noticeably faster than the generic one I had, but it still pauses once in a while. I've actually never used a bluetooth ELM327, so I'm not sure how it compares. Is this normal?
I have the bluetooth one right now on my nexus7, and there is no pausing. Pretty responsive. I was going to go the nexus7 route, but i really like knobs and buttons for certain features, plus i was hoping the usb connection would be even faster. This sounds like overall its slower and more glitchy. I also have the replacement leds for this so i can change the color to red/orange instead of the green. If i dont use them i can send them your way should you want them.
Now im not sure what to do, maybe just cancel this and stick with the nexus 7.
I have a aem failsafe for boost and afr, so thats good and fast. I just wanted the torque for oil pressure oil temp, etc...so maybe this would still work.
gdrider77 is offline   Reply With Quote
Old 01-31-2014, 12:37 PM   #30
mkivsoopra
For slow-moving numbers, it should be fine. If you do cancel the order, I'll be happy to take those LEDs off your hands. I was planning to swap them eventually anyway.
mkivsoopra is offline   Reply With Quote
Old 01-31-2014, 12:54 PM   #31
gdrider77
gdrider77's Avatar
So are you saying the tach is worthless, same as mph? I really mostly wanted it for coolant temp, oil temp, oil pressure, so it should work fine for that correct? Are those working ok for you?
Old 01-31-2014, 01:05 PM   #32
mkivsoopra
Yeah, I'd use the the stock gauges for those things anyway. With Torque and the USB ELM327 on this unit, when it's working, it's fine. It'll work for a few minutes then maybe pause for 3 seconds or so, then resume. For temperature stuff, it's fine. Everything else.....
Also, Torque isn't able to measure anything accelerometer-related. I haven't figured this one out yet.
Old 01-31-2014, 01:15 PM   #33
gdrider77
gdrider77's Avatar
hmm.thats not sounding too positive. In Torque i am able tuse the acceleraomter on the nexus 7 and it works fine, can read 0-60, 1/4 mile, etc...
Maybe this is just not the right head unit for me.
Old 01-31-2014, 02:30 PM   #34
mkivsoopra
I have a feeling there's no accelerometers in the unit, since it's not meant to be rotated in portrait/landscape positions. I'll have to look into it some more.
Old 01-31-2014, 11:02 PM   #35
sciallo
Drives: 4 wheels and a steering wheel
I can confirm, these units don't have accelerometer
sciallo is offline   Reply With Quote
The Following 3 Users Say Thank You to sciallo For This Useful Post:
amram (04-06-2014), gdrider77 (02-01-2014), mkivsoopra (02-01-2014)
Old 02-01-2014, 01:19 AM   #36
gdrider77
gdrider77's Avatar
thats what i figured. Sucks. I already canceled my order..at least i emailed them a cancel order request, hopefully they will cancel it sand refund my money...
Old 02-01-2014, 03:54 AM   #37
mkivsoopra
That's too bad... Could've been so useful.
Old 02-01-2014, 12:29 PM   #38
sciallo
Yeah, I would love it if we could figure out a way to let the unit use the accelerometer from the phone as if it was it's own, maybe through a tethering app or exposed module, it should be possible in some way...
Old 03-08-2014, 01:14 PM   #39
Brody602
Drift King
Brody602's Avatar
Drives: '13 Firestorm FR-S 6MT
Originally Posted by pixel67 View Post
But it still has green led... Bummer
Sent from my Nexus 7 using Tapatalk
I found this unit, http://www.tradesolution.hk/e/ptxweb...duct/1193.html
It runs the new android firmware, not sure of LED colors but from previous experience when they aren't lit up in the picture they're normally orange, a simple email to the company would answer that question, also it says it supports OBD, (the have an optional obd dongle for 45$) not sure if any dongle can be used with it or only the one they sell?
@nzer @coyote @Trap63 this might be of interest to you guys
'13 6MT Firestorm FR-S
Brody602 is offline   Reply With Quote
The Following 3 Users Say Thank You to Brody602 For This Useful Post:
coyote (03-08-2014), nzer (03-08-2014), Trap63 (03-08-2014)
Old 03-08-2014, 02:06 PM   #40
nzer
nzer's Avatar
Drives: 2012 Grey TRD GT86, 2015 VW Golf R
Good find and very interesting. Could be the perfect solution.
I won't be trying it as have mine all sorted and very happy with it running carscope with my HKS OB-LINK.
It needs so other brave soul to be the first person to try one.
nzer is offline   Reply With Quote
Old 03-08-2014, 02:16 PM   #41
Brody602
Drift King
Brody602's Avatar
I have yet to pull the trigger on a unit as I decided to wait through the winter months to see if something new and improved came out since my car is parked anyways.. Sure enough the T7019A has new brains , I will probably email tradesolution shortly to ask if they can send me a picture of the "obd dongle" and what color the led's are, and if our own dongles can be used instead, the only downfall to this one being that it only has 512mb of ram and the possibility that it will only worth the supplied obd dongle. I'm not sure if 4.0+ requires more to run smoothly as compared to 2.3?
Edit: Sent them an email, curious to see if they will send me a picture of the dongle.
Old 03-08-2014, 05:09 PM   #42
Trap63
Trap63's Avatar
Drives: Brz WRB - Europe LHD
that's fine. The only issue might be low ram, but OS 4.0 will run faster so a memory refresh could be attractive rather than to get onboard more memory but not speeder.
About dongle...ask for Torque Pro compliance, if positive maybe a good bargain this one!
T7019A Specs:
Main CPU:MST786 A9 dual core 1Ghz
RAM Memory DR3 1G
iNand Memory:8GB
IMHO the 7019A is a best buy.
Trap63 is offline   Reply With Quote
The Following User Says Thank You to Trap63 For This Useful Post:
Brody602 (03-08-2014)
Android Head Unit - LED Colour Change - T7019A (and TUN21A) Tech DIY (Do-It-Yourself) Guides 57 10-11-2013 12:10 AM
T7019A Android 2.3 Unpacking Trap63 Electronics | Audio | NAV | Infotainment 18 09-19-2013 01:42 PM
FS: T7019A Android Head Unit pheoxs Audio/Visual, Electronics, Infotainment, NAV 4 08-26-2013 06:05 PM
DIY - External microphone for Android HU - (T7019A) Trap63 DIY (Do-It-Yourself) Guides 6 08-20-2013 09:00 AM
Android Head Unit - LED Colour Change - T7019A (and TUN21A) Tech Electronics | Audio | NAV | Infotainment 2 07-18-2013 07:17 PM
