Old 01-21-2014, 07:18 PM   #85
milkesfrs
milkesfrs's Avatar
Drives: hot lava
Originally Posted by 914_WHITE_FRS View Post
okay I understand, now do I have to get 2 of these?
Yes. I used 2 of them.
milkesfrs is offline   Reply With Quote
Old 01-21-2014, 07:49 PM   #86
phanguy
phanguy's Avatar
Drives: Scion FR-S Ultramarine
people are refusing to actually read through and comprehend this thread. not to rush you, but the sooner you write up the diy the sooner you can just tell people to refer to the first post. i've seen you answer the same question like 100 times now. it's painful. i do appreciate your patience though!
phanguy is offline   Reply With Quote
The Following 2 Users Say Thank You to phanguy For This Useful Post:
MaXimus (02-29-2016), milkesfrs (01-22-2014)
Old 01-22-2014, 06:04 PM   #87
milkesfrs
milkesfrs's Avatar
Drives: hot lava
My FRS got hit and its in the body shop. Once I get it back and its not to cold out I'm going to make a step by step Youtube video on how to install the Advanced Keys . It might be a 10 step video but a nutless monkey would be able to install it if they follow the video instructions. Every wire and wire location will be covered.
Old 01-22-2014, 08:20 PM   #88
phanguy
phanguy's Avatar
Damn sorry to hear man. Hope you're okay.
Old 01-23-2014, 04:25 PM   #89
MemphisR
Memphis
MemphisR's Avatar
Drives: 1989 MR2 S/C, 2014 Scion FR-S
Anyone thought about my question? ^^^
"It's ok... It's not structural."- Mikey
MemphisR is offline   Reply With Quote
Old 01-23-2014, 04:47 PM   #90
phanguy
phanguy's Avatar
Originally Posted by MemphisR View Post
So I have a question that may seem stupid until you finish reading and look at the video. So I was watching SubaruWRXFan's YouTube channel and I noticed that the monogram series he was reviewing had the push start. We all know this. But what is interesting is that it still had our ignition slot in the steering column uncovered and with the red ring we have. Now I was wondering if it is possible that Toyota/Scion may have wired the 2014's to still take the factory system with minor mods just light the fog lights? Thoughts?
Here is the link:
you seemed to answer your own question? i mean realistically that's exactly what they did. that's how a lot of companies sell products. do the r&d to make the first one to sell. the next year they make incremental changes and call it something new and raise the price even though it costs them nearly nothing in r&d to do. no way that there is a whole new system in the 2014. doesn't seem likely to me at least.
Old 01-24-2014, 02:40 AM   #91
MemphisR
Memphis
MemphisR's Avatar
I guess my post may have been poorly worded. What I mean is; is it possible that there is a simple solution from toyota like the fog lights.
Old 01-24-2014, 03:01 AM   #92
phanguy
phanguy's Avatar
I follow you now. But no I don't think there is. There are still various modules you would have to purchase and install. Similar to this one. And it may even require a new ecu or a flash. Or maybe a separate controller. You could probably look up all the parts required for the brz push to start as I'm confident that it's using the same system. I just don't see that being any more cost effective than this solution. It might be "easier" in the sense that everything should just plug in together, but there is also the chance that it would require a whole new harness for the car as well. And that would be a lot of trouble. Plus at least this way you're getting a good bit more functionality. :P
Old 01-26-2014, 03:42 PM   #93
MemphisR
Memphis
MemphisR's Avatar
True enough
Old 01-30-2014, 11:09 AM   #94
milkesfrs
milkesfrs's Avatar
Drives: hot lava
Got my FRS back from the body shop the other day . I started to work on the install video but temp outside got to like -19 here in the Chicago land area . To cold to work in the garage. It will be up soon. Til then if you have any ? on how to install this unit PM me.
Here is a better video of the Advanced Keys in action.
[ame="http://www.youtube.com/watch?v=_mJyaDdwL0k"]Advanced Keys Push to Start Installed Scion FRS. - YouTube[/ame]
The Following User Says Thank You to milkesfrs For This Useful Post:
phanguy (01-30-2014)
Old 01-30-2014, 11:15 AM   #95
phanguy
phanguy's Avatar
That's so slick. So it looks like the proximity range needs you to be pretty darn close to lock and unlock automatically yeah? That was something I was worried about so that's awesome. And the remote start works too! Freaking sweet. Did you also get the trunk working? Also I read in the other push to start thread that they aren't using Toyota style buttons anymore. Is the one you're using the one you got from them or did you order that separately? Thanks for your work man!
Also your car looks awesome.
Old 01-30-2014, 11:31 AM   #96
milkesfrs
milkesfrs's Avatar
Drives: hot lava
You need to be about 5 ft from the car for the doors to open. Its ok . If not my car doors would be locking / unlocking like crazy. Also, the truck pop work by holding the unlock button on the fob for about 5 seconds. The push button that Advance Keys uses is the OEM Toyota push to start button. Here is a more detailed video on how the Advanced Keys works. It covers everthing.
[ame="http://www.youtube.com/watch?v=tR-cZqpbFyM"]FULL Review: Advanced Keys Push Start Smart Keyless Entry System Lexus IS300 - YouTube[/ame]
Old 01-30-2014, 11:47 AM   #97
phanguy
phanguy's Avatar
awesome awesome. as far as the trunk i meant to ask if you had installed the actual trunk switch so that you could just walk up to it and open it without having to fumble with the fob. sorry for not being clear.
Old 01-30-2014, 11:57 AM   #98
milkesfrs
milkesfrs's Avatar
Drives: hot lava
No probs with the ? . I installed the trunk wire from the advance keys to the FRS truck wire in the car with out a trunk switch. If I think I know what your asking. You would need the advanced keys fob to open your trunk by holding the unlock button for 5 seconds. You have to connect a wire from the advance keys to do this fuction.
DIY - EasyGo Push Start Button Install (FRS or BRZ Premium) Chaetagnath DIY (Do-It-Yourself) Guides 225 09-03-2017 06:20 PM
Advanced Keys for GT owners..? luv85 Australia Classifieds 10 10-22-2013 07:48 PM
Pop-Start with Push-Button Start cmspooner BRZ First-Gen (2012+) — General Topics 5 03-22-2013 03:45 PM
Advanced Keys Inc + Viper 5904 Iddoit2er Electronics | Audio | NAV | Infotainment 5 02-24-2013 03:50 PM
Push Start Rough Engine Start Up joergasm Engine, Exhaust, Transmission 3 12-12-2012 04:44 AM
